Go Back   Maxima Forums > Advanced Performance > All Motor
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 06-28-2004, 11:38 AM   #201
vsamoylov
Quote:
Originally Posted by Oxidizer2k
Hey, ive been hearing Tilley droped a vq35de in his 4th gen, who has got the link for that?
so did he actually do it or what?
Old 07-12-2004, 03:40 AM   #202
STROKE distance
Hi! Dixit
Can i know how many mm for the stroke ?(77.1mm??)
will piston hit the cylinder head or valve ?
Thanks !!!
Hun
A329878 is offline   Reply With Quote
Old 07-21-2005, 01:52 PM   #203
Only gentoo powered Maxima!
rmh3093's Avatar
Send a message via AIM to rmh3093
are there any results for this yet or is this still just a myth?
rmh3093 is offline   Reply With Quote
Old 07-21-2005, 02:07 PM   #204
Certified Hooptie
NmexMAX's Avatar
Send a message via AIM to NmexMAX Send a message via MSN to NmexMAX Send a message via Yahoo to NmexMAX
Check all motor forums
__________________
03 SE 4AT 242whp/238wtq
95 SE 4AT 235k Miles
NmexMAX is offline   Reply With Quote
Old 07-21-2005, 06:10 PM   #205
Maxima.org Sponsor and Donating Maxima.org Member
Send a message via AIM to dmbmaxima2k2
good work guys
__________________
1990 Nissan 300ZX TT 5-spd - SOLD ;(
4th gen maxima coming in the spring!
Owner-Frankencar Performance
www.frankencar.com
shop@frankencar.com
Don't worry guys, even though i don't have my maxima i'll still be around. i'd miss you all too much
dmbmaxima2k2 is offline   Reply With Quote
Old 07-21-2005, 11:45 PM   #206
Wanna Go Fast?™
MrGone's Avatar
Quote:
not from Dixit, he's too busy playing with fast, worthwhile toys.
MrGone is offline   Reply With Quote
Old 02-15-2006, 06:02 PM   #207
Send a message via AIM to Vigo327
now that a 3.5 shortblock swap is a proven option, it makes sense that the vq33 stroker idea isn't holding much attention anymore, but i think it still merits investigation. Definitely doesn't merit bugging the crap out of the only people who actually have the werewithal to do it until they stop posting updates, but that has everything to do with being on a car forum (its universal) and nothing to do with vq 33.
I think the main questions that need to be answered about this parts combo are the ones that apply most to the people who are most likely to consider doing it, i.e. people with no tuning experience/knowledge or no intention of putting the time into tuning something. People who have the ability or willingness to do tuning work will skip this for the vq35 swap in its various forms, so this combo's potential appeal is mostly in the possibility of it being a wrench-turning mod and not a brain-wrenching one.
with that in mind, the questions that need to be answered most are these:
1. will the vq33 shortblock setup have adequate valve clearance when bolted to stock 3.0 heads and valvetrain using stock 3.0 cam timing? Since it's been mentioned that the compression ratio would be higher using the STOCK pistons, that by definition means that there would be less distance between the combustion chamber and the top of the piston, because if the piston, combusion chamber, and bore remain the same, the only way to change compression ratio is by changing the pistons TDC position in relation to the combustion chamber. Long story short, piston ends up closer to head, and for those that dont know, there are times when the valves are open and the piston is near TDC and if the piston was higher up in the bore, there's the possibility of contact. contact=bent valves=$$$$ and hard to fix. You COULD alter the cam timing to prevent contact but you're basically opening up a complicated can of worms and it goes beyond the scope of the people likely to consider this setup.
There is probably a mathematical way to check the clearance that some smarty-pants could do if he knew all the numbers, but the only real way to check this clearance is to put together a vq33 shortblock, bolt both 3.0 heads on (one with one each (int/Exh) of the stock valvesprings removed and replaced with a much softer one to allow you to move the valve by hand so you can check available clearance with a dial indicator), and put the stock vq30 cam timing setup on the front, set to the stock timing marks, and rotate the engine through a full revolution. if it binds at any point you're automatically done, interference=no go, basically. if not, then the engine needs to rotated in small increments and the valve clearance checked at points throughout the valve's travel, because the clearance isn't necessarily smallest at the valve's max open point. Difficult to explain, but it needs to be checked throughout the valve's travel. I dont know what a good amount of clearance is, plenty of engine builders would know, but if it is too tiny than you risk a bunch of bad things: a weaker then the rest or weaker than stock valvespring could not retract the valve fast enough, a chain stretching through its normal wear could change cam timing enough to cause contact, even a failing tensioner that might usually only make noise could cause cam timing to change enough to bend valves if this clearance is too small.
