Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-12-2006, 10:36 PM   #1
VQ Wizard
Send a message via AIM to SR20DEN
VAFC-II setup template
It has come to my attention that some people could use a little extra help when setting up the VAFC-II for the Maxima. Many are following my recommendations for getting it over the SAFC-II, which I find encouraging, but I suppose I need to clarify more of the details.
The reasoning for getting the V over the S really has nothing to do with it's 'vtec control' or in our case 'rpm switch'. That part isn't a direct wire setup anyway. And it certainly would have nothing to do with attempting to control the VTCs on the VQ35, as some mistakenly suspect.
It's really all about the NE points for setting up the fuel corrections. The SAFC-II has a twelve point by two point map (12x2) which means you can setup 12 rpm points throughout the rev range and 2 throttle points for correction. Anything in between your specified RPM and throttle points is interpolated . The SAFC-II can also be manually switched to a second data file or map to be used with Nitrous or some other more or less aggressive tuning parameters you might need.
The VAFC-II essentially uses both of these 12x2 maps together, effectively making it a 24x2. But it has to be triggered to select between these two maps by a Hvt and Lvt setting (12x2 high vtec, 12x2 low vtec).
Now for the example setups:
So for most of these cars that can only rev to 6500 or 6600, we would set the Lvt to Hvt setting at 4200rpm and the Hvt to Lvt at 4100 (for some reason it wont let you make them the same). Doing this means that the VAFC-II will switch over from one 12 point map to the other 12 point map at 4200rpm. Now you'll need to setup the Lvt NE (RPM) points, obviously you'll want to end the Lvt points at or before 4200rpm because that is where you just set the crossover. If you set Lvt points past your crossover point they just go to waste and you won't make use of the full 24. A good selection would look something like this:
Lvt 1200,1600,2000,2400,2600,2800,3000,3200,3400,3600, 3800,4000
Hvt 4200,4400,4600,4800,5000,5200,5400,5600,5800,6000, 6200,6400
If you have some A/F problems at the crossover point you may need to adjust those settings. I don't think the VAFC-II will interpolate between the Hvt and Lvt maps.
Notice I have listed settings as low as 1200rpm, this isn't really usefull to everyone but those with larger MAF sensors or larger injectors can make use of the low rpm/low throttle settings to keep the ECU fuel trims in check (they really need to be as close to zero as possible).
As for the wiring setup, keep in mind that the VAFC-II only has settings for MAP sensors, but it still needs to be wired to your vehicles MAF sensor. And for display purposes I generally use the setting of +15psi, which does not give by any means an accurate display of air mass flow or MAF voltage, it does somewhat put the MAF output into some discernible perspective. It's also cool to show off to your friends, and those who think you have forced induction anyway.
I realize there is still much left out here but I'll try to answer the questions as they arise. I don't have a VAFC-II to look at, so I am having to do this from memory.
SR20DEN is offline   Reply With Quote
Old 03-12-2006, 10:43 PM   #2
Need A Light?
steven88's Avatar
Send a message via AIM to steven88
Just letting you know...I'm running the following INITIAL SETUP settings
1 in & 1 out, 6 cylinder, up right arrow, vtec type 1
no problems so far...anybody else running diff settings?
steven88 is offline   Reply With Quote
Old 03-12-2006, 10:45 PM   #3
Custom User Title
Nice writeup. It definitely answered my questions about the VAFCII.
Motion for sticky
Nismo3112 is offline   Reply With Quote
Old 03-12-2006, 10:46 PM   #4
Custom User Title
Yeah, what do these settings mean anyways? (besides the V6 part)
Old 03-12-2006, 10:52 PM   #5
Need A Light?
steven88's Avatar
I really don't know...well I know the up-right arrow means something about the TPS voltage...u can test it out manually to see where your at...but from what I know, all maximas have this same voltage...so u pick the up right arrow...
dunno too much about the 1 in and 1 out....and vtec type
Old 03-13-2006, 12:13 AM   #6
want to wire either a vafc or safc to the sunglass holder...will the wiring for a vafcII reach there? i know they safcII is about 7 feet long...how long do you think the wiring is for the vafc..you think the wiring can be easily made longer
__________________
FTSB,Progress RSB,H&R Springs,Illuminas,Courtesy Nissan Grounding Kit,Injen Cold Air Intake, G35 coupe Rims,clear corners,HPautoworks STS 6speed..
rchun08 is offline   Reply With Quote
Old 03-13-2006, 12:19 AM   #7
Need A Light?
steven88's Avatar
when I measured my VAFCII....it barely reaches the sunglass holder...but I didn't completely stretch out the wires...I'm sure it would reach if you tried hard enough....
others say it won't reach...but this is from MY personal experience with MY VAFCII....take your pick
Old 03-13-2006, 06:12 AM   #8
VQ Wizard
The last two installations I dealt with would not reach.
