I own the slowest f-ing 3.5 swapped fourth gen in history
Old 08-16-2007, 02:50 PM
  #41
VQ30 DE T
accordingtou's Avatar
Originally Posted by DasYears
all the more reason to deal with wiring instead of timing chains. i still havent heard of anyone that f'd up a full swap
we all might as well buy a 5.5thgen^
accordingtou is offline
Old 08-16-2007, 03:17 PM
  #42
DasYears
full swap 4th gen is faster than a 5.5...cheaper too
i just dont understand why people choose to go with less area under the curve and less potential when they could just do a full swap...for hardly any difference in work.
Old 08-16-2007, 03:23 PM
  #43
<3's the all motor section
XJinCT's Avatar
please dont **** on my thread guys, this isnt what this thread is even remotely about.
XJinCT is offline
Old 08-16-2007, 04:59 PM
  #44
VQ30 DE T
No pun intended
Keep the car man. You have a temp 3.0VQ donor in the back aka parts car.
Worst case scenario swap for stock motor & take your time with the 3.5 & timing equipment. sh&8 you should be a pro at pulling that VQ out by now Fyi if / and when you get a rwd sports car. 240 z skyline etc, it will basically eliminate the sleeper effect we get with these "family cars"/"fullsize sedan" "maxipads" "grocery getters" Excuse my run-on sentences.lol Guess I am living my sleeper dreams through your car .SAAD I know but my project has come to a screaching stop due to the body shop.
Old 08-18-2007, 05:02 PM
  #45
XJinCT's Avatar
useless update: met up with someone who did a 3.5 swap in their 4th gen. hes going to help me get it running the way it should. took a ride in the one he did...that thing is out. thats how i expected mine to be plus some. i couldnt get over how fast it was...just a intake too. im so excited to get mine done now :-D .
XJinCT is offline
Old 08-20-2007, 05:52 PM
  #46
XJinCT's Avatar
update with progress: found out the problem guys. its not even that bad!
the cam spacer/adaptor....apparently the cam dowel pin that slides through the spacer into the sprocket on the 3.5 is smaller than the 3.0...so it didnt have enough 'bite' and it jumped timing on the exhaust cams. no damage done. but i am using the 350z cams i aquired just to be safe with some spare 3.0 cam dowel pins i had. should be running by thursday at latest. at that time, i will def. take videos if all is well for you guys.
XJinCT is offline
Old 08-20-2007, 05:55 PM
  #47
Kevlo for President
Kevlo911's Avatar
Good stuff
Kevlo911 is offline
Old 08-20-2007, 06:07 PM
  #48
dot dot dot ...
NmexMAX's Avatar
What z33 cams are you using?
NmexMAX is offline
Old 08-20-2007, 06:09 PM
  #49
XJinCT's Avatar
non-revup ...
Adv. Dur. 256°/256° Dur @ .050 208°/208° Lift (in) .375"/.375" Lift (mm) 9.52/9.52
XJinCT is offline
Old 08-20-2007, 06:15 PM
  #50
nismology's Avatar
Non-revup 350Z cams = maxima/altima/murano/quest cams. AKA, 238°/240° with 9.5mm lift.
nismology is offline
Old 08-20-2007, 06:19 PM
  #51
XJinCT's Avatar
really? hm whatever. those are the specs the guy gave me i bought them from. came from a 03 350z so it would be non rev-up regardless. he even said it was non-revup also.
XJinCT is offline
Old 08-20-2007, 06:46 PM
  #52
XJinCT's Avatar
http://vids.myspace.com/index.cfm?fu...deoid=15026400
completely off-topic old video my friend just uploaded recently of my other car. when it was stock except for an exhaust
1989 audi 200 quattro wagon
why it rocks: turbocharged, 5 cylinder, all wheel drive, 5 speed. 170hp stock. it now rocks a full 3 inch exhaust, chipped 2.2 bar ecu, 18psi wastegate spring and a 034 motorsports bpv. it should be putting out around 230-250hp. with MUCH more room for improvement.
ps: i didnt upload the video, so im not the large man. im in the comments if you want to look at my myspace page for some reason.
edit: i know the car is a piece of ****. so save your comments its just a funny car thats actually pretty ****ing quick. cool sleeper/daily/winter beater.
XJinCT is offline
Old 08-20-2007, 08:50 PM
  #53
DasYears
either you got his aftermarket cams or you got
Old 08-20-2007, 09:05 PM
  #54
XJinCT's Avatar
how so? i knew what i was buying. i know they are the same as all other vq35 cams. i got them for 5 bucks literally. with intentions of selling them on this forum for more money. or now, using them as spares.
XJinCT is offline
Old 08-20-2007, 09:18 PM
  #55
DasYears
non-revup ...Adv. Dur. 256°/256° Dur @ .050 208°/208° Lift (in) .375"/.375" Lift (mm) 9.52/9.52
seems you were confused in the end. not trying to hate. if you got them for 5 bucks and really knew they were the same as maxima/altima/g/z...cams then nice steal
Old 08-21-2007, 06:54 AM
  #56
LandShark has Cosworth
grey99max's Avatar
Congrats! That was a good find. Especially since I'll be assembling mine when all parts are here, so thank you for posting this.
grey99max is offline
Old 08-21-2007, 07:47 AM
  #57
XJinCT's Avatar
no problem buddy <3.
