Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 10-08-2005, 04:26 PM   #1
You can't friend yourself
Kevlo911's Avatar
5 Speed Parts List
Part - Part Number - Price
5th Gen Clutch - 301002Y904 - 75.55
5th Gen Pressure Plate - 3021089F00 - 82.06
Clutch Release Bearing - 3050241U20 - 24.50
Support Rod - 34550-40U00 - 42.74
Control Rod - 34103-40U00 - 72.52
Hole Cover - 74965-0E510 - 8.87
Hole Boot - 74960-0E500 - 3.59
Hole Bracket - 34560-70N00 - 13.61
Socket Assembly - 34553-50J00 - 13.03
Lever Bearing - 34116-50J00 - 4.50
Bearing Seat - 34118-50J00 - 5.08
Lever Boot - 34122-50J00 - 5.08
Return Spring - 34573-40U00 - 4.28
Clutch Pedal Assembly - 46540-40U00 - 36.20
Brake Pedal Assembly - 46501-40U05 - 55.64
Master Cylinder - 3061031U17 - 71.93
H- Connector To Flex Hose - 3085140U00 - 10.22
H- Flex Hose, w/Bracket - 30855-31U12 - 35.42
H-Master Cyl To Connector - 10.22
Slave Cylinder - 3062031U61 - 38.24
Flywheel - 123102Y910 - 182.29
Front Engine Mount - 1127040U03 - 68.16
Tranny Mount - 1122040U12 - 60.28
B&M Shifter - 115.00
AE Shift Knob - 32865-4Y910 - 48.97
Drivers Side Axle - 88.79
What am I missing. What do I do about the bolts and nuts I need?
Kevlo911 is offline   Reply With Quote
Old 10-08-2005, 04:44 PM   #2
Kevlo911's Avatar
I know I am missing the Center console trim peice(wood grain)
http://www.drivetrain.com/nissanRS5F50Afwd5sp.html
How is that for a rebuilt kit? What about hte synchros
__________________
97 Pearl White Max GLE
I has car
LED tails for sale for 97-99 as well:
http://forums.maxima.org/4th-generat...-interest.html
Old 10-09-2005, 11:37 AM   #3
Kevlo911's Avatar
Quote:
Originally Posted by s0ber
blah i just formatted and lost nissan FAST, gotta install it again, but from what I see, you're missing the clutch pedal bracket
Where are the pedals on FAST?
Old 10-09-2005, 01:12 PM   #4
Kevlo911's Avatar
Clutch Pedal Bracket Assembly - 46550-40U00 - 43.06
__________________
I has car
Old 10-09-2005, 04:34 PM   #5
not sure, i was wondering what to do, im prolly just gonna make a big list in FAST for all the bolts I will NEED from nissan (Flywheel bolts n stuff) and just order them all together, and whatever im missing, a few trips to the hardware stores/local dealers during the install... best I can do unless I Can find a 5spd car down here at a junkyard (Rare)
__________________
SouthFloridaMaximas.Com
s0ber is offline   Reply With Quote
Old 10-09-2005, 05:13 PM   #6
Kevlo911's Avatar
Does anyone know if I can use a 5th gen donar car most of these parts?
__________________
I has car
Old 10-09-2005, 08:46 PM   #7
Armed and Dangerous
i30ds's Avatar
posted some part numbers for some bolts and stuff in my 5spd thread.
i30ds is offline   Reply With Quote
Old 10-12-2005, 11:40 AM   #8
Custom User Title
Quote:
Out of a 5th gen, the clutch master, and clutch pedal won't work. Everything else should.
Nismo3112 is offline   Reply With Quote
Old 10-12-2005, 02:13 PM   #9
Kevlo911's Avatar
Quote:
Even the shift rods/control rods?
Old 10-12-2005, 02:30 PM   #10
Custom User Title
shift rod and control rod will work. We installed 5th gen ones in my buddie's 95.
Old 11-07-2005, 11:07 PM   #11
aznsap's Avatar
Send a message via AIM to aznsap
yup, it was done on my '95 actually. you can pretty much use the same parts, except the clutch pedal bracket is different. you can use the clutch master cylinder if you want, but you have to change the pushrod w/ the 'C' shaped bracket on it (the part that the pin goes through to connect it to the clutch pedal). it's longer in the 5th gens than the 4th gens, so if you happen to get a 5th gen donor car, it's like a $10 part instead of gettin a whole new master cylinder.
shift rods/control rods worked out well for me, i have a courtesynissan STS (which is pretty much the same as the b&M) and the shifter is not even close to hitting the trim in any gear (i heard some ppl have problems w/ this before)
aznsap is offline   Reply With Quote
Old 12-03-2005, 11:43 PM   #12
Help me please, car goes into shop tomorrow
I was just rechecking the instructions site below (vqpower.com) and now the parts list mentions a 5speed starter?? is this true or will my Auto starter work fine?
http://www.vqpower.com/v2/modules.ph...howpage&pid=30
Parts Needed:
5spd tranny (try and get the I30 LSD or Canadian Maxima LSD if possible – doubt it)
Both Manual drive shafts (if you have ABS you need specific ones, if you don't have ABS you can use ABS ones)
1 clutch kit (clutch disc, pressure plate, throw out bearing)
2 shifting rods (support rod + control rod) (acquire used w/ all the hardware)
Return spring (connect to the 2 shifting rods (Buy this new, the stiffer the tighter your shifter feels)
1 5spd starter
1 shifter (Acquire used to get nuts and bolts (buy with the shifter rods)
1 shifter console piece (interior)
1 shift consul bracket (Replaces your auto one) (interior) (dealer name plate bolt and transaxle hole cover)
1 brake pedal
1 clutch pedal
1 master cylinder
Hydraulic lines for clutch
1 slave cylinder for clutch
1 extra set of tranny harnesses (might come w/ 5spd tranny)
1 18ga wire and wiretaps
Assorted cotter pin set.
