Torque specs for Rod Bolts??
Old 02-26-2007, 07:32 PM
Turbo is too much fun!
jcy98maxse's Avatar
Alrighty, just put in new APR rod bolts for the 3.5 but I have two torque spec one from ARP and the other from FSM.. which one should I go off of? They are relatively close but just wanna get an opinion. Thanks.
ARP: 28 ft-lbs 3 times
FSM: 14-15ft-lbs then 90-95 degree with a angle wrench
jcy98maxse is offline
Old 02-26-2007, 07:37 PM
95BLKMAX's Avatar
I would go with the specs from ARP. Its a different type of bolt with different capacities and tolerances, so ARP would know how to properly install their own bolts. I'd only follow the FSM in this case if I were using new OEM bolts, because then the procedure would apply, IMO
95BLKMAX is offline
nismology's Avatar
Use ARP's instructions. And use their lube exclusively, no oil.
nismology is offline
Old 02-26-2007, 08:16 PM
VQ Wizard
SR20DEN's Avatar
And try to get yourself a real torque wrench. Not a $20 clicky kind.
This is the one I have
SR20DEN is offline
Old 02-26-2007, 09:57 PM
jcy98maxse's Avatar
Already have them in, only used the lube that they provide. I only have a clicky wrench so I may have to buy a nicer one. I took pics so maybe i will post them sometime.
litch
123
01-04-2024 07:01 PM
hcarter1112
42
07-18-2022 03:35 PM
knight_yyz
11-01-2015 01:34 PM
RealityCheck
10-02-2015 06:34 PM
Quick Reply: Torque specs for Rod Bolts??
