Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 07-21-2009, 11:49 AM   #1
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
Just a note on Q45 rotors and control arm clearance and other issues (A32)
I recently swapped Q45 calipers and rotors (milled 3mm) on to the front of the Maxima and made a couple observations that I had not read anywhere else on the forum.
-Although the rotor will have around 8mm of clearance from the inside surface of the rotor to the control arm, this distance will be reduced to 0 at full lock and the rotor will rest on the lip of the control arm.
-The lip of the arm needs to be ground or pounded in about 5mm on each side to clear the rotor at full lock.
*As a sidenote I am on OEM Nissan arms and nowhere near slammed.
-The pads I got (the Axxis MM equiv.) needed to have a tab ground off the low side to clear the hub area of the rotor.
-While you can bend/pound the splash shields out of the way, just remove them, the clearence is in the sheet of paper range with them on in the inner portion of the rotor.
As far as driving impressions, I got exactly what I was hoping for: Excellent high speed stopping power and higher resistance to heat. The pedal feel is different from my I30 in that the travel is longer and there is more precise modulation. I happened to get these calipers at a low-low price while getting a part for the I30 at the yard so I rebuilt these and tossed the whole setup on the car as a small project. As is the car has more brakes than grip (at sub 65 speeds) so this should keep me happy until I do bump up to the dogbones and Cobra rotors.
Just wanted to note a couple things to help anyone in the future with this setup since all the reading I did greatly helped me in my swap.
__________________
Fr33way™ is offline   Reply With Quote
Old 07-21-2009, 12:29 PM   #2
Former Vendor
Send a message via AIM to BLACKonBLACK98
one of the houston guys is doing this swap as well with j30 calipers and q45 rotors. i will direct him to this thread for a head's up and possible slight differences with j30 calipers.
BLACKonBLACK98 is offline   Reply With Quote
Old 07-21-2009, 01:34 PM   #3
Wild for Width
Fr33way™'s Avatar
What I have heard but not evaluated side by side is that the Q45 caliper has a tad more material than the Q45 and I had noticed that the same pads by the same brand did not share the same part number.
__________________
Old 07-21-2009, 03:57 PM   #4
Send a message via AIM to mightyMax95
i'm the one doing the upgrade that BLACKonBLACK98 mentioned. there doesn't seem to be any contact anywhere except on the dust guard, which i have already remedied; ie: BFH (not really, a small hammer will do it but i've been wanting to use that acronym for a while )
__________________
Originally Posted by mightyMax95
well, i got the water pump in
Reply Posted by streetzlegend
if the car starts, ur not a nooblet anymore!
i'm just gonna start answering all ?'s i have for you with, "ebay"
Reply Posted by kzoosho
lol, u could
Originally Posted by Matt93SE
Took me a ton of money to learn that physics will ALWAYS win against a FWD car.
mightyMax95 is offline   Reply With Quote
Old 07-21-2009, 05:22 PM   #5
Maxtank's Avatar
Send a message via AIM to Maxtank
Is this with the Q brackets, or the maxima? I'm working on getting everything together for the Q caliper/Cobra rotor, but my drivers side bracket I got from the junk yard has an enlarged hole due to the caliper bolt being sheared off ()
I've been trying to find a new bracket (see sig) or getting a clear answer on weather the Q calipers work with the maxima brackets (thought I read this somewhere, maybe I was dreaming?)
__________________
99 SE-L | Super Black |5 Spd.
'05 Xterra - Daily Driver (yeah, it's yellow)
NEED - Drivers side Q45 Bracket/torque member
Maxtank is offline   Reply With Quote
Old 07-21-2009, 08:40 PM   #6
Wild for Width
Fr33way™'s Avatar
I don't think the Maxima torque member will hold the Q45 pads and/or is too narrow to fit the wider Q45 rotor. I put this together:
__________________
Old 07-21-2009, 09:39 PM   #7
Quote:
i can't promise anything about the Q calipers, but the only issues i saw with the J30 calipers on the maxima torque arms was there was some minor contact with the pad shims. the set-up would need to be maxima rotors and torque arms and Q45/J30 calipers
and for those that use the complete Q45/J30 set-up, i highly suggest getting 4 or 5 millimeters machined off the diameter. from what i can tell, you can safely take off as much as 6 but that's cutting it VERY close.
__________________
lol, u could
Old 07-21-2009, 09:44 PM   #8
Quote:
it's possible to use the Q rotors with the maxima torque arms but it's a VERY tight squeeze. you'd be touching with any vibrations or the slightest warp in the rotor.
and fwiw the torque arms determine which pads you use, not the calipers.
__________________
lol, u could
Old 07-22-2009, 08:02 AM   #9
Wild for Width
Fr33way™'s Avatar
Quote:
The Q45 caliper over the Maxima rotor is not a great idea because the piston would have to travel further just to make contact with the rotor and when the pads are worn down it would possibly become over-extended, and like you said you would be using Maxima pads with less area on a smaller rotor.
Yeah, I did 3mm and it is about as close as you can get.
I thought that's what I was saying, I know where the pads go mane.
__________________
Old 07-22-2009, 09:28 AM   #10
Former Vendor
wait. are you using your maxima torque arms?
Old 07-22-2009, 10:18 AM   #11
haha, me too. that's why i said at least 4 would be a better idea.
yeah, i reread your post, my bad.
Quote:
haha, noooo. like i said, they BARELY fit.
__________________
lol, u could
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