Old 03-13-2006, 11:09 AM   #9
Old enuf to pick his own gears
d00df00d's Avatar
Send a message via AIM to d00df00d
Quote:
Originally Posted by Nismo3112
Motion for sticky
I second that motion, especially if even more info is to come.
__________________
SHIFT_yourowndamnself
Quote:
Originally Posted by BlackBIRDVQ
M3- doesnt have anything OVER a Maxima.
Click here and buy my stuff.
d00df00d is offline   Reply With Quote
Old 03-13-2006, 01:05 PM   #10
ok...glovebox it is!!
__________________
Old 03-13-2006, 03:56 PM   #11
Nissan maniaco conpulsif
hightuner's Avatar
Thanks you
hightuner is offline   Reply With Quote
Old 03-14-2006, 03:51 PM   #12
vsamoylov
interesting info
Old 03-15-2006, 02:22 AM   #13
mjk
Head shot!!!
Send a message via AIM to mjk
I will definately be posting once mine arrives. thanks for the effort man
sticky sticky sticky
mjk is offline   Reply With Quote
Old 03-15-2006, 08:59 AM   #14
Play with my balls
Deckdout2's Avatar
Send a message via AIM to Deckdout2
I have Haydn's manual still if you wanna look at it for more info Matt, or you can play around with mine for the other functions and features.
Here's where mine is mounted. Perfect, and I can still see the clock.
Deckdout2 is offline   Reply With Quote
Old 03-15-2006, 07:48 PM   #15
Send a message via AIM to jmeister Send a message via MSN to jmeister Send a message via Yahoo to jmeister
The in & out settings have to match & that's as much as I know about those. Have mine set at 4. On the VAFCII the vtec type should be set at med to use it as an RPM switch for the VIS. The VAFC will not actuate the VIS, known from personal headaches & wasted $... VAFCII on the way
Nice write up, where were you last year about this time
Here's where I mounted mine
jmeister is offline   Reply With Quote
Old 03-16-2006, 11:36 AM   #16
mjk
Head shot!!!
Do we just wire it up per the instruction booklet, I'm asking because all I saw was a bunch of honda examples. thanks
Old 03-19-2006, 07:00 PM   #17
So I'm a little confused. Maybe I just missed it somewhere. How exactly does this work with a MAF sensor if its made for a MAP sensor?? Like, how does it measure how much air is comming in?
__________________
Yes I am 17. And no, I do not like The Fast And The Furious. . I despise shopping cart wings and Honduhs that sound like a pissed off herd of wasps. And I'm no idiot! Treat me like you treat any other member.
NashCar is offline   Reply With Quote
Old 03-19-2006, 07:19 PM   #18
VQ Wizard
Quote:
It knows nothing about air. All it sees is an input voltage which it translates to a different voltage based on your settings per thottle (voltage) and RPM (frequency).
Old 03-24-2006, 02:42 PM   #19
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Got mine finally installed and set it up as per the info in this thread
My install thoughts/comments are here:
http://forums.maxima.org/showthread.php?t=463709
Puppetmaster is offline   Reply With Quote
Old 03-24-2006, 03:11 PM   #20
Custom User Title
Quote:
[IMG]http://i11.photobucket.com/albums/a190/Puppetmaster1/VAFCII/DSCN4427.jpg[IMG]
That knob doesnt double as a shift light does it?
Old 03-24-2006, 04:24 PM   #21
If you don't wanna use 12 of the fuel correction points then yes
Old 03-24-2006, 11:36 PM   #22
Old Maxima Legend
Ceasars Chariot's Avatar
Send a message via AIM to Ceasars Chariot Send a message via MSN to Ceasars Chariot Send a message via Yahoo to Ceasars Chariot
great work SR !
__________________
N/A - 97 SE - VQ30DE - 93 octane
13.8 @ 98x - 2.06 60' - USIM
13.5 @ 101 - 2.10 60' - OOVI/EU
N/A - 97 SE - VQ30DE-K Swap
TBA
Ceasars Chariot is offline   Reply With Quote
Old 03-27-2006, 06:04 PM   #23
VQ Wizard
Here is the wiring template I started working on.
http://vq35de.com:2002/A33x_ECM.pdf
Look it over and offer suggestions or requests.
