Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Quick Question Tokico Illumina's
Old 02-13-2014, 08:47 PM
TravisCadello's Avatar
Got the Tokico's installed, My question is why is their a small black box that looks like its meant to hold the Red tip with the numbers on it? I put the Tips on and they fit pretty loosely and probably would fall off, are they supposed to stay on the rod Tightly?
And also, Why does the adjuster screw just keep turning and never stop? How do i know if im actually on 5 or not?
thx....
TravisCadello is offline
Old 02-13-2014, 09:23 PM
Amerikaner83's Avatar
it's pretty fragile and it sounds like you broke it.
Amerikaner83 is offline
Old 02-14-2014, 10:31 AM
Prophecy99's Avatar
no they are pretty loose, and how do you know they are on 5? with the red tips on there
you shouldn't have turned it not knowing what settings they were originally at
Prophecy99 is offline
Old 02-16-2014, 09:05 PM
It didnt break, they just sit on their too loosely for my liking..
Old 02-16-2014, 09:06 PM
I had them on while i set it to 5 then removed caps.
Old 02-17-2014, 10:09 AM
Prophecy99's Avatar
you put them on only temporarily for the purpose of adjusting... you're not supposed leave them on there... what does it matter?
Old 04-06-2015, 09:32 PM
Mattx's Avatar
Got the Tokico's installed, My question is why is their a small black box that looks like its meant to hold the Red tip with the numbers on it? I put the Tips on and they fit pretty loosely and probably would fall off, are they supposed to stay on the rod Tightly? And also, Why does the adjuster screw just keep turning and never stop? How do i know if im actually on 5 or not? thx....
I can tell you how you know when ur on 5. There's a flat spot on the top threaded piece that the selector sits on. When you are lined up on that flat spot you are on 5. It only lines up perfect one way. This is assuming your install was on point. Just to let you know, you are only supposed to turn clock wise. You should never turn counter clock wise that is the way they're designed.
Mattx is offline
Old 04-06-2015, 10:31 PM
ABIGBRAIN's Avatar
Push down on the fender with some force.... you'll kmow right away if your on 1 or 5. Then just set them according to your personal preference.
ABIGBRAIN is offline
Old 04-07-2015, 09:30 AM
Prophecy99's Avatar
News to me, and interesting if true???
Old 06-03-2015, 10:23 PM
Mattx's Avatar
Yea I found it interesting as well. I can't remember his name but he's the suspension guru for maximas has his own thread. I can't believe I can't get his name anyway he's the one who told me this.
Mattx is offline
Old 06-03-2015, 10:27 PM
Mattx's Avatar
Djfreestyle. Sorry buddy. 😄
Mattx is offline
03-12-2020 12:06 AM
pears
09-18-2015 05:25 AM
ef9
Buyer/Seller Feedback
09-10-2015 10:13 PM
Johnny9595
09-03-2015 05:18 AM
Quick Reply: Quick Question Tokico Illumina's
