00vi swap
00vi swap
So I started with the swap yesterday, using all 5th gen parts..Uim, Lim, fuel rail, injectors, tb, valve cover, and coils. I got everything off and put on the new valve cover, coils, 5th gen lower im and new injector plugs. I got the LIM from someone in like great britian and it looks a little different than the ones ive seen around the org. I also got the fuel rail and injectors from GB, but it looks like the fuel rail mounts dont line up with the wholes in the LIM.....Im gonna have to figure something out.... but i got two more problems as well. I remember reading (but don't remember where) about the passenger side nipple on the vias, i don't remember if I'm suppose to block it off or run a vac line to somewhere.....Also, for the Uim to connect to the Lim you need 3 6X1X100mm(got those bolts) and 3 6X1X130mm which i can't find anyyyyywhere. (nissan said it will be about a week till i can get em) Would it be drivable till i got hold of the bolts?....Im goin to work on the whip again....ill be back in a little.
......figured out ^^^^^on my own but ran into one more problem... on the rear passenger side of the front valve cover, there is a large nippe. Anybody know what its for/where it goes?
Brake booster.
What did you figure out? YOU NEED AT LEAST 3 BOLTS, I would not drive w/o um. NONE of the vias nipples need to go to a vacuum source; the most inner one can go to a fresh air source or can be left alone. I don't understand why the fuel rail and lower IM don't match up if they came from the same car, did you get jipped? Any pics?
its not a mevi, its a 00vi from GB but its a smaller version.. the US power rod doesn't fit inside its too big..... but that huge nipple coming out of the front valve cover is the brake booster? I thought that was the house running across the fire wall?....Also the other nipple on the rear valve (not the pcv) what does that hook up to?
If I'm interpreting what you're saying correctly, then those nipples on the valve covers (passenger side) are for the PCV system... not the PCV valve itself but just the hose connecting the two valve covers.
Post some comparison pics up of the UK manifold(s) if indeed they're that different!
Yea ill def post some pics after....so the nipple on the front valve cover and the nipple on the rear valve cover go to each other?....I'm about to drop on the uim right now then time to run vac...
Originally Posted by Kevlo911
Brake booster.
Originally Posted by Tatanko
Kev, you know better than that. It's PCV-related (like Dan said)
Yes, those two nipples connect. Just run a hose from one to the other. You could probably re-use the stock hose, but I'd put a new one in. Mine was cracked when I took it off.
I finished getting everything on did a double look and went to turn the key...the motor turned over but wouldn't start...and the clutch sounded squeakey...but yea i checked over all the plugs,vac lines, injectors everything is good but no start...any ideas?
also i cut the wires on the iacv going to the egr (its blocked off), and i plugged a house carrying coolant to the 4th gen tb.....would any of this cause the no starts?
Did you remember to put the fuel pump fuse back in?
idk.....when I turn the key to run, there is this thing that might of been bolted on to the stock manifold by 2 bolts (i dont remember). I know it was metal with a big brown cap/plug. it was running a vac line to the stock manifold and has a couple other lines running to it. but yea when u turn the key to run it makes this weird noise kind of a grinding sound but not really? right now its hangin free on the top of the manifold with no vac source from the manifold...what is that thing and could it be a problem?
Meh finals today I misread, I thought he said rear pass side of the IM and not VC
...Yea i swear i put that 15A fuel fuse back in, but i guess i didn't. When i popped it in she started right up!.. I got a little vac leak in the brakes, everytime i push the pedal it whistles. But yea def g2g to the dyno this week and get a tune..
Nope, maybe its not a vac leak. I T'd the brake booster and iacv hose together like your website showed, but some of the hoses are a little kinked. Alot of things still need mounting and a little bit of work. But yea the brakes feel like real hard to push and dont work that great alot of the time. It should all be figured out over time tho.....but yea im tunnin with the vafc 2.
I def read it on your site under 00vi>Cool ideas. Its called Curts IACV install. But i guess tomorrow im gonna have to change that and put a 1/2" nipple somewhere on the intake mani for the iacv.
Maybe I need to revise something...
jmlee44
10-02-2022 02:13 PM
TallTom
50
07-08-2022 09:54 AM
HerpDerp1919
09-29-2015 02:02 PM
