00vi gasket
Old 07-24-2006, 07:40 AM
devast8's Avatar
00vi gasket
I'm trying to peice up everything I need in order to start my 00vi swap and I have one question. Do I only have to use the 00 IM gasket for my 00vi swap? And do I need any other gasket?
Thanks for the help
devast8 is offline
Old 07-24-2006, 08:48 AM
maximaSE327's Avatar
you need one gasket part #14033-2Y901, and you need 2 IM gaskets part #14035-38U01
thats what you need for gaskets for the manifolds... you will also need gaskets for the egr system as well but they are cheap, couple bucks, if you didnt get all of that already when you bought the egr guide tube... hope that helps
maximaSE327 is offline
Old 07-24-2006, 09:41 AM
Bacon Lover
Tatanko's Avatar
I plan on re-using a good many of my gaskets, but you're saying 3 different gaskets are needed for the two intake manifolds? Like one lower -> heads and two upper -> lower? What would I need assuming I was using my 4th gen lower and the 00VI upper?
Tatanko is offline
Old 07-24-2006, 10:07 AM
I like Maximas
vipervadim's Avatar
good luck, and customization skills
hope you got a metric tap at least, lol
vipervadim is offline
Old 07-24-2006, 10:23 AM
devast8's Avatar
thanks!!
you don't have the egr gaskets part number by any chance?
devast8 is offline
Old 07-24-2006, 10:32 AM
3.5 in the works
DandyMax's Avatar
You likely don't need to replace the 2 gaskets b/w the lower manifold and the heads. They are metal and usually still in good shape (unless for some reason yours aren't).
DandyMax is offline
Old 07-24-2006, 10:35 AM
this is true... the part numbers i gave were assuming you were using the 00vi w/ the 5th gen lower
Old 07-24-2006, 10:38 AM
Originally Posted by devast8
thanks!!
u need 4 things total w/ the new egr set up... the egr guide tube, another metal tube and 2 gaskets:
part #s: 14713-2Y900, 14722-38U02, 14722-2Y000, 14719-W7001
the guide tube is around $25 and the other 3 peices are about $2-3 each
Old 07-24-2006, 10:56 AM
3.5 in the works
DandyMax's Avatar
Same scenario.
DandyMax is offline
Old 07-24-2006, 11:05 AM
Curt's Avatar
Some time back there was a guy on the org (overseas somewhere IIRC) doing the 00VI swap, and he was trying to use both the 4th gen & 5th gen gaskets between the UIM & LIM. Absolutely a NO NO! Whichever LIM you use, use just the 5th gen (00VI) gasket.
Curt is offline
Old 07-24-2006, 11:07 AM
3.5 in the works
DandyMax's Avatar
Why would you use both?
DandyMax is offline
Old 07-24-2006, 11:18 AM
Bacon Lover
Tatanko's Avatar
So I just need to pick up a 5th gen upper -> lower gasket and I SHOULD be ok? I hope so...I'd hate for this to get even more complicated
Tatanko is offline
Old 07-24-2006, 12:20 PM
devast8's Avatar
maximaSE327, you're a god among men!
thanks!!
devast8 is offline
Old 07-24-2006, 02:22 PM
haha not a problem... i had all the same questions not too long ago... i just did the swap last weekend... im glad i could help
knight_yyz
11-01-2015 01:34 PM
Gingerheadman
10-01-2015 05:11 PM
lrb6805
09-30-2015 08:12 AM
Socalstillen
09-20-2015 11:46 PM
Quick Reply: 00vi gasket
