All MotorAll Motor Advanced Performance. Talk about Engine Swaps, Internal Engine work. Not your basic Y pipe and Intake Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
I used an 04 shifter and cables in miine. It was a steal at $40 for the set.
I cut off the two chassis studs, drilled holes and thru-bolted it. Works great.
Really? Interesting, this gives a much cheaper option for swapping. If the 6th gen ones work, the sentra one might work as well and they are pretty cheap from the dealer
__________________
97 Pearl White Max GLE
I has car
When I received the shifter/cable assembly, I did not know what chassis they were out of until I checked the part numbers.
IIRC the A33B transmission hole cover has to be rotated 180 degrees for the A34 shift mechanism to have its full range of motion.
The A34 shift cables may also be a touch longer than the A33B ones. I have never had them side by side but they are longer than they need to be for an A32 application.
Can you to this conversion straight from auto? I would assume I would need to use some steps from the Auto to 5spd swap to prep? can anyone tell me which ones? I was planning on turboing but I'm not sure if I can justify paying $600 on z32 injectors when I could get a VQ35 for that and I've heard the auto's dont deal with that swap well.
__________________
'96 GLE: Y pipe, Test pipe, Cone filter on stock mid-pipe, Debadged, Re-Wired Amber Corners, Megan Catback, Clear bumper lights, tinted tails
Coming soon: oovi, and wait for my tranny to blow...(starting to lust after 5spd)
32702-AD012 Part number for the speedometer pinion you will need to use. Only comes on the L31 altima 6-speed. A33B and A34 6MT's just have a cover (removeable) there.
__________________
Tuning a car isn't a crime, but spelling it "tunning" ought to be. - ....
This may be self-explanatory once I get the part, but is it pretty easy to figure out how to put it on? Do I just attach the pinion to the tranny and then the VSS attaches onto that? And where exactly is the cover located on the transmission?
I apologize in advance if I'm asking dumb questions. I'm really just starting to understand this whole swap procedure.
Is there something special I'm supposed to be looking for with regards to the frame transmission mount? I was talking to DaveB trying to order it from him but he said there's nothing to order unless I bought the frame rail which is like $300. He said from what he was seeing that the mount is also welded to the frame on the 5.5 gen.
So I must not be clear on something. I am supposed to be getting a 6spd frame transmission mount from an 02/03 maxima correct?
Just to clarify, unlike the A32/A33 the bracket bolts to the transmission and the mount itself bolts to the frame. The part number listed is for the former.
__________________
I have the bracket that bolts to the transmission. I need the part that bolts to the frame.
So then is 11253-AU400 the wrong part? If so, does anyone know what the part number is for the mount that bolts to the frame?
my tranny is giving me problems so i want to swap to a 6spd, i just want to clear a couple of things up: the 5spd bellhousing will not work at all correct? and the specVs 6spd is most likely going to be my choice since im guaranteed a HLSD and they are cheaper, so will i use the 6spd maxima axles or the specvs axles?
__________________ 96 Black I30t VLSD 5spd A.K.A Big Black(has a bad attitude) Eibach springs//Koni yellows//Koyo OE Radiator//F&RSTB//Black retro'd Cefiros w/E46 Bi-Xenon projectors/ZKW clear lense'd//Budget y-pipe//test pipe//Apexi WS2//WAI//Grounding kit
The 5spd bell housing will not mate with the 6spd. You will need 6spd Maxima axles, and the passenger side must be OEM b/c aftermarket ones are too short.
Rwd cars have a bellhousing which is not part of the transmission.
Our fwd tranny uses a clutch housing which is an integral part of the transmission. It houses half of the shaft bearings as well as the mounts for all the shift linkages.
Buying a specV tranny will not be cheaper as you will still have to buy a maxima clutch housing. All your bearing preloads/clearances will have to be measured and appropriate shims obtained.
so there is a little modification that has to go into using the SpecV tranny, its not practically bolt on like the max's 6spds?
thats a cool swap, but whats the point if your not a everyday highway cruiser, doing atleast 80MPH...the way i drive, the 5spd is best for me..and from reading around here, it seems the 5spd is stronger.
Is it possible do all this with 5th gen 01 maxima A/T ? and get 6 MT for my 01 max auto? if it's possible how much it will cost$ ? i know it's very hard to swap a/t to m/t
I didn't see an answer to this question but, did anyone who used the HLSD diff or tranny use the non locking driver's side axle? If it's anything like the LSD and non LSD 5spd, then I know the answer is no. The splines of the axle have to correspond with the differential, but in the case with some LSDs on different cars, the LSD diff takes the non LSD axle. In any event, i've got asked this question and wasn't 100% sure of that answer. I'd assume when you switch to an HLSD dif from a non locking dif, you have to change the driver's side axle as well. Am I mistaken?
FAST shows only one part number for the left side 6MT axle, regardless of HLSD or not.
__________________
Quote:
Originally Posted by 2damax
This jerk is right so often I just search threads hoping he gets something wrong so I can catch him
Quote:
Originally Posted by kizzmyazz
ok so what i found out is that because of the FMU, i dont need to get injectors because it will neutralize the oil pressure to prevent detotnation
Wow ... this is awsome, nice write up and tons of good info. I'm still looking to do the 6spd swap and part ways with my 5spd. This will come in handy when the time comes, thanks!
__________________
CAI, Test Pipe Cat, JDM N1 Cat back, FSTB, Aluminium dash kit, STS, Razo shift knob, Clear markers, CC mod, .ORG Stickers (bright blue), Blue LED switches / map lights, A6 Bi-Xenon retrofit, rebuilt 5spd - My write up --> http://forums.maxima.org/showthread....121&highlight=
how much power did you get form this swap on dyno ??
will 6spd from an Altima 2005 good for me ?
You'll be at the same WHP as a factory 6 speed, you don't 'gain' anything. Calculate it out yourself using the drivetrain losses for the auto (assuming you are?) and the 6MT.
Will the '05 Altima 6MT work for you? Who knows, you have neglected to either fill out your profile or tell us what kind of car you drive.
__________________
ahh crap this would explain why the shop called and told me the 6spd axles are a bit off , I got A34 6spd and L31 Tranny . I wonder if that makes any difference ?
What do you mean, you got a trans from both? Or axles from the A34?
HLSD or no, there's no difference in axles for the RS6F51. Are you absolutely certain the axles are from/for a 6MT? The auto axles are very similar, but a different length.
Which axle? Or both? What exactly is a 'bit off'?
__________________
Well I shouldnt be posting here , I own a a33 and a34 .
I got tired of blowing these 5ATs so I got Nismologys 6spd.
the shop called me today and said there was a slight issue with the passenger axle. I have the 6spd A34 Axles but im using a L31 Tranny.
I purchase just about everything for my year but they are saying they have some issues.
At this point they should be able to figure it out since its a tranny shop www.atfspeed.com
that does this all day.
I was just browsing this thread and notice that I will have to drill the hole bigger for the CPS so thats good to know even tho this is about a32 6spd swap.
I just hope I dont have to dump more money into parts
All HLSD and non-HLSD use the same gear casings for A34/L31 etc.
HLSD inner CV joints do not require a special shaft like the VLSD 5 speed does.
The problem may actually be your passenger side driveshaft mounting point where it bolts to the block
I think that could be it , on the 6th gen 5AT the CV on the passenger side has 3 (10mm) bolts , It could very well that bracket that mounts on the engine that the cv axle shaft MIGHT NOT be bolt up right due to the 6spd axles?
I will look into that but its rare to find those parts in a junk yard , esp 6spd A34
