Using heads from other VQ35s
Old 04-02-2006, 02:51 PM
sciff5's Avatar
Hey guys this may be a stupid question but if you have a VQ35 is there any reason why you wouldent be able to use freer flowing heads made for the G35 or 350z if you also use the 350z plenum?
sciff5 is offline
Old 04-02-2006, 03:04 PM
Glude's Avatar
I believe anyone with a 3.5 could use the heads from the 6th gen which people say are the heads from the pathfinder.
Glude is offline
Old 04-02-2006, 03:10 PM
VQ Wizard
SR20DEN's Avatar
You assume they are.
SR20DEN is offline
Old 04-02-2006, 03:41 PM
Custom User Title
Nismo3112's Avatar
You could.. But why would you want to?
Same part numbers.
5.5 gen VQ35's, 350Z = same part numbers
6 gen = different part number
R50 PF VQ35 = different part numbers from the two above.
Nismo3112 is offline
Old 04-02-2006, 07:25 PM
vsamoylov
nismo heads
Old 04-02-2006, 07:41 PM
Glude's Avatar
Originally Posted by vsamoylov
nismo heads
Extremely expensive if I remember correctly, right??
Glude is offline
Old 04-02-2006, 08:04 PM
Custom User Title
Nismo3112's Avatar
Anything Nismo = expensive lol.
Old 10-19-2007, 10:15 AM
coinage's Avatar
sorry to bring up an old thread but what are the difference between the 5.5gen and the 6th gen heads? i read something about softer valve springs... would it be a good idea to swap in the springs from my 02 onto the newer heads if i want to cam the motor?
Matt
coinage is offline
Old 10-19-2007, 10:25 AM
dot dot dot ...
NmexMAX's Avatar
If I was going to toss cams in, I would use JWT VS's.
NmexMAX is offline
Old 10-19-2007, 10:39 AM
coinage's Avatar
any other differences?
coinage is offline
Old 10-19-2007, 10:45 AM
dot dot dot ...
NmexMAX's Avatar
The only difference in A34 heads vs A33B heads is the VS's. No other differences exist. So, having said that, flow characteristics are not affected by that small difference.
NmexMAX is offline
Old 10-19-2007, 11:08 AM
coinage's Avatar
cool... thanks that all i needed to know
coinage is offline
Old 10-19-2007, 11:13 AM
3.5 in the works
DandyMax's Avatar
Even better, I'd use double shimmed HR springs, and HR retainers. And way cheaper too.
Wait, I already did that... with a heavier DEK valvetrain that still revs to 8k+ no problem.
DandyMax is offline
Old 10-19-2007, 11:16 AM
dot dot dot ...
NmexMAX's Avatar
Originally Posted by DandyMax
I'd use double shimmed HR springs, and HR retainers. Wait, I already did...
. . . . I was hoping you’d chime in with that because I didn’t feel like searching high and low for that post. But yes, my actual point was ‘I would not use A34 springs’.
NmexMAX is offline
Old 10-19-2007, 11:37 AM
nismology's Avatar
Any particular advantage to using the HR/Revup retainers for his purposes? Just looks like they have a bit more mass on them according to SR20's images.
nismology is offline
Old 10-19-2007, 12:16 PM
3.5 in the works
DandyMax's Avatar
They do look a little stronger. And they're dirt cheap.
I don't recall off the top of my head what the HR retainer weight was (I can check my notes at home later), but I *think* they might have been about .75-1 gram lighter than the non-revup, and they're definitely several grams lighter than the DE/DEK.
DandyMax is offline
Old 10-19-2007, 02:11 PM
KRRZ350's Avatar
& IINM they're NOT titanium FTW, or am I wrong here?
KRRZ350 is offline
Old 10-19-2007, 02:51 PM
nismology's Avatar
Figured that much. I've had DaveB price 'em out for me. Was just wondering if it would be worth the expense (albeit small) for his setup is all.
Please do check again because that would be nuts if they were actually lighter. Looked like they had more meat on them.
Old 10-19-2007, 06:01 PM
3.5 in the works
DandyMax's Avatar
If you're in there changing springs anyways...
Well I checked and I was mistaken (darn lousy memory). They're about the same, or slightly heavier by a few tenths of a gram, which does make sense.
DandyMax is offline
Old 10-19-2007, 09:54 PM
sciff5's Avatar
So even if we used the HR Valve springs in our Vq35s and were able to raise the rev limit to 7500 or so, would the heads/ intake be able to support power at those levels?
sciff5 is offline
mclasser
22
11-12-2020 01:58 PM
knight_yyz
11-01-2015 01:34 PM
worldwiderecognized
09-30-2015 01:16 PM
jaydot901
09-29-2015 01:18 PM
Quick Reply: Using heads from other VQ35s
