Advanced Suspension, Chassis, and BrakingTalk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Ive had my Z32 brake kit for a couple years now and didnt until recently really consider possible difference in braking bias (noob move i know). Anyway are you guys with this kit using the stock proportioning valve or have people switched over to the Z32 one. Only reason I bring this up is while talking to a friend about it I mentioned that I really wasnt that impressed with the kit's braking ability over stock for everyday driving applications. He mentioned getting the Z32 proportioning valve. I know that point is more to increase braking in excessive use (autocross/track) as bigger brakes shouldnt fade as fast. But should the initial bite be similar in day to day driving? I know that has part to do with the pads. I had the axxis ultimates for awhile and I noticed a really had to heat them up for them to start biting well so I just switched to less performance oriented pads bc I wanted that initial bite to be there. What are people's thoughts on this? Thanks guys.
Grant
__________________
WSP Y/B pipe, RT Cat, Stillen muffler, Exedy Stage 1 clutch, Progress RSB, Stillen FSTB, Z32 30mm aluminum 4-piston calipers, 300ZX cross-drilled and slotted rotors, SS brake and clutch lines, D2 coilovers, 19x8.5 SSR Competitions wrapped with BFG KDW2s, B&M STS, traction bars, 1st cefiro/projector retrofit, 1st 4th gen w/ Truax stage 3 SFCs, DTM tails, Corbeau CR-1 Seats, coated in Obsidian Metallic Pearl
most of the bite you're talking about is related to the pads. anything you're going to do to increase bite for street driving is going to increase rotor wear as well.
main thing for bias is that you need to have the same pads front and rear, or more aggressive pads in the rear for this application. With the increased pistons size of the front calipers, your bias will be shifted to the front. but it will also make the pedal a bit longer and give you more elverage when you put your foot into it (more braking power due to the greater hydraulic advantage).
So are you wanting more bite during everyday driving, or more bite under hard driving?
What pads are you currently using (front and rear) ??
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Yeah, that's very likely the pads. Crap pads stop like crap. you get what you pay for.
For street use, pick up some Axxis MM or Hawk HPS if you drive hard. If you're more of an everyday driver kinda guy, look at some Raybestos, Bendix IQ or CQ pads. You should be able to get them from Autozone or Oriellys or Advance or whatever for about $50-60 a set. The Axxis MM or Hawk will probably run you $60 or so as well, but will handle more heat. They'll wear out faster and have more brake dust too, but they will perform better.
Any of those will perform better than the $19 crap pads.
__________________
