Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-29-2009, 11:19 AM   #1
Send a message via AIM to Prophecy99
Let the rebuilding begin...
To those who bought junk yard calipers for the 6th Gen BBK upgrade were yours as bad as these? Seem pretty normal?
I think they should be ok with some serious TLC, and carefully examination of the pistons. That being said can you purchase the pistons individually?
I found this decent (generic how to ) and the piston shown is as rusty as mine so thats reassuring.
I am ordering the courtesy nissan seal kit and also had one question on that also http://www.courtesyparts.com/kb_search_result.php?keywords=[41000L]+\(A34&cPath=2668_2669_2760_2761 what is the difference in those two A34 kits?
Thanks in advance for any input.
Prophecy99 is offline   Reply With Quote
Old 08-29-2009, 01:49 PM   #2
Not a GM sack rider...
these look terrible. The pistons on my 96 don't look half that bad. I guess you should take the pistons out and make sure there is no rust inside the boots...
__________________
1996 5spd w/DE-K/HotShot headers/Apexi WS
JWT Short Ram/VAFC2
KYB AGX/Eibach SportLine/97+ front end...
Quote:
Originally Posted by nismology View Post
You can subscribe to a thread without posting.
DAVE Sz is offline   Reply With Quote
Old 08-29-2009, 06:41 PM   #3
STFU n00b!
OMFG dude.. did you pull those out of the bottom of the ocean or something?
I've seen stuff on 30 yr old Zs in better shape than that!
Those are crapola. I wouldn't even use them.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 08-31-2009, 06:26 AM   #4
That means alot coming from you. The saddest part is the parts had "looks good" in the description.
I am still debating if they are even worth it.
Old 08-31-2009, 07:05 AM   #5
Super Moderator
Puppetmaster's Avatar
Send a message via AIM to Puppetmaster Send a message via MSN to Puppetmaster
Damn dude, sorry to say that mine didn't look anywhere as bad as those.
Puppetmaster is offline   Reply With Quote
Old 08-31-2009, 07:35 AM   #6
Quote:
Roger that. Im not sure if.. these would be worth rebuilding.
__________________
Imagination reveals truths that reality obscures.
02 VQ35DE GLE__-_\:._.:/_-___sold_91 VG30E GXE
[FSTB /H&R /Illuminas /LTB Stage II /20mm Spacers /6th Gen BBK/Hayden 404 ATC /Blehmco Grounding Kit /Stillen F/R Lips /18" Exel RH-5 Gunmetal /Smoked Sides /30% /Taillight Vinyls /Eyelids /PIAA]= DONE
(MY CARDOMAIN) Bleed GREEN
Old 09-01-2009, 07:51 AM   #7
Send a message via AIM to jeff5347
the outside looks like crap but im sure the inside looks smooth. pullthe caliper apart beforeyou get the rebuild kit so you dont waste money if theyare junk inside. if they are ok all you need is a bench grinder w wire wheel andthat sh!t will comeright off and expose good metal. may still berough but good metal and use the caliper paint. i got minefrom ad auto parts and6 months later still have the silverpaint on them, no chipping. did u get these off car-parts.com?
__________________
http://www.cardomain.com/ride/2547814
AND NO IM NOT A NEWB. BEEN HERE QUITE SOME TIME But thanks for asking
jeff5347 is offline   Reply With Quote
Old 09-01-2009, 11:22 AM   #8
Quote:
Roger that, comencment asap.
Quote:
Originally Posted by jeff5347 View Post
the outside looks like crap but im sure the inside looks smooth...... . .. . .. .did u get these off car-parts.com?
Yes thats what I am anxiously waiting to see, the inside of em. And Yes I got them off Car Parts . com I almost ordered the seal kit today but said the same thing to myself. I also noticed it looks like you can purchase the pistons seperately.
I will post pics of the inside & progress. Thanks all.
__________________
Old 09-03-2009, 09:44 AM   #9
Those look very bad, but once sandblasted & rebuild they will be like brand new. I've rebuild many so far and once it's cleaned you would not know how bad it was at first.
__________________
2K1 AE-SE - Sterling Mist
2004 BMW X5 4.4i
doublea is offline   Reply With Quote
Old 09-08-2009, 08:47 PM   #10
Quote:
You can say that again, i am gettin em sand blasted asap. With that being said, When you sand blast these things do you typically remove the piston and tape up the area where the piston was removed, or leave the piston in as is so the typical outside elements are blasted?
I also checked out the inside of the pistons and they are great compared to what the outside looks like so they should be ready for work, also just ordered the A34 seal kit from courtesy nissan.
__________________
Old 09-09-2009, 06:58 AM   #11
I leave the piston in if there is no rust on the seal groove. Once the caliper are sandblasted I remove the piston to replace the seal and see if no sand went inside the cavity. If the piston show no rust inside then your good to go. If you see rust on the seal groove dont take any chance and remove the piston, put a rag tightly inside and have the groove sandblasted as well. Once done you can remove any dust with pressurized air and clean with gas or brake cleaner.
__________________
2004 BMW X5 4.4i
Old 09-09-2009, 10:10 AM   #12
Thanks for the response. Thats what I was thinking also.
__________________
Old 09-09-2009, 11:28 AM   #13
__________________
2004 BMW X5 4.4i
Old 09-09-2009, 07:15 PM   #14
STFU n00b!