If it passes that clearance test, however, thats one big hurdle out of the way.
2. The stock oil pan needs to be checked for clearance. I'm not super familiar with VQ's (dodge guy) but i think they use a girdle on the bottom of the block with the oil pan bolted to that, if thats the case oil pan clearance issue is extremely unlikely but it still needs to be checked.
3. Reference sensor compatibility needs to be checked. Again, not too familiar with the VQ setup, but need to find out that even if it uses the same type of triggering system, if the slots/holes whatever are in the same position relative to the crank throws compared to the vq30 crank. since there are already running 3.5 swaps using 4th gen electronics, you can assume it will work electronically with no or minor changes, but the thing is, if the 3.5 uses a different positioning of its triggers to achieve different base timing, it might not show up on a full 3.5 but COULD show up with the vq33 due to higher compression.
If all the physical stuff checks out, then all that remains is to bolt it into a 4th gen and see how it runs on stock electronics.
The higher compression ideally should be accompanied by changes to fuel and timing but basically, it it runs decent on stock fuel/timing (i.e. no misfires or detonation on premium) then it will likely run stronger than a comparable vq30 , ideally tuned or not.
If it DOES run well enough to be considered daily driveable/reliable with no tuning, then all we need to know past that is if the power gains justify the cost.
If you look on car-part, the cheapest used motors often have caveats like FIRE ON TOP/ MISSING VALVE COVER / NO MANIFOLDS/ NO CAMS/ ONE HEAD GONE etc etc etc, point being you only need an intact shortblock for this mod, and if the cheapest full engines are about 500 bucks, you can assume damaged/ partially disassembled/ parts missing engines will be much cheaper but still have the parts you need.
as for costs involving the actual assembly, you'll basically need a full gasket set, i dont know what it costs for a vq but they range from 100-300 bucks for most engines. if you wanna reuse everything you can, the bare minimum is a set of headgaskets. another cost i'd consider mandatory if you're using used parts is the cost to rent/borrow a micrometer to check the crank and rod journals. Plastigauge for the used bearing clearances will be cheap, and most 3.5s have less wear on them than 4th gen motors at this point anyway so... You'll also need to rent/borrow a ring compressor to put the pistons back in, and maybe some assembly lube if you like that stuff.
its probly BORDERLINE POSSIBLE for a person who can do it themself to pull it off for around 500 bucks if they get good deals, but id say its likely to be a couple hundred bucks more.
As for labor, IMO you'd be better off bribing someone who knows their crap to help you do it yourselves than pay a shop. this is just my opinion, but if you dont want to be there every step of the way and try to learn as much as possible in the process, you shouldn't be trying to pull off a cheap motor swap/stroker build. IF it runs ok without tuning, then all you're really doing for this mod is turning wrenches, and the only knowhow you need is the knowhow to not break stuff. (admittedly, that's like the first 3 years of the car guy learning curve but if you have an experienced friend to help you you'll be ok).
So, all it takes is one person who has all the parts available and the knowhow to do to valve clearance check to do the first couple steps, and a willing guinea pig to check the last.
I'll do that experienced friend thing if anyone near SA,TX wants to try it.
Otherwise, hope my contribution as a curious stranger to the maxima world is appreciated :P
PS Check out my cardomain (ID Vigo327), you'll notice im very experienced at mixing and matching stock parts :P
__________________
I like cars.
ASE Master-Certified Technician
Currently: Transmission Rebuilder
Vigo327 is offline   Reply With Quote
Old 02-16-2006, 03:04 PM   #208
if's there's a thread that answers those questions then great, i dont know where it is and won't go looking unless someone wants me to swap their car, i just found the link on ceasar's chariot link page and thought it was interesting. sometimes you have to lay things out in a very specific straightforward, systematic way on forums or people will hijack, spew useless crap, or otherwise not move the ball forward at all, just waste everyone's time being a half-*** car guy that only wants to fill up their free time cruising the intarweb, so i'm not writing huge-*** posts to come off smart, just trying to bump an interesting thread in a way that'll hopefully get some actual answers.
its also linked in the all-motor section.
__________________
I like cars.
Old 03-15-2006, 12:49 AM   #209
Send a message via MSN to Spanners
Sorry to say it.. but you're way off.
