00VI EGR Problems
00VI EGR Problems
I finally decided to put my 5th gen EGR tube on today...and now the upper manifold won't seal with the lower manifold. It's very, very close. I was told I need to bend the EGR tube towards the firewall a bit to make it sit right, but I absolutely cannot bend this thing, nor do I see how it is the cause for problems. If I can't get this problem fixed in the next hour, I'm putting my block-off plates back on...It's not worth this absolute nightmare of a problem.
Mine was ALMOST perfect. Just enough so that there was maybe a 0.5mm gap between the upper and lower, and only on the back, the front touched fine.
Oh well, maybe next weekend. Car ran pretty well at the drag strip last night once I remembered to change my RPM switch settings back to their correct digits (try a 0.6 difference in the 1/4 mile )
What you have to do is keep the bolts on the 5th gen egr loose enough that you can move it. Put the UIM on and than carfully hit the egr until its lined up plumb. Once lined up plumb than tighten the lower bolts.
0.6 is a good improvement!
Originally Posted by DandyMax
C'mon details man, whadidya run?
That was with no weight reduction, manually shifting, no DR mod of any kind, nothing. Just my car with me manually shifting.
shilov
02-19-2024 09:40 PM
t6378tp
09-29-2018 04:27 PM
KabirUTA13
19
10-17-2015 02:15 AM
JoshG
51
09-21-2015 10:41 PM