If you mail ordered those things from a yard on car-part.com, then I'd call them up and complain. those DO NOT "look good". they look like sheit. you're going to spend a helluva lot of time and money rebuilding crap calipers because they grabbed the ugliest, rustiest POS's they could and shipped them to you since you weren't at the place to deny them.
basically, tellt hem they're crap and to send you a set that actually "looks good". then you don't have to rebuidl or waste time sandblasting.
__________________
Old 09-24-2009, 06:45 AM   #15
Old 09-24-2009, 08:11 AM   #16
Clean them with PPG DX579 or an equivalent.
See here:https://buyat.ppg.com/refinishProduc...8-5fde9dc9cebc
The brake caliper is a caster and very porous so cleaning them with DX 579 will stop the rust process & eliminate all contaminent, then you will be good to prime, paint and clear.
__________________
2004 BMW X5 4.4i
Old 09-25-2009, 06:37 AM   #17
STFU n00b!
All that effort, and you coulda bought Reman calipers for about the same money and saved yourself the hassles.. :shrug:
__________________
Old 09-27-2009, 10:31 AM   #18
I hear you but it woulda been a hassle sending them back and finding another pair, I luckily had an uncle that could do the sand blasting at his work so that was a huge help. I cleaned them up with some metal cleaner and then painted them up with 2 coats of duplicolor caliper paint (brush no spray)
I am pretty sure but wanted to make sure, Are the torque member fixing bolts interchangable from 5th Gen to 6th Gen?
__________________
Old 10-07-2009, 12:13 PM   #19
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
Those were rougher off than some '91 Q calipers I rebuilt.
__________________
Fr33way™ is offline   Reply With Quote
Old 10-08-2009, 10:32 AM   #20
Update: I totally cleaned out the cylinder bodies and they look spotless. I re sealed the pistons with rings and piston boot. I also cleaned out the bleed screw areas. Now I have a question when resealing the PIN BOOTS. Is it critical to remove the old grease inside the torque members?
Old 10-08-2009, 10:35 AM   #21
Also another curious question. Is it acceptable that one piston has more give (easier to push out) under the air hose than another?
Old 10-11-2009, 02:00 PM   #22
Wild for Width
Fr33way™'s Avatar
What's critical is that there isn't any hard clumps or debris in there. Getting most of the old stuff out and adding some fresh grease should do the job.
__________________
Old 10-11-2009, 08:41 PM   #23
STFU n00b!
considering they were all sandblasted, I'd clean every bit of stuff out of them and repack them with fresh grease. just a few grains of blasting sand in there is all it takes to cause them to seize in short order..
Ideally, you shoulda cleaned all that out with parts cleaner/gasoline before you painted them. now you're at risk of damaging the new finish with the cleaner.
__________________
Old 10-12-2009, 07:19 AM   #24
Thanks for the input guys, I will do my best in getting anything old outa there and using the new amber grease supplied with the seal kit to lube it up. I left the old pin boots on there during the sand blasting and they still seamed intact after the blasting. That being said I will be sure to inspect inside the pins anyway.
Are there any nice methods in extracting all the old crap in the sliding pin areas?
Yeah after cleaning them up i have noticed the caliper paint became...matte and slightly worn in some areas where there wasnt alot of paint. I am going to redo another coat tonight.
They are being installed tommorow. Thanks again.
Old 10-12-2009, 08:51 AM   #25
STFU n00b!
Best thing I can think of is to hold the caliper so the pins open down, then use a can of carb cleaner or brake cleaner with the little plastic tube on it. shove it in there and spray until it comes out clean.
then soak a q-tip with the same stuff and swab it around in there to make sure you got it all.
since that's bare steel inside, be sure to coat it pretty soon with grease to prevent any rust.
__________________
Old 10-12-2009, 10:19 AM   #26
Sounds good. Thanks alot.
Old 10-14-2009, 05:51 AM   #27
Update: Redoing the Pin Boots went well. Cleaned them up well. Though some of the new seals that go on the actual pin didn't match the same size on there so I just left the existing ones on since they were fine.
The brakes are on and have been properly bedded and felt good. I still have an issue though.
*When going slow speeds you can here a clicking/ contact between the brakes. I drove around alot and Its almost %50 of the time you hear this clicking under 30mph.(anyhigher is probably to fast to hear one click). Any thoughts? Also if i am going slow as soon as I hit the brakes it goes away, but it I let off it 50/50 comes back. Also it sounds like only the driver side
Old 10-14-2009, 10:04 AM   #28
Well it is definately the cheap Rotors I picked up. The are not true at all. I need to get them recut !! And the painted black hub area was allready bubbling from the heat with in an hour after being used. I also can see.... what appears to be the zinc coating pealing right off...less than 24 hours of use. You get what you pay for...
Over all I like the upgrade, they feel pretty good other than the slight vibrations due to not being true. (which isnt much compared to how the previous felt) and they look great.. for now.
Old 10-29-2009, 12:31 PM   #29
install pics
Final install pics,
I would like to thank everyone for thier help and suggestions. It is greatly appreciated.
Old 10-31-2009, 01:01 PM   #30
Wow, I wouldn't have believed they could've come out that nice. The sandblasting really worked miracles on those things.
Congrats on the transformation though I don't think I could have been so patient or forgiving of the vendor. Returns are a pain though...
Jeremy
niceguy is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
