Advanced Suspension, Chassis, and BrakingTalk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
This will work easily for 89-08 Maximas. Not sure on any other years, I will find out on other years some other time. This is a work in progress, should be finalized soon.
If you have a 89-01 Maxima Please follow these directions first:
Needed Equipment:
-05-06 350z / 05-06 G35 Sedan Dual Piston Brake Caliper, Bracket and Rotor (Rotor NOT needed on a 04-08 Maxima).
-02-08? Maxima Caliper Bolts
-Brake Fluid.
-Aviation Snips (Some type of sheers for cutting metal).
I'm not going to hold your hand through this one, just make it to the point where your car is safely on jack stands and you're looking at this....
(02-03 Brakes on a 4th gen 99 Maxima)
Step 1: Remove the unnecessary components. (If you're a 89-01 skip to step 2)
-Disconnect your brake line
-Caliper
-Bracket
-Rotor (6th genners keep this on!!)
Keep track of your two caliper bracket bolts, YOU WILL NEED THIS! You can NOT use the bolts off of the G/Z they are tooooo long. If you're swapping from a stock 4th gen setup, I suggest ordering these from nissan, if you did NOT buy your brakes from me and attempting the swap you can either order them from Nissan or try to beg for your forgiveness for not buying them from me and I can try to dig some up from work.
Step 2: Install Dual Piston Glory
-There has been confirmed fitment issues, I am working on a easy sure fire way around this. It looks like grinding down the calipers are needed to clear the rotors because of the bracket not moving it out far enough from the center of the hub. I will get around to putting this on a running car to see what is needed to get these on a Maxima, I really think not much is grinding is needed.
-Install rotor
This is where you need your handy dandy shears for 4th/5th gens... Start snippin away at what comes close to contact with the rotor or control arm (have both wheels in the air and the steering wheel unlocked so you can check the clearance while turning the wheels). I have yet to fully test on a 6th gen spindle and their dust shield, I will on Monday. IIRC 6th gens shouldn't need to modify their dust shield because they accomodate the 12.6" rotors already.
-Install bracket
You may still need to continue to hack away at your dust shield. During this step it'd be wise to give the disc a good ol whirl around to check for any rubbing.
-Install Brake Pads
-Install the Dual Piston Caliper
-Re-install your brake lines
Make sure to check the rotation of the disc again. And you have to use the bolts for the 02-08 Maxima. The 3rd/4th Gen bolts will NOT work and the 350z/G35 bolts will NOT work.
After your done it should look like this:
Then proceed to step 3.
Step 3: Prepare for WAR!
-Bleed brakes
-Bed in pads (you should be using new pads and rotors )
-Troll Q45/Z32 front brake owners
And yes, it is that simple, quite amazing I haven't seen anything like this before on the org, and if it's already been done then WHY HASN'T IT BEEN STICKIED?!?!?!?
Quick Facts:
-350z/G35 brembo's will go on following the same procedure it takes to install them on non brembo 350z/g35s (Just replace the bracket/caliper/rotor!). If you're a real baller you can get the Akibono (spelling?) Brakes and relocation kit for the 350z and do the same thing..... Remember, this is a game for ballers and only ballers can participate.
-I have yet to test this mod on the street!
-The dual piston pads use more sweeping area than the 300zx pads.
-It BARELY! Clears AE wheels on my 4th gen if you're running the stock wheels I suggest getting a 5mm spacer for safety sake.
-Caliper Comparison (4th gen and G35/350z, the 5.5 gen on my car looks just like the 4th gen, who cares)
-Rotor Comparison:
-4th top, 5.5 Gen middle, G35/350z/6th Gen on the bottom.
-4th, 5.5 gen, g35/350z/6th gen.
Review of braking to come soon as soon as I get the first street test dummy.
__________________ This is a game for ballers only ballers can participate
REGISTER FOR MAXUS
-$45 for base package, $65 for racers. Details on the site, any questions PM me!
Quote:
after all that, this is what i comes down too. Now this is trolling of the year.
__________________ Originally Posted by mightyMax95 well, i got the water pump in Reply Posted by streetzlegend
if the car starts, ur not a nooblet anymore!
Quote:
Originally Posted by Aaron92SE
Well the car is so fast that I can just accelerate up to 60mph, set the cruise, and still beat the car next to me in the 1/4 mile.
Quote:
Originally Posted by DraKhen99
... silly Nissan, hiding some power behind the gas pedal!
Quote:
Originally Posted by 95Maxed
Either your car is sideways on a patio... Or you sir have taken off your roof and are a brave man.
haha this is actually news from about 6 years ago, the S14 knuckle/spacing is the same as ours (along with the G/Z/spec-V and a slew of other cars)... I too thought I discovered it when I first mocked up my G brembo's on my A32.......nope.
Hey Aackshun, The brake pad covers the ENTIRE rotor and doesn't hang off the rotor and cause uneven wear like the 300zx conversion with the cobra rotors?
__________________
2002 Maxima SE 6-Speed: Tokico Blues/Eibach Springs/ES Bushings/Ralco Short Shifter/Front Strut Bar/Rear Sway Bar/Sprint Booster/Spec Stage II Clutch/Fidanza Flywheel/NWP BOP/Custom Intake Piping w/ Vstack and AEM filter/Cattman Headers, Fast Cat and 3" Exhaust/NWP Spacers/Stillen UD Pulley/Haltech 350z Platinum Pro/Haltech Dual Wideband Controller/Custom IM w/ 09 Maxima TB
Why would it do that since you're using the same rotor the caliper is made for?
