VQ Valve Spring spec. charts
It looks like the VQ35HR spring is the way to go. It isn't linear like the Nismo spring so it doesn't have the seat pressure but it does have much higher full lift pressure and it can go all the way to 13mm vs. the Nismo spring at 12mm.
This means that even with 11mm lift cams you can double shim the HR spring to raise the seat pressure and still not get coil bind (for a total of 12mm effective spring lift pressure).
Thank you Nissan!
edit: Those colors I listed with each spring is the paint color mark from Nissan. And IIRC, some VQ30 springs had yellow.
VQ35HR valve spring part# 13203-JK21A
Great charts, here's a noob question; if doing cams on a 3.5 would the HR springs be comparable to JWT, Crower etc..? I'm new to engine building and it's specific requirements for higher revving and stability.
I have seen a few errors in the VQ35HR service manuals, now it would be nice to see someone confirm the 37mm install height for it's valve springs (which is the same as all other VQs).
MMmk, double shim HR springs to get Nismo equivalent or better seat pressure, and still be able to achieve higher lift w/o coil bind when using ub3r aggressive camoids, and for 3x less price, with more potential than said Nismo pieces, I think.
I think I'm getting better here. I get up to speed in electronics, and now for mechanical
Thanks, once again, SR20DEN =
Untill I physically have a spring in hand to test i'd rather not speculate.
I did this chart in 1mm increments to make it somewhat easier to compare with other manufacturers listed specs but those advertised numbers still won't tell the whole story. If anyone wants to send me a Ferrea, JWT, Crower or Supertech spring, I'd be most happy to spec it.
I also want to add that with the HR springs, you should use the HR retainers. IIRC, they have a little more meat on them.
man, the more time i spend on here learning about nissan engines the less it seems like i will ever switch over to another company.
this is some pretty interesting info.
question though, what is the importance of having higher valve lift? allowing more gases to enter and escape or what?
Nice comparo.
So we know it can handle lift. But can it handle revs? The valve is at full lift for a small fraction of the time. I think I'd still opt for a spring with more "area under the curve" when dealing with 11mm+ lifts @ > 7500 RPM, for instance. This might be fine for moderately aggressive cams at reasonable revs, though.
Just for reference, from Z350lover's experience the valves floated with the Nismo springs @ 11mm/7500 RPM.
Originally Posted by nismology
Nice comparo.
That extra linear force also robs the engine of useable torque. Which is another reason why I like the idea of this progressive spring.
He was also using the 55* CVTCs and the 272* cams. Both are to be considered reguarding his problem.
But we have the specs of the VQ35HR to look forward to. It does also rev to 7500 and has a 10.5mm cam lift, not far from the 10.82mm R Tune Nismo cams or the 10.9mm JWTs. Granted those have a higher duration.
Peak valve acceleration occurs for only a brief moment as you come off the crest of the cam. You really only need a relatively large force at this point in order to reverse the direction of valve travel. The HR spring seems to fit this bill better than the other springs presented. (for 10+mm lift)
The brute force method of throwing more spring force at it will not necessarily solve potential valve float issues.
You need to be careful when mixing and matching valvetrain components from various vendors and motors for high rpm usage. It is pretty easy to throw some high lift/duration cams, high force valve springs and lightweight valves, retainers, etc. together and think you have the ultimate valvetrain. What you do not know is what you have done to the critical frequencies of the system. (ie. spring surge)
Originally Posted by SR20DEN
But do we know that the area under the curve is really that important here? You want the extra pressure at max lift to keep the valve from going past max cam lift from inertia. That spike is nice to keep the bucket planted firmly on the tip of the cam lobe and get it set in motion in the opposite direction to close. Once it is already in motion do you really need a linear force to close it in time?
Originally Posted by eng92
"Area under the curve" only gives you the amount of energy input required to compress a spring. Generally you want the smallest amount to get the job done in order to minimize wear and valvetrain losses.