Top put it simply...
Your volume of the chamber at TDC hasn't changed (providing deck height hasn't changed)
What has changed to increase the compression is the volume in a stroke based on same bore size and now longer stoke.
That larger volume is now squeezed into the SAME sized gap, hence more compression.
Piston to valve and quench etc HASN'T changed at all, infact the piston is now traveling further during a cycle, which in turn more distance over same time = faster, so chances have LESSENED for any contact if any existed on orginal engine.
Spanners is offline   Reply With Quote
Old 03-17-2006, 08:53 AM   #210
Super Moderator
Stephen Max's Avatar
The problem is that deck height has changed. Using the VQ35 rods and the VQ30 pistons results in the piston sticking up above the deck by .6 mm. This is less than the thickness of the head gasket (~ .9-1 mm), but enough of a change to cause some concern. Maybe not with valve clearance, since JWT markets cams that have a larger change in lift than .6 mm, and they work okay, but I would be concerned with piston to head contact due to rod strecth and thermal expansion at high rpm.
__________________
Stephen in Austin
Hook 'em!
Member ASME, SAE
http://www.utexas.edu/research/cem/who_manifold.html
04 G35 sedan
2k GLE
92 ZX11
Stephen Max is offline   Reply With Quote
Old 03-24-2006, 02:30 AM   #211
Could be the big bang in the worst possible way , any thicker head gaskets available ?
Cheers Adrian .
discopotato03 is offline   Reply With Quote
Old 03-24-2006, 02:42 AM   #212
Lebanese By Birth
panda_1's Avatar
Send a message via AIM to panda_1
Quote:
Originally Posted by BigDogJonx
Well im sure some of yall saw the thread that IceY2k1 put up about this being possible. Since I had a spare engine (VQ30) and DaveB had a VQ35 sitting around, we basically test fit these parts. Thanks to both of these guys for helping out on this.
So basically I put in the VQ35 Crankshaft, VQ35 Rods and VQ30 Piston Head all going into the VQ30 block. This is a COMPLETE drop in kit. I mean even the main bearing caps, main bearing cap beam, and rod bearings were all from the VQ30 and it fit perfectly. Without a hitch. Now on a sidenote, not sure why it was said the VQ35 piston heads was dished/valve reliefs, but it doesnt. Its as flat as it gets. The VQ30 has an ever so slight dish to it.
So for you people who want more performance via NA application, this would be a HUGE benefit. It will stroke your engine to about a 3316cc and your Compression Ratio will go to 11:1 using stock parts. No need to buy custom pistons and rods.
Pictures
Crankshaft comparisons 1
Crankshaft comparisons 2
Crankshaft comparisons 3
Crankshaft comparisons 4
Piston/Rods Comparison 1
Piston/Rods Comparison 2
VQ35 Piston 1
VQ35 Piston 2
VQ35 Piston 3
Finally VQ33 Stroker installed!
Dixit
you.... are.... GOD!.!.!.!. i really really want, do you have an approximate pricing on the parts required?
__________________
********OFFICIALLY THE 1ST 5TH GEN WITH NWP ENGINEERING IM SPACERS INSTALLED!!!!********
PR CAI / Exedy Stage 1 / Pacesetter STS / Larrio's Shifter Bushing / Fidanza / Cattman Headers & Exhaust / Custom Enterprise Test Pipe / All ES Bushings / SS Brake and Clutch / S-techs with Illuminas / Blehmco 300zx Brake Upgrade / FSTB / RSTB / RSB / Walbro / Autometer / Emanage Ultimate / Innovative Motorsports LM-1 Wideband / AE VLSD Tranny / Rev-up Oil Pump / Scan Gauge II / Home Depot Catch Can / JB Welded VI / KOYO Rad./ 350Z Thermostat / 19" Forged G35 Rims
211 HP
204 TQ
More Powah Coming Soon!!
panda_1 is offline   Reply With Quote
Old 03-24-2006, 06:26 AM   #213
Super Moderator
I didn't notice this at first, but this needs clarification. The first generation VQ35 engines (Pathfinder, e.g.) had flat pistons, but later VQ35's have slightly domed pistons with valve reliefs.
__________________
Stephen in Austin
Hook 'em!
Member ASME, SAE
04 G35 sedan
2k GLE
92 ZX11
Old 06-03-2007, 03:06 PM   #214
Certified Hooptie
NmexMAX's Avatar
For the work involved, I'd say a 3.5 swap is better time/$$ spent. It also depends what exactly you're after.
