All MotorAll Motor Advanced Performance. Talk about Engine Swaps, Internal Engine work. Not your basic Y pipe and Intake Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
That's the same question I have. I am in the prrocess of building an engine right now, it's down to nuts and bolts. If I can drop in this setup that would be great.
wow thats amazing, def. a BAD *** discovery!!!...looks like i'm goin to have to switch out some engine parts with my sisters VQ35 engine with mine, without her knowing LOL
I dont know much about this stuff but I plan on reving really high and what would be the result if you used the 3.5 block and pistons and 3.0 crank and rods . Thanks
SkyMaxGTR, if you do that then you and your sister will have almost the same size engines because you will destroke her engine bring it down to like 3.2-3.3L.
krismax: Wont be an issue as long as you stay below the 7200rpm level.
You'd be fine up to 8000rpm, since the piston speed would be equivalent to a stock VQ35 stroke at 7200rpm.
Quote:
I wana know because I think I can have this done for the cost of labor but will only do it if it's proven to work.
~THT
I also want to know if everything is ok, and all you need is just the crankshafts and the rods from the VQ35 and nothing else. This will be my summer project if all goes through. Auto + MEVI + 3.3L = fun
Shop charges can vary alot due to the complexity of the build according to them.
I see shops charging normally $1000 at least just to remove the engine and tear it down. Then you talking about getting a VQ35 so you can steal the parts from which will run anywhere from 500-1000. No point in ordering it from a dealer since it will be more than a new engine. Then need new bearing seals, rod bearings, etc.
The cost of this is probably going to run in excess of $3000 in my opinion if you get a shop to do this.
Do it yourself and probably look around 1000-1500.
I dont have the pricing on seals and bearings, but you talking about all the crank bearings, cap bearing, rod bearings, front and rear engine seals, and other misc items that will have to be replaced since you are that deep into the mess. Not to mention depending on your motor condition possibly new Piston rings, oil rings and probably hone the cylinder walls.
You may be able to find a shop at good price, but im still thinking no normal performance shop is going to do this all for less than 1500-2000 in just labor. I know you looking at at least 10hrs they will probably charge in just engine rebuilding time not to mention the engine removal and inserting times.
I guess it would be better to just swap the VQ35 short block and just use VQ30 heads.
Now you tell me........
I dont know what my plans are on this, its been up in the air on this setup for the past month now since the cost is starting to outweigh what i budget'ed.
Damnit, someone just bring me a 4th gen so I can do the how-to on the VQ35 swap. I still do not understand why any of you want to short change yourselves by settling with 3.3 liters instead of 3.5 .
Hahahahaha...LOL! Like I'd have a clue what it costs to build an engine.
For the price you paid, I think you can sell off parts and eventually get your money back, so not too bad off.
We still don't know if Mardi was sucessful or not, but he keeps hinting like he was, ie "my compression ratio is around 10.5:1". Until he or someone does it, who knows if it will work. Plus, 11+:1 CR isn't going to be boost friendly and SGP or similar low CR pistons are pricey.
now... who can figure out to get better gas milage?
I can!
step 1: install tall tires. 225/75 reduces engine speed from 2400rpm to 2100rpm at 60mph in 5th.
step 2: install 3:1 diff. to reduce 60mph engine speed to 1700rpm.
step 3: replace intake with 2½" cone and muffler with 1¼" pipe so your engine breathes like a 1.5 liter 3 cylinder. The maf will meter much less fuel now.
sorry to hijack, but this is thread has some knowledgeable people in it, so...
whats the deal with the 3.5 Altima 5 speed tranny? is it the same as the 2k/2k1 5 speed in the maxima? i dont think it has LSD as an option, but if it's stronger than our 5 speeds, and isn't as notchy/time consuming as a 6 speed swap, i think it might be worth looking into for people with blown trannies.
