00VI customized IM
Old 11-12-2004, 09:10 AM
Lives in a 11sec maxima
TILLEYS99's Avatar
00VI customized IM
TILLEYS99 is offline
Old 11-12-2004, 10:42 AM
BSwithTF's Avatar
Looks nice. What size is that TB? Is that the Q TB?
BSwithTF is offline
Old 11-12-2004, 11:47 AM
TILLEYS99's Avatar
thats right a Q45 t-body
Old 11-12-2004, 11:54 AM
VG Ridah's Biatch Hoe
Bags's Avatar
How is that a custom IM?
Or is it just a stock 00VI?
Bags is offline
Old 11-12-2004, 12:15 PM
TILLEYS99's Avatar
CUSTOMIZED to fit a Q45 TB
Old 11-12-2004, 12:45 PM
kenji's Avatar
Next up: Custom intake piping
Or you could just strap a filter right there on the TB, like on my CIVIC TYPE R!!!!!!!111one
kenji is offline
Old 11-12-2004, 02:07 PM
JClaw's Avatar
Cool. Now install it on your car and convince us to do it as well with 1/4 mile times.
JClaw is offline
Old 11-12-2004, 02:40 PM
TILLEYS99's Avatar
well you will probably see this on my car sooner than you will see vsam's car do a 1/4 mile
Old 11-12-2004, 02:55 PM
Bags's Avatar
Thanks.. I was confused
Bags is offline
Old 11-12-2004, 03:53 PM
TILLEYS99's Avatar
test fit on the car
Old 11-12-2004, 03:57 PM
I'm needing a caw
Jeff92se's Avatar
Swweeettttt!!! Talk about a killer combo. You get those brackets yet?
Jeff92se is offline
Old 11-12-2004, 04:03 PM
TILLEYS99's Avatar
Yup! Thanks man........I put one side on (car is sitting) and they look killer with 18s with slotted/drilled rotors
Old 11-12-2004, 05:29 PM
JClaw's Avatar
How complicated was the install. Not the Q45 TB, the install of the IM on the car. I am assuming it bolts right up but... you never know. Does the upper DE-K manifold bolt to the lower DE manifold or did you change both to fit it on?
BTW, are you planning on replacing the JWT cams with stock VQ35 cams? That's what japmax96SE did. Hasn't tried it yet (http://www.cardomain.com/id/japmax96).
JClaw is offline
Old 11-12-2004, 07:06 PM
BSwithTF's Avatar
Enjoy your first test drive. I think you'll like what you feel.
BSwithTF is offline
Old 11-12-2004, 07:19 PM
TILLEYS99's Avatar
Its not easy took alot of mods, i used the DE lower (removed then spun 180% and reinstalled it) I had to bore the holes out (2 middle fronts) and had to make either end bolts holes.
Old 11-12-2004, 07:20 PM
JClaw's Avatar
So you couldn't use the DE-k lower too?
What about the wiring and all.
JClaw is offline
Old 11-12-2004, 07:48 PM
TILLEYS99's Avatar
it would be way easier using the DE-K lower, if you got it.....wiring is not done yet.
Old 11-12-2004, 08:18 PM
JClaw's Avatar
So you went through this since you couldn't find a DE-K lower manifold? K. The DE-K lower should bolt right on my 1995 heads, right?
I talked to the guy at the junk yard. I am buying a full 3.5 but might trade him the entire 3.5 manifold for a 2000-2001 VI but keep the 3.5 heads so can use a 3.5 bottom end, 3.0 heads with 3.5 cams & 00-01 VI.
JClaw is offline
Old 11-12-2004, 08:27 PM
Father of the 00 VI
krismax's Avatar
just get the dek lower and get the dek injector plugs and soder them on and its all ready to go .
I removed the swirl junk in the lower and welded the holes shut.
krismax is offline
Old 11-12-2004, 08:37 PM
JClaw's Avatar
So how hard was the wiring on your car, krismax?
JClaw is offline
Old 11-12-2004, 08:42 PM
stephenlc's Avatar
dude just use the whole 3.5 block.
I want to know how your car runs without all the other things connected to the intake manifold. I have a 2k manifold in my room too but waiting for someone else to install it first so I can follow. Hey isn't the Q throttlebody radius much bigger than the opening of the intake manifold even after boring it?
stephenlc is offline
Old 11-12-2004, 09:20 PM
TILLEYS99's Avatar
I was able to match the size for the tb now if i can only get the car too start grrrrrrrrrrrrr its been sitting with no motor since last may............I had it flooded today too the point the cylinders were full...lol i just swapped in a different wiring harness and i at least got a couple fires out of it, plus i had a bad ground...
Old 11-13-2004, 10:50 AM
Charcoal95GXE's Avatar
Tilley. Check PM
Charcoal95GXE is offline
Old 11-13-2004, 02:09 PM
Father of the 00 VI
krismax's Avatar
How big is the TB 90mm? you port matched it ? and that big?
krismax is offline
Old 11-13-2004, 02:32 PM
TILLEYS99's Avatar
thats right it matches up after some porting
Old 11-13-2004, 07:04 PM
JClaw's Avatar
Should have gone with the Pathfinder TB, for the amount of power you're making.
JClaw is offline
Old 11-13-2004, 07:20 PM
TILLEYS99's Avatar
Wrong car this is going on my 99 turbo car.........
Old 11-13-2004, 07:52 PM
JClaw's Avatar
K. But A 00-01 VI + Pathfinder TB would've been better than the MEVI on your '97.
JClaw is offline
Old 11-17-2004, 12:58 PM
Fastest Fantasy Maxima Evar
IceY2K1's Avatar
Can you describe how you did it? Looks like an adapter plate was used for the different holes?
Hmmm...I wonder if a 5th gen could get around the TPS/IAC.
IceY2K1 is offline
Old 11-20-2004, 11:31 PM
Sports Button FTW
meccanoble's Avatar
Interesting Stuff
meccanoble is offline
Old 11-21-2004, 05:57 AM
TILLEYS99's Avatar
Im working on the IAC but its not looking good.
Old 11-29-2004, 08:28 PM
goodhead's Avatar
any news?
also what do you have to do with the iac?
goodhead is offline
Old 11-29-2004, 10:37 PM
vq30max's Avatar
does anyone ahve a write up on this ???
vq30max is offline
Old 11-30-2004, 12:39 PM
IceY2K1's Avatar
Are you trying to use the Q45 IACV or the 4th gen IACV?
IceY2K1 is offline
Old 11-30-2004, 12:41 PM
Custom User Title
Nismo3112's Avatar
Will the 4th gen injector connectors plug into the 5th gen injectors?
Nismo3112 is offline
Old 11-30-2004, 01:17 PM
Kevlo for President
Kevlo911's Avatar
No.........
Kevlo911 is offline
Old 11-30-2004, 03:23 PM
vq30max's Avatar
Write Up On How To Install 00vi's On 4th Gen???
vq30max is offline
Old 11-30-2004, 03:31 PM
Chassis Freak
VQuick's Avatar
I don't think anyone's made one yet. I would like to see one too but let's be patient. If you're really eager to do it you can read up on all the threads and figure it out yourself.
VQuick is offline
Old 11-30-2004, 03:56 PM
Stephen Max's Avatar
I'll have a writeup with pix and a before and after dyno comparison (but boosted - sorry, NA folks) by the end of next week, maybe.
Stephen Max is offline
Old 11-30-2004, 04:36 PM
living out of a maxima...
JeffesonM's Avatar
look forward to it
JeffesonM is offline
Quick Reply: 00VI customized IM
