Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 08-02-2009, 07:14 AM   #1
Send a message via AIM to k2a2b
BBK Options - Clarifications
What I understand:
Both Matt and Jeff's kits use 30mm 300zx calipers via relocation brackets.
Matt's kit utilizes 6th gen rotors.
Jeff's kit uses redrilled or spaced cobra rotors.
Question:
Can either of these kits accommodate 300zx rotors?...Or the two piece 300zx rotors automax95 is selling? (I realize he is also selling 2 piece cobra's).
Thanks in advance.
__________________
k2a2b is offline   Reply With Quote
Old 08-03-2009, 12:35 PM   #2
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
If you were to use Z32 rotors you would not need a relocation bracket, just the conversion brake lines. The bracket is to fit the bigger Cobra rotor (hence the BBK).
__________________
Fr33way™ is offline   Reply With Quote
Old 08-03-2009, 12:39 PM   #3
Wild for Width
Fr33way™'s Avatar
I'll drop this here as well:
Quote:
Originally Posted by Matt93SE View Post
They're cheap because they're not much better than the stockers.
What year car?
the stock 2000-2001 rotors are larger diameter than the Z32 rotors and 26mm thick.
02-03 are an inch larger, but 24mm thick.
04-08 are 12.6" x 28mm.
the only good thing about the setup you have is the Z calipers, which have better selection of high performance brake pads.
__________________
Old 08-03-2009, 02:48 PM   #4
Thanks!
__________________
Old 08-03-2009, 07:58 PM   #5
Any reasonable upgrades for the 5.5 Gens?Or does anyone REALLY know how to fix the "loose fitting" pad issue.This happened when i had to replace the rear calipers because one would not screw back in.I think it is a Wagner remanned caliper.Even took back to my dealer where there they assured me that it was the fault of the aftermarket brake pads.After $400 and new pads and shim kit,it is doing it again after 2 months.Sounds like something is rolling around in the trunk when you hit a bump.REALLY FRUSTRATING!!!!!!!!!
1handicap is offline   Reply With Quote
Old 08-04-2009, 01:21 AM   #6
Wild for Width
Fr33way™'s Avatar
Quote:
I'm going to say this as nice as possible but you are posting this in the wrong place mate. Notice the thread title.
That sounds more like an upper strut mount issue with your rear suspension. For way less than 400 bones I'm sure you could have a local orger take a look at it. Check your regional forum (link).
__________________
Old 08-04-2009, 09:32 PM   #7
New to the board here sorry.It is not the strut mount.The noise goes away when you pull on the e-brake,just like the TSB states.Have been all over the board and back looking for threads or upgrades for rear brakes.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
