Well it was the oil pump...
Old 05-21-2007, 10:33 AM
3.5 in the works
DandyMax's Avatar
Finally got a chance to pull my seized engine out and as soon as I got the pans off it became clear... oil pump, just like I (and most of us probably) thought.
Check out the pics below... cracked the casing in 4 places and shredded the teeth. In the 2nd pic those loose pieces off by themselves I found in the strainer..
DandyMax is offline
Old 05-21-2007, 10:40 AM
Kevlo for President
Kevlo911's Avatar
Kevlo911 is offline
Old 05-21-2007, 10:41 AM
KRRZ350's Avatar
What were you pushing for rev's? On a side note that engine appears to have low miles or have been well taken care of.
KRRZ350 is offline
Old 05-21-2007, 10:43 AM
3.5 in the works
DandyMax's Avatar
Kev I only see 3 cracks on that one...
KRRZ350: the engine had somewhere around 115k miles on it, it had lived on quality synthetic its entire life AFAIK. I was usually revving only to 7300-7500 but did hit higher a few times. It just fatigued I think, because it didn't actually fail at that high of a rev, I was around 4000-5000 during a burnout when it seized.
DandyMax is offline
Old 05-21-2007, 10:52 AM
95BLKMAX's Avatar
oh wow what a bad one. This is new to me to seea VQ oil pump go out like that (or to go out at all for that matter) nice pictures tho! lol
95BLKMAX is offline
Old 05-21-2007, 10:58 AM
1FSTMAX's Avatar
i cant see the pictars!...
1FSTMAX is offline
Old 05-21-2007, 11:01 AM
3.5 in the works
DandyMax's Avatar
Sorry.. fixed it (I think)
DandyMax is offline
Old 05-21-2007, 11:17 AM
1FSTMAX's Avatar
works now.. +1 on the clean engine.. So what is you next enine set up going to be?
1FSTMAX is offline
Old 05-21-2007, 11:23 AM
Old enuf to pick his own gears
d00df00d's Avatar
It has happened before with extended use with a really high rev limiter.
d00df00d is offline
Old 05-21-2007, 11:50 AM
gtr_rider's Avatar
I wonder what my beat 233k mile oil pump looks like :-x
gtr_rider is offline
Old 05-21-2007, 12:02 PM
3.5 in the works
DandyMax's Avatar
works now.. +1 on the clean engine.. So what is your next engine set up going to be?
To get me through this season, a DEK out of an 01 with about 55k on it that I will modify a bit...
DandyMax is offline
Old 05-21-2007, 01:16 PM
Bacon Lover
Tatanko's Avatar
We better see a 12-second time slip
Tatanko is offline
Old 05-21-2007, 02:29 PM
JClaw's Avatar
Cams in a DEK will put this guy in the 12s! Once he has set the bar impossibly high for everyone else, hes gonna move on to the 3.5 and do the same thing.
JClaw is offline
Old 05-21-2007, 02:32 PM
LandShark has Cosworth
grey99max's Avatar
Clever Canadians... J/K
grey99max is offline
Old 05-21-2007, 02:52 PM
Zack342's Avatar
can you use a reved up oil pump?
Zack342 is offline
Old 05-21-2007, 03:22 PM
fwd gone rwd cr00
tavarish's Avatar
I think the air in canada is ideal for maximas, for some odd reason.
tavarish is offline
Old 05-21-2007, 03:54 PM
SomePsychoGuy
SPiG's Avatar
Looks like some one needs a Rev up or HR oil pump?
Krismax blew his pump with a 8000rpm rev limit.
SPiG is offline
Old 05-21-2007, 03:55 PM
3.5 in the works
DandyMax's Avatar
Tell me about it! I was so disappointed to be .007 away on that run before it seized...
BWAHAHA... you have discovered my evil master plan!
But I will need my secret weapon - Canadian "20% nitrous" air - to pull it off!
LOL. J/K... but in all seriousness, I am 100% sure I could have hit 12's with that engine on stock internals if it hadn't seized. I just figure now that since I have to swap in another engine I might as well tweak it a bit to increase my chances.
DandyMax is offline
Old 05-21-2007, 04:45 PM
speed racer's Avatar
Damn. that oil pump exploded. Great to hear your still considering the 3.0 platform. I feel that there's still unchartered HP that can be have from the 3.0.
Are you going aggressive with cams or just dropping in the 3.5 one's?
speed racer is offline
Old 05-21-2007, 06:15 PM
GoalieKeg's Avatar
I figured it was your oil pump. Time for a revup one.
GoalieKeg is offline
Old 05-21-2007, 06:16 PM
nismology's Avatar
The standard 3.5 oil pump would be fine.
nismology is offline
Old 05-21-2007, 08:44 PM
SLOW
Nealoc187's Avatar
Why do folks suggest the Revup pump over the stock 3.5 pump? I've heard it suggested before but don't know the reasoning.
Nealoc187 is offline
Old 05-21-2007, 08:47 PM
GoalieKeg's Avatar
My logic is since revup motors take higher revs easier, then the revup oil pump must be either equal if not superior to the stock VQ35 non-revup pump.