Was that due to insufficient spring force or surge?
He was/is using nismo spec 1 camshafts, FWIW.
i guess dual springs means simply 2 springs on top of each other?
also, the HR revs to 7,500, so shouldn't the HR valve train theoretically be able to handle the 8k rev and 11+mm duration? i assume that real world usage is different than theoretical usage.
so, to break it down. using the HR valvetrain in a fwd vq35, revving to 7500 shouldn't be an issue right? and with cams like nismo r (10.5 lift, 262 duration), revving to 7500 with that lift definitely shouldn't cause any trouble seeing as the rpms are oem(HR) with just a little more lift than stock HR cams... right?
any info on HR rod bolts? i dunno if they are designed the same, but from what i've read on here, revving to 7500 rpm on vq35 rod bolts = not a good idea..
I am revving to 7500 now with the stock valve springs and cams. But there is still no guarantee that the HR springs will do the job to 7500 on cams that have 1.32mm more loft and 24* more duration than the VQ35 OE cams.
There is only one way that question can be answered. Someone has to do it.
what about the rod bolts? do HR fit on the vq35? or is that a completely diff design?
btw, you have rod bolts at least right?
Originally Posted by AnDyMaN
i see, so a real big factor is the cams have more lift and duration that stock cams....
Retainers;
So I have to retract my statement about the HR retainers. I haven't seen one and I do not know anything about them. I confused them with the VQ35DE revup retainer which I do have one of.
Maybe I will order a HR retainer now but here are two pictures I just took of the VQ35DE (2002) retainer next to a revup retainer. You can clearly see the difference in extra mass on the tops.
http://www.vq35de.com/Images/valvesp...etainers01.jpg
http://www.vq35de.com/Images/valvesp...etainers02.jpg
And if you ask why would you want to use the factory retainers, the answer is simple. Mass. These are made from an aluminum alloy which has LESS mass than titanium. If you buy titanium retainers they will be stronger but are also likely to weigh MORE than the OE retainers.
steel > titanium > aluminum
Originally Posted by DandyMax
Thanks Matt for the info. Just for fun can you add the VQ30 spring to the graph?
Also, did you ever have a chance to mic any of JWT's springs?
Everyone needs to be aware that later style VQ35 springs are weaker (A34 etc.) according to those ESMs.
From what I have checked in the past, the VQ30 spring is exactly the same as the early style VQ35 spring.
Then again my memory's bad... I'll look for the thread if I get a chance.
*edit*: found it, they are the same. Guess I just remembered wrong.
That's not very reassuring How high can a A34 spring go on stock cams without worry. Don't they use the same springs as mrev Z33's?
The way they spec the springs in the ESMs makes it difficult to compare them.
so by your greater than/lesser than diagram, steel is best, then its titanium, then its aluminum?
but in the paragraph you talk about why the OE retainers(aluminum) are better (because it has less mass).
could you please clarify?
Aluminum is about 1/3 the density of steel.
Titanium is about 1/2 the density of steel.
got another one for ya. you say you rev to 7500 rpm.. do you hit that daily? like maybe once or twice a day?
i ask because i remember reading that someone's oil pump failed because of the constant high rpm they were seeing (all motor).
will the stock oil pump stand upto 7500 daily? if not, would the 350z oil pump be able to work in a maxima directly?
The oil pump failures are on the VQ30, not the VQ35. The VQ35 oil pumps were the same until the revup cam out.
They have a different part number. I remember reading on my350 that there was either a 17% or 19% increase in efficiency with the the rev-up pump. Either way, from what i've seen the regular non-revup 350z oil pump (aka maxima/altima/etc. pump) is good for AT LEAST 7500 RPM.
True. But from what i've seen on alot of the buildups is that they'll throw in the rev-up oil pump for good measure even if they don't plan or revving past 7500 RPM or so.
But enough of this irrelevant OT mess.
