Help with instilling a 00VI
I need help from the people that did not use the egr, how did you close the pipe (block it off). And a question for those that used a 5th gen throttle body with the swap, how did you hook up the IVAC or IAVC ,its been a long night(did you use the 5th or what?).
I made a triangle plate to cover the hole in the VI and got a plug to close the hole in the exhaust manifold.
I used the 5th gen IACV. All I did was swap the 5th gen IACV plug in place of the 4th gen one. The middle two wires match colors but the other 4 don't so I just hooked the others up accordingly. It has it's little quirks but it works good enough for me.
okay I tried to get the pipe off the exhaust but there is too much stuff in the way so I can't get my wrench down there and move it. Could I block of the egr guide tube that goes into the manifold.
That's my only option at this point unless I take out the entire egr system. One more question I dont have the 5th gen IACV plug so I'm rigging my 4th gen IACV plug to go into the 5th gen. I know that the 2 red wires stay in place but where do the other 4 go, if you could tell me what order they go in as if you were looking at the throttle body and the IACV was plugged in.
I should be, I just keep running into things that slow me down alot. There is just one thing that is blocking me for getting the upper on it is a black plug it hits the bottom of the manifold . I think it is the PCV (correct me if I am wrong) does anybody have a way to fix thisand make it work?
I finally got the wiring written down. Mine is set-up as follows:
1: yellow - yellow
2: red - red
3: purple/green - white/purple
4: gray/blue - gray/blue
5: red - red
6: yellow/black - gray/green
That's going from 4th gen wiring harness to 5th gen IACV plug. It looks like 4 of the wires matched colors instead of just 2 like I had originally posted.
1: yellow - yellow
2: red - red
5: red - red
1: yellow - yellow
2: red - red
5: red - red
1: yellow - yellow
2: red - red
5: red - red
Thank you!
#6 is transposed I believe
Is this wiring setup w/ the correct idle or is it the random idle issue
I didn't have the 5th gen IACV plug because my throttle body didn't come with one. So I just modified my 4th gen IACV plug as well as the IACV on the 5th gen throttle body and it plugged right up.
Originally Posted by jmeister
Thank you!
t6378tp
09-29-2018 04:27 PM
Finkle
09-27-2015 09:53 PM
Maximeltman
08-31-2015 01:01 PM