If it is indeed a broad power band, a full VQ35 swap can accomplish that.
__________________
Old 05-13-2008, 04:29 AM   #215
but the thing is a full vq35de swap might be more complicated in other vehicles.
irax is offline   Reply With Quote
Old 05-13-2008, 12:43 PM   #216
Donating i30 Owner
Send a message via AIM to HomerMAC
Quote:
I was gonna comment that this is old.... but then realized I dug up 4 year old threads myself.. so carry on....
__________________
WTB: 00-01 shifter linkage/shifter, front mud flaps a32 or a33, real speaker grill (a32), white spoiler led bar, i30 cleared rear brake lights,RPM switch, Side Skirts (paradox/ionic
HomerMAC is offline   Reply With Quote
Old 05-14-2008, 07:46 AM   #217
Certified Hooptie
NmexMAX's Avatar
Who said anything about other vehicles?
__________________
Old 04-13-2009, 03:40 PM   #218
arghh but does it work
yea yea i kno old *** **** thread but
the question was never answered
and in my case where i swapped a vq30 into my car
if i have a stock piston and a low compression piston side by side will the low compression piston be shorter. cause then will that solve the problem of the .6 over lap and then what would the compression be?
wtfemI is offline   Reply With Quote
Old 04-13-2009, 05:43 PM   #219
This can be done and has been. There is only one problem that needs to be resolved. The piston sticks out of the deck by 1 mm or so. The simplest solution is to have the connecting rod shaved. This means you have the cap shaved 1 mm then connected to the rod and then hone the rod and cap re shaped to fit the crank. If you are using stock pistons the compression ratio will increase to about 11 to 1.
Ferhan
__________________
Don't believe your own bull****!
furbiss112 is offline   Reply With Quote
Old 04-13-2009, 05:48 PM   #220
Bear > Wookie
DrunkieTheBear's Avatar
Send a message via AIM to DrunkieTheBear
actually the stroker has been done.
Its VQ35 crank
VH45 rods
VH45 pistons
Puts it below the deck, still a high compression motor though.
__________________
2004 Pontiac Grand Prix GTP Comp G
|3.5" Intake Bpi/R2C|Ram Air|3.4" Pulley|180* T-stat|Headers|Corvette Brakes|SSC Lowering|KYB|LEDs everywhere|GXP parts|SE Parts|
Want a Plug and Play Harness for your Emanage Ult/Blue? CLICK HERE!
Quote:
Originally Posted by MOHFpro90 View Post
Thank you Dave. I love you Dave.
Quote:
Originally Posted by bigleman View Post
...so i had to get towed out of a ditch last night...
DrunkieTheBear is offline   Reply With Quote
Old 04-13-2009, 11:23 PM   #221
finally some friggin answers lol
thanks fellas
ok but then how about if i need to lower the compression down to like
i onno 9 or 8 something streetable with turbo?
Old 04-14-2009, 12:13 AM   #222
Send a message via AIM to NiZMo1o1
Quote:
thanks fellas
why go thru that when you can drop a 3.5 ?
if stroking it and going higher compression for N/A
why not save the trouble and boosted a 3.5
the engine is a stout motor with great torque ?
__________________
http://www.facebook.com/home.php?#/p...e/194777241351
R.I.P. Kevin007
NiZMo1o1 is offline   Reply With Quote
Old 04-20-2009, 09:11 PM   #223
niceee
maxima dude is offline   Reply With Quote
Old 04-22-2009, 05:17 AM   #224
because i want a stroker ..
i just want to know if it will work or if it did
Old 04-22-2009, 05:55 AM   #225
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Cleaned up a little and moved to All Motor, where the discussion will be more constructive (hopefully).
Nismology: do as you please with it.
Puppetmaster is offline   Reply With Quote
Old 04-22-2009, 10:31 PM   #226
vq30 stroker
so all i need is vq35 crankshaft and rods..and everything else can be vq30
nengers is offline   Reply With Quote
Old 04-22-2009, 10:58 PM   #227
I'm thinking probably no, but on the VQ is it possible to remove the crankshaft and the rods from the bottom with the motor still mounted to the car?
If it was all accessible from underneath taking the oil pan off, then this might definitely be worth it.
