DEK swap - running the hoses
Old 03-13-2007, 08:22 PM
Create From Nothing
Digital Alchemy's Avatar
from what i can see they moved the hoses from the side of the block to on top of the IM. wanted to know if anyone knows where I can get a clear picture of where all the hoses ran to and from???I don't hook up anything wrong or forget to hook something up.
Digital Alchemy is offline
Old 03-14-2007, 05:22 AM
matty's Avatar
Since the 4th gen and 5th Coolant Logs are different, you need to modify the 4th gen Vac gally if you want to re-use it.
When I did my swap and took off the stock gallies, I kept both the gallies in tact...(meaning I left all the vaccum lines where they were) I then moved the green plug, I believe for the KS, over to the one side of the main metal bracket. I then drilled a hole in that bracket and mounted it to the 5th gen Coolant Log. I went to the FSM and printed out all the diagrams on there for the Gallies and did up the vaccum lines exactly how they have them in the FSM.
-matt
matty is offline
Old 03-14-2007, 08:30 AM
Create From Nothing
the 4th gen fsm or the 5th gen fsm i have both. one for my 98, and a 00 for the dek
Old 03-14-2007, 08:33 AM
matty's Avatar
Use the 4th FSM if your keeping all your 4th gen EVAP, EGR stuff, Vac Gallies
-matt
matty is offline
Old 03-14-2007, 01:25 PM
Create From Nothing
cool thanks man
Old 03-17-2007, 05:33 PM
RedfoxXx's Avatar
I have been looking into doing a dek swap as my vq30 leaks oil badly,
I keep reading about the "coolant log" but what exactaly is it?
RedfoxXx is offline
Old 03-17-2007, 06:35 PM
matty's Avatar
Your upper radiator hose goes from your radiator to the Coolant log. It has the engine coolant temp sensor on it and the sensor for the temp guage. Main purpose is to bring coolant to each bank
-matt
matty is offline
Old 03-17-2007, 06:51 PM
Cdg2125's Avatar
what has to be modified with the coolant log? Sorry I'm not too knowledgeable on this swap. I was thinking of possibly doing the swap but don't have enough info. What has to be modified to swap them? If you have links that would be great. I've tried searching google but it doesn't give anything good.
Cdg2125 is offline
Old 03-17-2007, 08:47 PM
matty's Avatar
You use the 5th gen Coolant Log that is on the DEK.
-matt
matty is offline
Old 03-17-2007, 09:41 PM
Cdg2125's Avatar
thats it? just run the hose to the 5th gen log? What sensors need to be changed? crank sensor? Are the vac galleries needed? Can't you just vac source everything like the 00vi swap?
Cdg2125 is offline
Old 03-18-2007, 08:17 AM
RedfoxXx's Avatar
needed parts
1. vq30dek
2. IACV plate
3. RPM switch
sensors from de to dek
1. bell housing
2. cam position
3. throttle position sensor
4. coolant log sensor
extra work
1. jb weld swirl valves (maybe)
2. swap evap system (I have a 95 so I dont think i have evap)
3. rewire fuel injectors
stole this from another thread, matt plese let me know if this all sounds right
I plan on droppin this bad boy in over the summer
any thoughts on what the RMP switch does and such?
thanks so much!
RedfoxXx is offline
Old 03-18-2007, 09:21 AM
Cdg2125's Avatar
RPM switch is connected to the VI to make it open at designated rpm. Good find on the other info. I have all of that covered since I have the 00vi. Just would need to do the swirl valves.
Cdg2125 is offline
Old 03-20-2007, 11:33 AM
RedfoxXx's Avatar
the swirl valve is a must do!
I have read over this writeup and it did not talk about the RPM switches,
http://vqpower.com/gtrmax/00VI/
what is the best RPM switch to go for and how does it interface with the OBDII PC?
what is the disadvantage of using the neg side of a coil for timing?
Also I have read that people use the stock 4th GEN pc with the 00VI
Would it not have a tendency to run lean at high RPM when the secondary runners are open?
Dose the bigger injectors just compensate or dose a sensor pick up the slack?
RedfoxXx is offline
Old 03-24-2007, 01:54 PM
Create From Nothing
from what i've heard and seen people go with the Summit RPM Switch. if your using the 5th gen injectors get a/f controller so tha you don't run rich. it doesn't interface with the OBD it hooks up to the VIAS and the tach.
