Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 04-23-2009, 12:45 PM   #1
Wild for Width
Fr33way™'s Avatar
Send a message via AIM to Fr33way™
Removing caliper pistons without air.
This applies to the 90-96 Q45 (G50) dual piston calipers.
-Seperate the torque member from the caliper by simply sliding it off.
-Begin by removing the outer rubber seal/boot. I was able to do this by hand but if they are stubborn you can use pliers with a towel.
-With the rubber piece off, use a thicker, decently long flathead to fit in the groove where the boot fit in place.
-Use the body of the caliper to pivot the screwdriver outward moving the piston with it.
-Move each side of the piston 5-10mm at a time exposing about 25mm of the piston.
-The piston will glide slowly but if it just DOES NOT MOVE do not FORCE it to the point of damaging the recess that the boot sits it.
-After you have significant meat to work with, use a set of pliers, a towel and decent grip strength to rotate the piston back and forth.
-As you rotate the piston back and forth pull outward from the caliper.
*Again* This applies to MY G50 calipers because I am lame and don't have air to just blow the pistons out with.
__________________
Fr33way™ is offline   Reply With Quote
Old 04-23-2009, 05:50 PM   #2
I'm needing a caw
Jeff92se's Avatar
I'd be scared to scratch something
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 04-24-2009, 12:20 PM   #3
Me too. I'm about to rebuild a set of calipers and I think my friend has a compressor somewhere, you can also just use a bike pump with a cone nozzle...
But it's good to see you're still around and kicking (Justin is it?)
MorpheusZero is offline   Reply With Quote
Old 04-24-2009, 01:57 PM   #4
Wild for Width
Fr33way™'s Avatar
Quote:
That's what the towel is for brah!
But yeah I was very careful, like I mentioned in the first post if the piston is not gradually moving to just STOP rather than really go to town on it and risk damaging it.
Morph what up man! What are you rolling now? I hope it's on 9"+
__________________
Old 04-24-2009, 04:17 PM   #5
Quote:
Try 4 lug 14x6
The good news is it's 2900lbs with me in it, and 48% of that is over the rear axle, which is coincidentally also the driven axle.
Old 04-25-2009, 06:09 PM   #6
Wild for Width
Fr33way™'s Avatar
Quote:
Originally Posted by MorpheusZero View Post
Try 4 lug 14x6
Sounds like the kind of kind of car where 205's are running wide
Get that weight down!
__________________
Old 06-08-2009, 08:59 PM   #7
Not a GM sack rider...
why can't you just remove the caliper from the member, sit in the car, press the brakes, and watch the pistons fall out?
DAVE Sz is offline   Reply With Quote
Old 06-08-2009, 09:31 PM   #8
Send a message via AIM to djfrestyl
How you gonna watch the pistons coming out if you're sitting in the car?!
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Clifford / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Click here for info!
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Click here to see a solution!
djfrestyl is offline   Reply With Quote
Old 06-09-2009, 08:16 AM   #9
mirrors my friend, mirrors...
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
