If you have them already, just try it. It doesnt take more than 10 minutes to take off the calipers and rotors and see if the new ones bolt on. While you have both of them off, just put them side by side and compare size differences. (weight too if you have a scale)
The worse that can happen is the altima ones dont bolt on and you put your old ones back on.
__________________
01 I30, [5 speed swap][4th gen pedals and master cylinder][OEM clutch][OEM flywheel][ksport coilovers front, D2 coilovers rear][10k hid headlights and fogs][custom WAI][cattman exhaust][tenzo type-M, 19x8.5 +17F, 19x10 +22R][300zx calipers][Cobra 13" drilled and slotted rotors]
5 speed swap myths BUSTED:
1. Both driver and passenger side AUTO axles work fine.
2. AUTO flywheel bolts work fine.