Also I have read that people use the stock 4th GEN pc with the 00VI Would it not have a tendency to run lean at high RPM when the secondary runners are open? Dose the bigger injectors just compensate or dose a sensor pick up the slack?
you won't run lean you will run rich. the DEK injectors are larger so the 4th gen ecu will push too much fuel to the chambers
Old 03-24-2007, 02:07 PM
matty's Avatar
I have my Charge pipe off right now...Do you guys want me to snap some pics of how I did it ??
-matt
matty is offline
Old 03-24-2007, 02:32 PM
Create From Nothing
please that would definitely help...and i have a couple of questions cause im curently stuck.
i'm working on putting everything back together which includes the egr, evap, and putting the 00vi back on top. im using a 4thgen LIM and fuel rail. here's my problem.
the 00vi has 8 screws that bolt down. stephenmax drilled the LIM that you sent him so the 4 middle holes fit perfectly, but what do I do about the 4 holes on the outside???
also the pipe from the evap has a sensor that runs from the IACV to the EGR intake pipe. how do I hook that up to the 5th gen egr pipe???
Old 03-24-2007, 04:24 PM
Cdg2125's Avatar
I drilled a hole in the UIM that lined up with the LIM hole and used nuts & bolts to tighten it down.
Cdg2125 is offline
Old 03-24-2007, 05:22 PM
matty's Avatar
You have to Drill out the Plastic on the 00VI for the two outer holes to be able to put a bolt through. What I did was secure the 5th Upper and the 4th gen lower with the center Bolts and then drill the outer. Be carefull so you leave enough meat on the plastic outer. Youll see what Im talking about when you do it. Do alittle at a time.
There is a thread in your New 5th gen Guide tube for the temp sensor
-matt
matty is offline
Old 03-24-2007, 05:29 PM
Create From Nothing
ok so would it be possible to leave the 00vi bolted to the LIM turn it upside down and drill from the bottom to the top???
Old 03-24-2007, 05:40 PM
matty's Avatar
No. Bolt it up and make a reference mark. You cant drill from the bottom because thats where the threads. I guess you can take a small bit and make a reference hole. Then just take it off and make it bigger... I put it together and took it apart about 10 times till i got it right.
-matt
matty is offline
Old 03-24-2007, 05:49 PM
Create From Nothing
-matt
ohhhhhhhhhhhhhhhh ok that makes sense. forgot about the threads...you still gonna take a pic of the vac lines when you get the chance
Old 03-24-2007, 06:07 PM
matty's Avatar
Yea im workin the overnight but ill be able to get a pic tomorrow afternoon
-matt
matty is offline
Old 03-24-2007, 06:11 PM
Create From Nothing
-matt
no rush when ever you can you definitely helping us all out
Old 03-26-2007, 07:46 PM
Create From Nothing
OK...I'm in the middle of putting everything back together while doing a DEK swap. here's my setup
00 upper manifold
00 throttle body
4th gen rail injectors
4th gen LIM (lower intake manifold)
4th gen IACV
I've hit a problem. the LIM is drilled so the the 4 middle bolts line up with no problem. but the 4 holes on the outside are not lining up
i've been told to drill the 00VI to line up with the LIM on the ends, but a nissan tech said that the 00VI is hollow at some points. does anyone know how safe it is to drill the 00VI, and which parts are hollow and parts aren't.
Old 04-14-2008, 04:26 PM
shadyonedeath's Avatar
bump on this question ^
shadyonedeath is offline
Old 04-14-2008, 06:16 PM
matty's Avatar
Well if you look at your second pic, one of those bolts arent used.
The OUTER LARGE TWO holes need to be drilled to line up. What I did was mounted it on the bench with the middle bolts tightened. Then drill alittle and slowly
-matt
matty is offline
Old 05-07-2008, 03:29 AM
Turbo 4th Gen
93altima's Avatar
I plan on doing this swap in the next week or so and i cant find any step by step swap write up or detailed pics i HAVE been searching i know what i need just dont have instructions please i need some help
93altima is offline
Old 05-07-2008, 12:43 PM
soseihin's Avatar
Did you read the stickies? How did you miss these?
http://forums.maxima.org/showthread.php?t=373884
http://forums.maxima.org/showthread.php?t=256788
http://forums.maxima.org/showthread.php?t=400691
soseihin is offline
Finkle
09-27-2015 09:53 PM
Slamrod
09-03-2015 07:38 PM
lowpost99
22
09-02-2015 04:38 PM
FlaMark
08-21-2015 11:06 AM
acw
08-07-2015 04:20 PM
Quick Reply: DEK swap - running the hoses