I'm not fully versed in teh Q45 or Z32 brake calipers/rotors swap because the age of the technology turned me off.
REGISTER FOR MAXUS
The reason I asked is because people that got the 13" cobra rotors with the brackets for the 300zx calipers had a portion of the pad hanging off the rotor. the entire pad did not cover the rotor and people's brake pads ended up looking like this:
You know I had actually asked someone in the forums if the 350z dual piston calipers would fit our cars and people told me NO.......LIES!!!!!! Talking about the holes on the calipers were different and screws wouldnt fit...bla bla bla. Because this is what I was going to do instead of buying that brake upgrade kit like I did!!!! Might still do this anyway. Let us know how it feels! Brake bias is still the same?
__________________
Keep reading, I said earlier that I haven't driven this setup on the street yet, my red car is still motorless
Quote:
Originally Posted by NmexMAX
This is cool.
What is this alleged bracket that you speak of?
I didn't speak of any, it's the 350z/G35 bracket.
REGISTER FOR MAXUS
What's the availability of good track pad compounds for these heavy iron beasts?
Sure they're bigger than stock and cheaper than the Z conversion, but do they work any better than the current brake kits, are they cheaper to maintain, and how much do they weigh?
and 1mm of pad overhang is no big deal. Lots of wilwood calipers are spec'd for anything from 10 to 13" rotors, and they hang off the ends on larger rotors too.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
IIRC the caliper weighs in at 14lbs...as far as race compounds, just look at my350z for 2006+ non-brembo brake pad options.
(side note - comparing the z32 iron and aluminum calipers...the preference is the iron caliper due to its ability to withstand the flexing that the aluminum calipers face)
Current brake kits?...do you mean work better than an aftermarket setup? I doubt it. Better than OEM setups for Maximas, yes, even better than going 6th gen Maxima caliper.
Yeah, I was referring to the 6th gen or Z32 calipers on same size rotors.
The advantage to the Z caliper is weight and pad options over the more "grocery getter" pad selection of the 6th gen Maxima.
You the DTC-60 is a heavy duty track pad and HP+ is fine for a beginner. for a Maxima, the HT-10 or DTC-30 would be a pretty good choice unless the car is putting down 300+hp- then you'll need more.
But yeah, there's pads available for the Z32 and Z33 calipers, but not squat for A34 calipers unless you're only buying bigger brakes to get to the grocery store in style.
__________________
2 Akebono fronts...with rotors and pads...for under $1500? Where do you see this? And no, your discount doesn't apply. lol
My point is, getting 2 Akebono fronts/rotors/pads is getting closer to aftermarket BBK pricing (for all 4 corners) and is cost prohibitive when compared to OEM G35 non-brembos with rotors/pads at around $400.
Wilwood fronts on ebay...$949 for front calipers, pads, rotors, stainless steel lines & relocation brackets. Just an example but I'm sure I could find cheaper.
Akebono fronts only are how much? Rotors are going to be how much? New pads? Stainless steel lines? Relocation brackets?
It's a moot point for me...just saying Akebonos are going to be 3-4 times as much as OEM '06 G35 dual pistons any day.
Ok 950 for two brakes... now find me a rear BBK, you have $600 to spend!!!! Go, go, go, go!!!
Re-read what I said $1300 shipped for all four (and then like what $200 for the brackets? You use your stock lines, sooo SS lines are what $40? Ok $1540, find me a 4 corner BBK, go, go, go!)
Of Fck yeah. Not even gonna argue that!!!
REGISTER FOR MAXUS
Since you like Fastbrakes.com for pricing reference...
4 piston Wilwood fronts...$825 (includes calipers, rotors, pads, adapters & steel lines) 12" rear upgrade kit...$300.00 (includes 12" rotors and adapter to fit stock caliper so stock parking brake can be used)
New rear pads...~$50
That makes my total $1175 now.
__________________ DFW Timing Advances - PM me ¤ D.N.E. Forum ¤ G35 Dual Piston BBK info thread
¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ ¤ 2003 Maxima SE 6spdw/3" of pleasure and other 'stuffs'
All my exes...'03 GLE * '07 CX7 * '99 SE-L * '92 PGT * '92 MX-3 * '85 Z28
The 04 Max has a bigger rear piston than us, and the G's/Z's are bigger than that
Also the Cylinder in the master cylinder is bigger too... But oddly enough on certain models (the heavier ones eg. a AWD G or a Drop Top Z) have the same brake booster we do....
Hrmmm time for a new thread....
REGISTER FOR MAXUS
It's still good to me. Larger rotor surface with the rear kit and I keep the parking brake.
Just for reference and you're correct:
*2003 Maxima rear caliper bore = 34mm
*2004 Maxima rear caliper bore = 35mm
*2006 G35 caliper bore = 43mm
BUT...All 3 calipers use the exact same pad size according to HPS website. So same size, just less force. Where are the braking experts with their formulas?
I want to start another thread too, some interesting similarities (and differences) between the A32, A33, A34, V35, Z33 when it comes to Brake Boosters and Master Cylinders, I need to keep reading up on some things then I will start another thread.
REGISTER FOR MAXUS