__________________
|1997 Maxima SE|5sp|Pebble Beige|Sec.&Conv. package|SE Leather package|Cold weather package|
|00vi|VAFC2|Warpspeed B pipe|fenderwell CAI|KYB AGX/Tein S.Techs|I30 headrests & autodim|Hardwired Passport 8500|6000K 35w HIDs|
modenaf1 is offline   Reply With Quote
Old 04-23-2009, 12:50 PM   #228
Send a message via AIM to 98SEBlackMax
Quote:
Its VQ35 crank
VH45 rods
VH45 pistons
VQ35 crank = 81.4 mm / 2 = 40.7 mm peak crank height
VH45 rods = 147 mm average center distance
VH45 pistons = 32 mm average compression height
Total bottom end length = 219.7 mm
VQ30 average block height = 215 mm
Im calling unless those VH45 pistons and/or rods were machined quite a bit.
__________________
- Joe
1996 KH3 Maxima SE - 222 WHP / 208 WTQ SAE corrected @ 209,000 miles, VQ30DEK swap
(5 spd - project car, never ending money pit )
2007 KH3 Frontier NISMO 4x4 - ??? WHP / ??? WTQ
(6 spd - daily driver)
98SEBlackMax is offline   Reply With Quote
Old 04-23-2009, 01:04 PM   #229
VQ35 rods = 144.2 mm average center distance
VQ30 pistons = 30.7 mm average compression height
Total bottom end length = 215.6 mm
This is more doable and requires less machine work. You would only have to flycut off 0.6 mm from the VQ30 pistons to get the proper deck height.
Old 04-24-2009, 04:21 PM   #230
This is a pretty cool idea. I'm gettin nervous about my VQ30 now that its up around 190000 miles and I know its had a tough life.
Another option for the rebuild or swap debate.
Murdoc is offline   Reply With Quote
Old 05-05-2009, 12:33 AM   #231
Send a message via AIM to tyler5619 Send a message via Yahoo to tyler5619
so...
is this or is this not a direct bolt-on?
as in, could i tackle this project with little engine experience? is there a CEL?
__________________
SHIFT_no bailout.
A32. QN0. 5MT. FTW.
Current mods.
JVC HU. | 35% tint. | Blackout center caps. | Indy fogs. | Blackout Maxima badge. | Custom blackout SE badge. | Clear bumper lights. | A33 OEM clutch. | HTP MAF adapter, AMSoil cone filter. | NGK Iridium spark plugs. | eBay FSTB. | WarpSpeed y-pipe. | White & bright clock. | Custom 2.5" b-pipe. | Custom G20 sidemarkers. | E46 Bi-X, 6K D2S. | Thrush glasspack. | Magnaflow muffler. | Full tank of 93 octane.
BIRD COUNT: 2.
tyler5619 is offline   Reply With Quote
Old 09-14-2009, 09:12 AM   #232
NissanMan97's Avatar
Send a message via AIM to NissanMan97
is there anyway to get the pics reposted for us noobs to look at?
B
__________________
02 Maxima SE 6spd w/HLSD
Mods - Stillen high flow intake, Fog light rewire, Ralco RZ STS kit and ES shifter bushings on the way
Future Mods - Brembo blanks, HPS pads, SS brake lines, ES suspension bushings, Eibach springs, Koni Yellows
Past cars
97 Maxima SE 5spd, FSTB, RSB, A4 Projectors, full audio overhaul -Totaled
96 Probe GT auto, CAI, full cat back, custom header - sold
94 Probe GT auto, full audio overhaul - Totaled
93 Altima 5spd, CAI, headers, full catback - totaled
NissanMan97 is offline   Reply With Quote
Old 09-14-2009, 09:21 AM   #233
Not a GM sack rider...
try PMing or emailing Dixit....
__________________
1996 5spd w/DE-K/HotShot headers/Apexi WS
JWT Short Ram/VAFC2
KYB AGX/Eibach SportLine/97+ front end...
Quote:
Originally Posted by nismology View Post
You can subscribe to a thread without posting.
DAVE Sz is offline   Reply With Quote
Old 09-14-2009, 10:10 AM   #234
Quote:
will do
B
__________________
Past cars
Old 10-25-2009, 06:30 PM   #235
so what up with this?? so much debate down here..
what is the BEST and TESTED solution for valve clerance??
fly cut the piston or rod shaving?
redteg94 is offline   Reply With Quote
Old 10-25-2009, 08:41 PM   #236
Bear > Wookie
3.5 swap.../thread
__________________
Old 11-06-2009, 03:24 PM   #237
I had the rods machined for my build.
Ferhan
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
