VQ35 300hp RevUp cams for <$600!!!!
Old 02-23-2006, 07:58 AM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
Someone needs to buy an exhaust cam and compare it to know 100% for sure, but DAVEB says from what he can tell in his diagrams the exhaust VTC doesn't seem to have changed anything on the head side of the cams. Looking at the dynos, these definitely lose some torque, but make it up on the top-end.
Specs:
RevUp VQ35 248-degrees duration 10.5mm lift(Per SR20DEN)
JWT VQ30 256-degrees duration 10.54mm lift
JWT VQ35 260-degrees duration 10.87mm lift(INT cam 2-degrees advanced)
Any PIONEERS out there?
IceY2K1 is offline
Old 02-23-2006, 08:54 AM
vsamoylov
$600 just for exhaust cams?
Old 02-23-2006, 09:06 AM
IceY2K1's Avatar
No, for all 4.
DAVEB said $500 and change...not sure how much change.
IceY2K1 is offline
Old 02-23-2006, 09:12 AM
IceY2K1's Avatar
I know he said it was ~$125 for each intake cam, so I'd assume about that for the exhaust cam.
In short, someone with a non-RevUP VQ35 exhaust cam would need to take the risk of ordering a single exhaust cam for $125 or so and compare them to make sure Nissan didn't change the length, end design, or whatever so it could be put in the 95-2003 heads.
IceY2K1 is offline
Old 02-23-2006, 09:14 AM
vsamoylov
and anybody have specs on the nismo cams?
Old 02-23-2006, 09:16 AM
I'm needing a caw
Jeff92se's Avatar
Looks like the shorter duration of the Rev up cams might retain more torque than the JWT versions. Expecially when the Rev Up's lift is the shortest of them all
Jeff92se is offline
Old 02-23-2006, 09:19 AM
IceY2K1's Avatar
I know this is the NA forum, but I think they're absolutely PERFECT for the FI crowd, since they don't have overlap.
Plus, for the price, you'd have to go with some no name generic off ebay.
IceY2K1 is offline
Old 02-23-2006, 09:22 AM
IceY2K1's Avatar
Rumor has it that the Nismo USA cams were made by JWT, but are slightly more aggressive IIRC. Nobody has tried the Nismo Japan cams that weren't made by JWT.
Again, just rumors on the 350Z board and I don't keep up too much over there, so I could be wrong.
IceY2K1 is offline
Old 02-23-2006, 09:37 AM
chris'smax's Avatar
i think i remember reading somewhere that people w/ the rev up motor could not use the after market cam options for the 350z due to the exhaust cams being different. I think it said something about a sensor for the exhaust cams
chris'smax is offline
Old 02-23-2006, 09:48 AM
IceY2K1's Avatar
True, but that's because of the VTC pulley/cam sprocket end.
A spacer and VQ30 sprocket might work.
IceY2K1 is offline
Old 02-23-2006, 09:58 AM
IceY2K1's Avatar
262-degree duration and 10.82mm lift
http://performancenissanparts.com/ca...products_id=49
IceY2K1 is offline
Old 02-23-2006, 10:08 AM
IceY2K1's Avatar
Per this...sounds like the exhaust cam needs a bit of a haircut to work on 287hp VQ35s, but since we have to ADD a spacer to work with the VQ30 timing equipment...MAYBE we just need a smaller spacer????
Originally Posted by ALong
Jason, the Rev-Up cams actually will work in the non-Rev motors, that is what we will be using in our T2 race motor. Because the Exhaust cams have CVVT on the Rev-Up motor, the ends of the exhaust cams need to be machined to fit the non-rev motor, but its not a real big deal.
Where are you getting information on the parts used in the Super Taikyu cars?
Jason, the exhaust cams for Revup are different in that the end of the cam is set up to have the CVVT gear on them (just like the intake cam). From what I understand the cam is slightly longer so to fit the non-rev head, the end just needs machined off so that its the same length as the standard cam. Fairly easy job at a competent machine shop.
Dont want to get in the middle of this debate on the lower plenum, but I do know that to take full advantage of the plenum on the non-rev motors, you really need the Rev-up cams. Several other T2 racers have installed the lower plenum on the non-rev motors (but without the cams) and did not see any noticable difference on lap times or driveability.
Do you have a source for Super Taikyu spec parts?
IceY2K1 is offline
Old 02-23-2006, 10:10 AM
IceY2K1's Avatar
Also, this place has the exhaust cams a bit cheaper then the intake cams:
http://www.performancenissanparts.co...&Submit=Search
IceY2K1 is offline
mclasser
22
11-12-2020 01:58 PM
gustavison
10-04-2015 06:50 PM
soybeanz
09-25-2015 10:46 AM
Quick Reply: VQ35 300hp RevUp cams for <$600!!!!