XJinCT is offline
Old 08-21-2007, 08:03 AM
  #58
Sexier Than Simpson
Bufflomike's Avatar
So you still selling for 5K? I hope not because of the blood, sweat and trears into this. Good luck with the timing and hope you are screaming yes pretty soon.
Bufflomike is offline
Old 08-23-2007, 06:27 PM
  #59
XJinCT's Avatar
car is back in effect and running like a ****ing champ. this is what i signed up for when i did a 3.5 swap. ill hit up the track this weekend and dyno later on in the week. videos soon to follow. thanks for the support of everyone on this forum. i couldnt be happier.
XJinCT is offline
Old 08-23-2007, 06:42 PM
  #60
nismology's Avatar
Old 08-23-2007, 07:01 PM
  #61
DasYears
nice, glad it worked out for ya. now go visit the 12s range
Old 08-23-2007, 07:57 PM
  #62
XJinCT's Avatar
ill post pictures of my masacred 3.5 dowel pins to show you in pics what happened. kinda humorous actually.
XJinCT is offline
Old 08-23-2007, 08:01 PM
  #63
XJinCT's Avatar
lol low low 14s high 13s maybe...all motor...nitrous and slicks i should see 12s tho
XJinCT is offline
Old 08-23-2007, 11:20 PM
  #64
DasYears
you must not have intake or headers, or a 5spd. or maybe a driver mod is in order . but really, with a 4.5 and bolt ons you can see low 13 easy.
Old 08-24-2007, 06:06 AM
  #65
dot dot dot ...
NmexMAX's Avatar
The only swapped A32B that has gone low in the low 13 second range is Jime, 96sleeper, Tilley, JClaw and krismax I'm sure there are a few others that have slipped my mind, but the fact is, it's not as common as one would think.
Everyone else seemed to hover in the upper 13/slow 14's arena. Seems as if most in the upper 13/low14's had a y-pipe of some sort.
NmexMAX is offline
Old 08-24-2007, 08:35 AM
  #66
DasYears
IMO the majority of the people that arent fast have a number of reasons, such as no tune or very few bolt ons. thats why i asked if he isnt modded. krismax ran 12 with low power number, and i think he could be faster than he ran too especially because of his weight
Old 08-24-2007, 09:39 AM
  #67
nismology's Avatar
A hybrid 4.5 won't see low 13's/high 12's without cams unless there's MASSIVE weight reduction (a la krismax).
Old 08-24-2007, 11:45 AM
  #68
DasYears
hmm, always felt different to me, probly cause i only feel like a few can be considered as others have no supporting mods or tune. and we know they run rich even WITHOUT mods. oh well.
IBcvtclesswonders
Old 08-24-2007, 02:11 PM
  #69
XJinCT's Avatar
ummm i have all of those. im just not cocky about my car and wont say **** i dont think it can do. ill let the slips talk when i get back from the track.
i pulled a 13.9@95 with a 2.060 60ft on street all season tires. on a beat 253k mile 3 liter. stock with a drop in air filter and 75 shot. when you can do that, then you can tell me to get a 'driver mod'.
but anyway....short ram intake, ebay headers, motostorm crank pulley, ssim, phenolic lower intake spacers, apex safc2
then i have my nitrous on top if i really need it. havent tried it on the 3.5 yet because its not filled.
XJinCT is offline
Old 08-24-2007, 02:16 PM
  #70
chillin014's Avatar
yeah seriously. why bother throwing numbers out there? you run what you run DAYMN. should/could/would/might/wish/dream
chillin014 is offline
Old 08-24-2007, 02:23 PM
  #71
Sexier Than Simpson
Bufflomike's Avatar
That might actually run 13's easy
No driver mod needed
Old 08-25-2007, 12:41 AM
  #72
DasYears
yeah, i have no doubt that you can get into the low 13's with those mods.
Old 08-25-2007, 12:58 AM
  #73
dot dot dot ...
NmexMAX's Avatar
Unless you have experience with 13's, stop talking like you know is up, mmmmmmmmk.?
NmexMAX is offline
Old 08-25-2007, 07:21 AM
  #74
VQ30 DE T
Lmao.
Old 08-25-2007, 10:02 AM
  #75
SLOW
Nealoc187's Avatar
aiming low is always the way to go at the track, things have to fall into place just right to run really exceptional times. if you aim low you won't be disappointed - that's how I always look at it anyways.
Nealoc187 is offline
Old 08-25-2007, 10:12 AM
  #76
DasYears
unless you have experience with racing AT ALL then stop talking like you know is up, mmmmmmmmk.?
Old 08-25-2007, 11:00 AM
  #77
XJinCT's Avatar
i love my thread.
XJinCT is offline
Old 08-25-2007, 11:28 AM
  #78
chillin014's Avatar
so...what tuning device are you using?
Old 08-25-2007, 11:32 AM
  #79
XJinCT's Avatar
safc2 for now. EMU later on.
XJinCT is offline
Old 08-25-2007, 12:53 PM
  #80
nismology's Avatar
Tone aside, he's right. Saying he's gonna run low 13's off the bat is unrealistic. Sometimes it's better to not say anything than to give someone false hope.
Quick Reply: I own the slowest f-ing 3.5 swapped fourth gen in history