Old 05-21-2007, 08:52 PM
nismology's Avatar
The revup oil pump has like 17% efficiency over the standard 3.5 oil pump, but would be overkill for a 3.0. The standard 3.5 oil pump is good for 7500+ RPM and has to provide oil for the VTC sprockets and the piston oil jets. Subtract the VTC's and the jets and it's clear that the standard 3.5 pump would be sufficient.
Old 05-21-2007, 08:53 PM
GoalieKeg's Avatar
So in other words my logic is correct...stfu n00b lol
Old 05-21-2007, 09:11 PM
nismology's Avatar
Want a scooby snack?
Old 05-21-2007, 09:17 PM
3.5 in the works
DandyMax's Avatar
I haven't decided what I'm doing yet. I need to do some measuring and analysis first... it will depend on $$ also.
DandyMax is offline
Old 05-21-2007, 09:34 PM
nismology's Avatar
Flow volume yes but what about ~8000-8200 rpm? Think the standard 3.5 will be as good as the rev-up at that level? Or would that be pushing it on both? ie will they hold together, assuming they can flow enough.. I'm trying to remember what pump 350zlover used on his high-rpm build (I'll search later if you don't recall)
He went with a revup oil pump shimmed to raise the "pop-off" pressure.
Your dilemma is something I've though for a while now. Do oil pumps fail due to mechanical failures (the internals physically not being able to handle it) or due to insufficient flow at high revs due to design issues, thus starving itself and the rest of the motor? Maybe they cavitate and cause the oil to foam at excessive revs? I wish I knew the answer...
Old 05-21-2007, 10:40 PM
KRRZ350's Avatar
I'm voting for mechanical failure of the pump, but that's just my .02 cents.....
Mustang dohc failed oil-pump, on these engines they fail because of a weak powdered metal used in the gears, billet oil-pump gears take care of that. Please don't flame, I just thought that this was at least somewhat relevant to this thread.
KRRZ350 is offline
Old 05-21-2007, 10:50 PM
3.5 in the works
DandyMax's Avatar
Oh it was shimmed? Any more details on that (how much etc)? I didn't know that but I did realize he'd used the rev-up pump (which is why I deleted that part of the post).
But yeah, I'm wondering too about what failed. Cavitation could be a possibility, the resulting large pressure differentials behind the impeller teeth... Another thing is that crank torsional vibrations will only get worse with high rpm, resonant frequencies can become an issue and if one has a UDP that's not damped...? Or is it a mechanical issue (ie stresses/metal failure/fatigue simply related to the high speed)?
One thing I will say, that 3L pump casing seems thin/not rigid or reinforced enough to me... I'll be looking forward to comparing a rev-up pump in a few days.
DandyMax is offline
Old 05-21-2007, 10:54 PM
3.5 in the works
DandyMax's Avatar
No worries, it is.
Unless I'm mistaken though (small pic), it looks like the casing held together even though the innards 'sploded (how's that for a technical description lol), it looks a lot more rigid/reinforced than the VQ30.
DandyMax is offline
Old 06-11-2007, 12:33 PM
3.5 in the works
DandyMax's Avatar
Bump. Rev-up pump is now here... anybody want pics of it posted up?
DandyMax is offline
Old 06-11-2007, 12:57 PM
Red Lion's Avatar
...sure!
Red Lion is offline
Old 06-11-2007, 02:09 PM
Bacon Lover
Tatanko's Avatar
While you're at it, update us with your full progress. I know you were going to throw a DE-K in, but I don't know if you ever said whether you were going to put cams in or change anything else from your previous setup. So, fill us in
Tatanko is offline
Old 06-11-2007, 02:19 PM
nismology's Avatar
Pics of the guts? Sure...
Old 06-12-2007, 06:43 PM
3.5 in the works
DandyMax's Avatar
Alrighty, so here's some pics. The casings are nearly identical and the rev up pump should fit right in place of the 3.0 pump (haven't put it in yet though).
The most noticeable difference is the depth of the inner/outer gears (by depth I mean thickness parallel to the axis of rotation - just look at the pics lol). The rev up gears are about 3 mm thicker. However, the tooth patterning is the same on both pumps.
I may shim the regulator yet before I put it in. Have to look up some info on that. BTW, the revup pump part number is 15010-AC700 in case anyone wants it.
DandyMax is offline
Old 06-12-2007, 06:45 PM
3.5 in the works
DandyMax's Avatar
Not much to update yet, progress has been slow due to other projects on the go with the house, doing work for local guys etc. I can tell you the DEK cams will be getting switched out though.
DandyMax is offline
Old 06-12-2007, 06:51 PM
I guess it being thicker means that it can handle more stress at higher revs without with minimal failure. It sounds like there may be some tinkering to get it in and working.
Old 11-05-2007, 02:56 PM
3.5 in the works
DandyMax's Avatar
Some pics to complete the thread
Here are some pics of the #2 rod bearing that seized my DE engine (after the oil pump went). Always meant to post these but never got to it. Seeing as Neal posted his funky piston shots up today, I figured why not continue the engine carnage theme..
The other half was so bad I couldn't get the cap off the journal..
DandyMax is offline
Old 11-05-2007, 03:08 PM
SLOW
Nealoc187's Avatar
yyyyyiiiiikes....
Quick Reply: Well it was the oil pump...
