Go Back   Maxima Forums > Advanced Performance > All Motor
Sign in using an external account
Register Forgot Password?
Register Photos Classifieds FAQ Timeslips Members Parts Guide Search Today's Posts Mark Forums Read ExperienceVendorsUsed CarsGarage TSB & Recalls
Search
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Search this Thread Display Modes
Old 01-19-2007, 07:05 PM   #1
Points: 11,510, Level: 70
Points: 11,510, Level: 70 Points: 11,510, Level: 70 Points: 11,510, Level: 70
Activity: 2.2%
Activity: 2.2% Activity: 2.2% Activity: 2.2%
Send a message via AIM to venompwr2
Engine removal
I'm pulling the engine out of my 95 max right now and am a bit of a tough spot. How are you guys getting access to the rear motor mount? Is it possible to unbolt it w/o removing the lower cross member under the engine or does that have to come out? Because I am not able to get at one of the bolts to remove both the shifter rods w/o that cross member being removed either. I'm only asking because one of the bolts on the cross member will NOT come out, I've shattered 2 sockets trying to remove it with an air gun, even after heating it up. Any tips here? As this is all thats holding me from progressing with my work.
Whats out so far:
Click the image to open in full size.
The cross member I cannot get out in case it wasnt clear
__________________
1999 Maxima Black on Black SE 5spd Supercharged
2006 Nissan Xterra
2008 Buell Lightning XB12Scg | 1980 HD Sportster XLH
venompwr2 is offline   Reply With Quote
Old 01-19-2007, 07:39 PM   #2
Helicopters! Money!!!
Weimar Ben's Avatar
Points: 10,748, Level: 68
Points: 10,748, Level: 68 Points: 10,748, Level: 68 Points: 10,748, Level: 68
Activity: 0.9%
Activity: 0.9% Activity: 0.9% Activity: 0.9%
Quote:
Whats out so far:
You don't need to remove the crossmember, but you will have to remove the shifter rods regardless. You don't have to remove the crossmember to remove the shifter rods. Simply use a 14mm box end wrench. It's a little slow that way since you can only turn the bolt like a 1/4 turn each time.
You should be able to access the rear mount from underneath the car or even up above. It's not terribly hard to get to, but it helps if you have a 1/2" socket wrench with a flexible head.
An air gun isn't going to loosen the crossmember bolts because they are bolted up agaist rubber and the rubber will absorb the hammer blows the airgun will give.
If you want to remove the crossmember, you will need a 24" breaker bar with a 1/2" 17mm socket. You may even heed to use a cheater bar in addition to that.
Weimar Ben is offline   Reply With Quote
Old 01-19-2007, 07:50 PM   #3
Activity: 2.2%
I'll give it another try tomorrow. I dont have small hands or arms so I have some trouble reaching into certain places with a wrench. I removed all of the bolts on teh crossmember except for 1 that doesnt want to come out, I even tried a breaker bar with a 60" pipe and it just shattered the socket. So I guess removing that is out, unless I grind down the bolt more. Thanks though!
__________________
2006 Nissan Xterra
Old 01-19-2007, 07:59 PM   #4
Maxima Owner
MaximaSE96's Avatar
Points: 12,923, Level: 74
Points: 12,923, Level: 74 Points: 12,923, Level: 74 Points: 12,923, Level: 74
Activity: 0%
Activity: 0% Activity: 0% Activity: 0%
Send a message via AIM to MaximaSE96
must i come over to save u again...i dunno what i got going on tomorrow but if i can ill stop by with some more fun tools
MaximaSE96 is offline   Reply With Quote
Old 01-19-2007, 08:41 PM   #5
Activity: 2.2%
Quote:
All set! I was able to undo the mount from the engine from the side, and then was able to remove the cross member and then removed the shifter rods. I suppose its possible to unbolt the shift rods w/ the cross member there but I was not able to get a wrench on there very well with the way its angled. Anywho thanks for the tip and now I can pull the motor out and get started with the fun stuff.
__________________
2006 Nissan Xterra
Old 01-20-2007, 04:36 PM   #6
Maxima Owner
MaximaSE96's Avatar
Activity: 0%
yaaaaaaaaaaaaaayyyyyy...sorry i was busy all day today...damn wedding plans
MaximaOrg
Nissan Maxima
Paid Advertisement
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
Emails Backup
Search Engine Optimization by vBSEO 3.5.2
