Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 11-03-2007, 01:04 AM   #41
Maxima.org Sponsor
With all due modesty, I'll note that they seem to fit perfectly, we've really got this design down nicely. There have been well over 100 sets sold sold since December without any install issues.
Brian
__________________
Brian C Catts, Cattman Performance
Tucson, Arizona
520.575.6195 for ?s and 800.759.9920 to order
bcatts@cattman.com
www.cattman.com
Cattmobile FOR SALE: [pics here] 02 6M Maxima SE w/ CP intake, headers/y-pipe, FastCat, Catback, short shift kit, coilovers, FSTB, Progress RSB, NEW 245.45.18 Toyo Proxes4 tires on perfect 18x8 ROH DriftRs, 243whp, only 59k miles and never abused (true). Price reduced to $9999!
Cattman is offline   Reply With Quote
Old 11-03-2007, 05:55 PM   #42
I hate being slow
Send a message via AIM to BlackA32max
ok...i know there was a pair of headers mentioned from ebay going for 150 but these are the only ones i see on ebay http://cgi.ebay.com/ebaymotors/Compl...QQcmdZViewItem
does anybody know what brand these are? they're making claims but i see no dyno...and the "supposedly" fit i almost bought them a while ago..but then i got smart and saved up for bigger and better plans that i hope to carry out soon
__________________
Boost?!?!?!
BlackA32max is offline   Reply With Quote
Old 11-04-2007, 08:39 AM   #43
ShiftVQ35
well then i am the first that is having fitment issues. The actually headers fit like a glove. Instailling them was soo simple and easy. I will say install of the actually headers is way better then the hotshot. I had hotshot before and i had problems with them. Now my point is I am haing trouble with the y-pipe. the y-pipe doesn't match up with the headers. If i match up the front of the y-pipe to the front header, the back part of the y-pipe doesnt match with the rear header.And another thing is that it seems like the y-pipe is too long because it pushes my exhaust out and the tip sticks out past the bumper. also the exhaust is not centered in the tunnel. My car is a 96 with a vq35
Old 11-04-2007, 09:27 AM   #44
Gut it like a fish
accordingtou's Avatar
Quote:
I have the same issue with my cheapo ebay y-pipe.
The pipe is only temporary untill I get my custom y-pipie,but the headers are great
__________________
Stock & performance parts F/S@ PANTRY sale.lol Philly Pa
accordingtou is online now   Reply With Quote
Old 11-04-2007, 10:17 AM   #45
Maxima.org Sponsor
The issues you mention can be solved with proper installation technique.
Since there is room for movement where the manifolds bolt to the heads (bolt holes larger than bolts), the manifolds should be loose on the heads until the y-pipe is connected with both (tighten up the y-pipe first after using play in the bolt holes to align it properly), then bolt everything down, alternating from side to side as you tighten the bolts. The manifolds cannot be positioned exactly until they're both connected to the y-pipe.
The y-pipe dimensions are just like stock, give or take a quarter inch, so there should be no major change in exhaust position. You can make sure its properly aligned if you leave bolts loose until positioned properly and then tighten things down in the correct sequence.
I stand by my statement that these fit great - no heating, bending or cutting like you hear about other brands - but it's still a challenging installation and needs to be done right.
Brian
Brian C Catts
Cattman Performance
__________________
Tucson, Arizona
bcatts@cattman.com
www.cattman.com
Old 11-04-2007, 11:45 AM   #46
ShiftVQ35
Brain that does make sense but how do i know that the headers will be flat and tight when they are against the actually heads? I assumed that the best way was to do it like the way i did it because there wont be any leaks. Also when installing the rear header do you have to remove the bracket that is bolted to the block? The bracket holds the rear motor mount.
Old 11-07-2007, 11:22 AM   #47
Maxima.org Sponsor
If you follow the sequence I've suggested - which would be standard procedure with any header installation - once everything's bolted and torqued there will be a perfect seal at the headers, that's no concern. This won't correct a situation where there's truly a bad fit, but that's not the case here.
When you do it the way you did, you not only create a minor misalignment ( by "locking down" all the tightened joints in slightly incorrect positions as allowed by play in the bolt holes (instead of allowing everything to settle into natural positions), it's all focussed on a single flange-to-flange connection instead of being spread out over all the flanges. Hope that makes sense...
__________________
Tucson, Arizona
bcatts@cattman.com
www.cattman.com
Old 11-08-2007, 07:26 PM   #48
When will the next batch of headers be ready Brian? Also, do you offer a package price for the entire header back system?
__________________
v6guy is offline   Reply With Quote
Old 11-08-2007, 07:33 PM   #49
Maxima.org Sponsor
Quote:
As a matter of fact, they're in stock right at this moment. Give us a call at 520.575.6195 or 800.759.9920, open 9-5 MST.
We do offer a good package discount if you buy a full exhaust system, though I'll note that we're low on both 00-03 catbacks and FastCats right now (not out, but low).
Brian
__________________
Tucson, Arizona
bcatts@cattman.com
www.cattman.com
Old 11-21-2007, 02:28 AM   #50
Send a message via AIM to 00SEMAX19 Send a message via Yahoo to 00SEMAX19
So, now we have to be members of nycmaxima's to see the comparison. Makes sticky worthless unless everybody that wants to know about the review wants to sign up for a new thread.
00SEMAX19 is offline   Reply With Quote
Old 01-06-2008, 12:00 AM   #51
Exclamation joining nycmaximas
Quote:
I FIRST found this in the nycmax site... and EVERYONE mentioned it should be made a sticky in BOTH sites. Dunno whos dragging their feet on this one but they obviously are. Has anyone tested/reviewed the stillen headers some orgsters are asking about?
__________________
" The pursuit of happiness, one horsepower at a time "
RacerX1320 is offline   Reply With Quote
Old 01-07-2008, 11:46 AM   #52
Maxima.org Sponsor
I think the Stillen headers were reviewed pretty thoroughly when they came out a few years ago. I'll limit my comments to noting that they didn't fare too well in the critique.
Brian
__________________
Tucson, Arizona
bcatts@cattman.com
www.cattman.com
Old 02-18-2008, 09:47 PM   #53
Beast Mode!!!
Send a message via AIM to skuccio's max
Are you guys planning on releasing an equal length y-pipe to work with stock primaries? I want to get a y-pipe but hate the GM 3800 exhaust notes the unequal length setups give. I've heard the Cattman header setup and it sounds unlike any other setup for the Maxima...
__________________
skuccio's max is offline   Reply With Quote
Old 03-24-2008, 12:18 AM   #54
Hey Brian Do You have any 2k Maxima Headers available now and if you do What is the price for them
siege562 is offline   Reply With Quote
Old 03-24-2008, 02:41 PM   #55
Maxima.org Sponsor
I expect to receive more by the end of this week (today is Monday, 24 March). The price is $859.99 for the two manifolds, y-pipe and install kit.
Brian
__________________
Tucson, Arizona
bcatts@cattman.com
www.cattman.com
Old 10-28-2008, 04:02 AM   #56
i got ebay header's and y pipe they went on with no probleme and they do the job
fred86 is offline   Reply With Quote
Old 04-26-2009, 12:45 AM   #57
Hey Brian. I was wondering about the header/y pipe combo for my 03 maxima....do you ship to canada??
codester is offline   Reply With Quote
Old 05-05-2009, 05:32 PM   #58
Maxima.org Sponsor
Quote:
PM sent!
__________________
Tucson, Arizona
bcatts@cattman.com
www.cattman.com
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