1 Manual Fly wheel
1 Manual motor mount
Tranny Fluid (GL-4 or redline is preferable)
Locking pin and clip for the clutch pedal to the master cylinder (you could bend a nail but I would go to the dealer and pay $4)
2 nuts that fit the threads on the clutch pedal.
1 bolt that bolts in the top of the clutch pedal (the dealer can find it's size for you)
1 bolt that connects the control rod to the tranny (the dealer can find it's size for you)
1 Haynes Manual just in case you need extra help
killerVQ30DE is offline   Reply With Quote
Old 12-04-2005, 10:19 AM   #13
Send a message via AIM to scrhale Send a message via MSN to scrhale
In addition to ^^^ ... that list says "1 brake pedal and 1 clutch pedal"
The list up top says "assembly" not "pedal" ... any difference?
Assembly sounds like it has a lot more stuff that comes with it.
__________________
2002 SE 6-Speed 100% Stock
scrhale is offline   Reply With Quote
Old 12-09-2005, 04:21 PM   #14
for the bolts listed how many of each do we need. or does that one part number include all the bolts needed for that part. price seems rediculously high if its just 1 bolt.
231577A00 $4.61
Engine / transaxle - Transaxle parts - Flywheel - Bolt
Bolt - Manual trans 1995 - 1999
blazingchimp is offline   Reply With Quote
Old 12-18-2005, 04:45 PM   #15
Armed and Dangerous
i30ds's Avatar
Parts Needed:
1 5spd starter
1 brake pedal
1 clutch pedal
1 master cylinder
1 Manual Fly wheel
There is no 5spd starter. Its all the same starter. The hal instructions and vqpower are wrong.
__________________
Vortech- V2 SC/ BOV/ FMU- 8:1 disk; 3.25 pulley; Walbro 255 lph fuel pump; 3'' Intake Piping; Variable Intake Manifold; 5th Gen. Clutch; Fidanza Flywheel; B&M STS; Raxles Axles; Cattman- Y/ B Pipes; ES Motor Mounts
Cefiro- Headlights/ Tails/ Grill/ Gauge Rings; 15% Tint; 350Z Pedals; Limited Kick Plates
Stillen- FSTB/ RSB; Tokico Illuminas; CE Springs; 17X7.5 Rays Engineering GramLights 57C; Yokohama AVS 235/45 R17
Old 01-15-2006, 06:13 PM   #16
Quote:
231577A00 $4.61
You need 8 of these bolts. That price is per bolt.
GoalieKeg is offline   Reply With Quote
Old 02-19-2006, 10:27 AM   #17
Send a message via AIM to MaxFanatik
ecu can be kept as the auto ones??? no need to get an ecu out of a 5spd car??
MaxFanatik is offline   Reply With Quote
Old 02-19-2006, 10:28 AM   #18
yes..
**** you 10char.
Old 03-29-2006, 08:33 PM   #19
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Quote:
Originally Posted by Hoooper
what was the end price for this?
$1200, every bolt/washer/part except for the the ECU. But in this instance (A32) you don't need the ECU to make it work.
Someone had a complete A32 set(minus ECU) f/s for that price.
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 04-24-2007, 10:25 PM   #20
Send a message via AIM to QnzMax
Does anyone know how many of each of these are needed for the swap?
manual flywheel bolts- 12315-77A00
clutch cover bolts- 30223-07S00
shift support rod bolt- 08121-0252F
clutch cover bolt washers- 30240-07S00
slave cylinder bolts- 08121-02528
manual motor mount bolts- 01125-03291
breather tube for manual tranny- cant find invoice
shift rod support bushing- 34560-70N00
transaxle hole cover plate bolt- 74965-0E510
QnzMax is offline   Reply With Quote
Old 04-29-2007, 09:29 PM   #21
Is the return spring the spring that is for the clutch pedal?
Old 05-01-2007, 04:02 PM   #22
Super Moderator
Send a message via AIM to nismology
Quote:
Originally Posted by QnzMax
Any one know which breather hose I would need? I have a 97 and Im putting in a LSD trans.
31098-47U00 is the part number for 01/95 to 12/98 production dates.
nismology is offline   Reply With Quote
Old 12-28-2007, 10:10 PM   #23
Bear > Wookie
DrunkieTheBear's Avatar
Send a message via AIM to DrunkieTheBear
now its time to start mine, my girl is pitching for half of it for my b-day, so by spring break of 08 I will be a manual, so by may 3rd (my b-day) I will have been a happy man for 2 months. Thanks for this parts list. I'm going to do a stage 2 clutch and a lightened flywheel for aftermarket parts on this.
Only question is I am not going to LSD, I honestly don't care to have it, I just want to be manual thats all that matters, would getting an older tranny from a 95 to 99 be cheaper? And what was your average price for the tranny?
__________________
2004 Pontiac Grand Prix GTP Comp G
|3.5" Intake Bpi/R2C|Ram Air|3.4" Pulley|180* T-stat|Headers|Corvette Brakes|SSC Lowering|KYB|LEDs everywhere|GXP parts|SE Parts|
Want a Plug and Play Harness for your Emanage Ult/Blue? CLICK HERE!
Quote:
Originally Posted by MOHFpro90 View Post
Thank you Dave. I love you Dave.
Quote:
Originally Posted by bigleman View Post
...so i had to get towed out of a ditch last night...
DrunkieTheBear is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