Old 03-28-2006, 12:43 AM   #24
mjk
Head shot!!!
good job man, makes me wanna start on this, otherwise I was scared
Old 03-29-2006, 12:44 PM   #25
But why is teh Rum gone?
rbrown81's Avatar
Send a message via AIM to rbrown81
Man its going to be painful to the wallet when I get that reflash and the VAFC... but fun
__________________
Catt Gen2 Headers/Res/B-Pipe | Franken Rear | Berk Intake/Apexi | 17" Timing | UR UDP | Watkins Short Shift | Generic Ground | ES Motor Mounts | H&R | Illuminas | ES Bushings |Otto FSTB | Progress RSB | Eagle F1 245/40/18 | OZ Ultraleggera 18x8 | Powerslots | HPS | Goodrich SS Brake Lines | Hella Supertones | Red Intake Cover | Clear sides | Maglite Mod
Soon : VAFC | Brakes | Intake Manifold
rbrown81 is offline   Reply With Quote
Old 04-01-2006, 02:56 PM   #26
El Mas Noob Del Org.
vq356sp's Avatar
Send a message via Yahoo to vq356sp
Just got my safcII working yesterday. Here is some pics of where it is mounted. I have to say thanks to all above for all the good info on here it sure helped.
vq356sp is offline   Reply With Quote
Old 05-22-2006, 10:10 PM   #27
aznsap's Avatar
Send a message via AIM to aznsap
i thought that open loop didn't come into effect until 3000 rpm? does that mean we can start the Lvt @ 3000 rpm and go up to redline in smaller increments?
__________________
FOR SALE (pics): 4g upper and lower IM, 4g IACV, white (qno) hood, '95 TCM, oem crank pulley and belts, auto gear select indicator and shift mechanism
aznsap is offline   Reply With Quote
Old 05-22-2006, 11:04 PM   #28
Need A Light?
steven88's Avatar
Quote:
yes you could start at 3000 and go in smaller increments...the way sr20den sets his up is becuz he has larger injectors and a larger MAF....if you are stock, then you wouldn't really need to modify the low RPM/low throttle settings...
if you have simple bolt ons, starting at 3k would be just fine as well
Old 05-23-2006, 02:26 AM   #29
Send a message via AIM to diymaximakid
wait a sec.what vtec type does it need to be on in order for vias to work.
diymaximakid is offline   Reply With Quote
Old 05-23-2006, 03:05 AM   #30
Need A Light?
steven88's Avatar
Quote:
just use the vtec type 1...i'm using it and have no problems...
Old 05-23-2006, 06:43 AM   #31
1 in and 1 out i think it means the sensor type. sometimes u need to change this if you change of sensor (i think)
virgilio7 is offline   Reply With Quote
Old 05-23-2006, 11:39 AM   #32
Need A Light?
steven88's Avatar
My Settings are....
1 in and 1 out, 6 cylinder, arrow pointing "up right", and vtec type 1
sup virgillio...hows the kinetix coming along btw?
Old 05-23-2006, 01:57 PM   #33
aznsap's Avatar
thanks steven88 for the prompt reply
Old 05-23-2006, 01:58 PM   #34
mine are 4 in 4 out, northeastern arrow, vtec type 1.no problems what so ever.
Old 05-23-2006, 02:21 PM   #35
Need A Light?
steven88's Avatar
does anyone know what the sensor in and sensor out feature do? i remember reading the owners manual, but it doesn't give u an explaination for why
Old 05-24-2006, 08:34 AM   #36
kinetix can suck the big one. they are going to experience bull**** when nobody buys it. sorry for the threadjack
Old 05-24-2006, 11:07 AM   #37
its the type of sensor for the maf/map. i'm looking to see if i can find a list
Old 05-24-2006, 12:10 PM   #38
the safc2 manual has a list (i think). it showed an example like if you install a z32 maf you might need to change it from 1 to 1 => 2 to 1.
Old 06-02-2006, 12:06 PM   #39
what is everyone using for the throttle point settings?also is this the low and hi for the narrow and wide correction settings?
Old 06-07-2006, 07:31 PM   #40
aznsap's Avatar
where have you 4th gen guys put these? i'm wondering where people install these. in the glove box? on the dash somewhere?
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
