Did the Z IM make power over the stocker?
Hello,
Seems like I've seen a dyno for this but can't find it now. Did the Z intake manifold make any power over the stock FWD 3.5L intake manifold or has nobody tested it yet?
Thanks,
Fred
Thanks,
Fred
Here it is:
http://forums.maxima.org/showthread.php?t=475915
Originally Posted by meximax
Highlights:
-FWD IM makes 25 ft/lb of torque more than Z33 (no spacer) @ 3500 rpm
-FWD IM makes 17 ft/lb of torque more than Z33 (no spacer) @ 4300 rpm
-FWD IM makes 20 hp more than Z33 (no spacer) @ 6900 rpm
-Z33 makes ~18 hp more during the VI change point @ 5800 rpm
Originally Posted by scrhale
I am pretty sure it lost power due to the lack of exhaust VTCs
Maybe you mean intake VTCs. AFAIK only Vasily and myself have 3.5 swaps with Z33 IMs and functioning intake VTCs.
I am not aware of any A33B owners that have installed Z33 IMs.
Originally Posted by Fred Allen Burge
How much have you two dyno'd at or have you yet?
Thanks,
Fred
Thanks,
Fred
I am doing a lot of flow testing and material removal inside my Z33 IM right now. I am hoping to be finished before the snow flies so I can dyno it.
I only plan to dyno once so I want to have everything optimal before I go. It may have to wait until the spring.
Originally Posted by eng92
Vasily has dynoed. It was nothing spectacular but he was lacking headers and any sort of tuning at the time.
http://forums.maxima.org/showthread.php?t=466571
I see, are you using an aftermarket spacer as well? The seem to be the hot ticket for the Z guys.
Fred
Fred
I am concentrating on equalizing the pressure drops between cylinders for a given flow. They are horribly out of whack in stock form (close to 50% variation) I have dropped it considerably without messing with the runner lengths too much. If I cannot get it to where I am satisfied, then I will get a spacer.
Originally Posted by vq354thgen
225 whp and 240 tq is nothing spectacular for a bone stock maxima? i can only imagine what happens when headers and tuning come into play.
stock 2k2 6spds put down 205whp....he made 225whp....so those 3 mods gave him 20whp....throw in some cattman headers and a test pipe...with air fuel tuning...he'll be in the 250whp range...
I didn't dyno or have VTC's but I am comparing my car before/after the Z33 IM.
Stock 2k2 IM vs. Z33 IM, I seemed to average better quarter mile times on the Z33 with worse conditions. But then again the "after" setup had HS headers instead of stock headers and a y-pipe as well. I also beat my previous trap by 2 mph, and ran 2 tenths faster with a 1 tenth slower 60ft.
My best 1/4 times have come from the stock 2k2 IM, I have a higher trap with the modified IM ie 111 vs 108 but my best et is from the stock IM. The totally modified 350Z IM ie spacer etc etc was in the middle, waste of money unless you are running cam timing and then I am not sure of the results.
lowpost99
05-16-2021 11:18 AM
trungg86
09-04-2015 04:58 AM
