Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 03-22-2009, 11:14 AM   #1
Brembo rotor dimple's
I recieved two front brembo blanks for my 4th gen and one has two dimples on the rotor while the other doesn't. Are both rotors supposed to have these dimples? Also one rotor has brembo stamped on it and the other doesn't. Should both have brembo stamped on them?
__________________
SHIFT_NFS
Quickywd01 is offline   Reply With Quote
Old 03-22-2009, 01:05 PM   #2
STFU n00b!
One is Brembo. The other isn't.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is online now   Reply With Quote
Old 03-22-2009, 01:50 PM   #3
Doggah Bite...
MadMaxSE-L's Avatar
Yeah, those should definitely not be there...
__________________
--1997 Maxima SE, White Frost Pearl Ext/Black Int/5spd: 15% Tint all around,Optima Red Top Battery, upgraded audio, Brembo Slotted Rotors all around, SS Brakelines, CE SS Y-Pipe, SS clutch line Place Racing CAI, K&N Conical Air Filter, 18x8 Sport Edition KV5's
Audio- (HU)Alpine CDA-9887 / (MIDBASS)Seas CD18RE / Eclipse XA4000 / (TWEETS)Seas 27TFFNC/G / Orion CS100.2 / (SUBS)2-TC Sounds TC2000 12"s, ported tuned @33hz, 2-Eclipse XA4000s
MadMaxSE-L is offline   Reply With Quote
Old 03-22-2009, 01:55 PM   #4
Send a message via AIM to ChrisMan287 Send a message via MSN to ChrisMan287 Send a message via Yahoo to ChrisMan287
Quote:
Quote:
__________________
http://www.cardomain.com/ride/3135334______http://www.cardomain.com/ride/3171620
4th gen. items FS:
-2 sets of 9004 bulbs ($10/set).
-1157 red LED bulbs ($5).
-OEM bumper lights ($20).
-License plate light assembly ($10).
-PM me if interested.
-Shipping/PayPal fee not included..
ChrisMan287 is online now   Reply With Quote
Old 03-22-2009, 03:07 PM   #5
I'm going to RMA the dimpled one. Autobarn sucks.
__________________
SHIFT_NFS
Old 03-22-2009, 05:04 PM   #6
STFU n00b!
The dimples are wear indicators. When they're worn smooth, the rotor is done.
__________________
Old 03-22-2009, 07:55 PM   #7
Doggah Bite...
MadMaxSE-L's Avatar
WTF - what ever happened to having the minimum thickness stamped on the outside of the rotor???
__________________
Old 03-22-2009, 08:53 PM   #8
ive got demples on my brembo rotors... i thought they were just wear indicators also....
__________________
MROTH is offline   Reply With Quote
Old 03-22-2009, 10:13 PM   #9
Doggah Bite...
MadMaxSE-L's Avatar
None of the 4 Brembos on my Max have them, but they are slotted so that may be the reason...
I just think its kind of retarded to put dimples in the friction surface of a rotor when most every other rotor on the planet has minimum rotor thickness stamped on the outer edge. If you have the equipment to turn rotors, you have the equipment to measure their thickness and tell they shouldn't be turned...
__________________
Old 03-22-2009, 10:49 PM   #10
What confuses me is why the rotor with dimples has no brembo stampings on the side while the rotor with out the dimples does have brembo stamped on it.
__________________
SHIFT_NFS
Old 03-23-2009, 07:48 AM   #11
I called brembo at 17347375823 and I was told that the "easy check" rotors have "notches" so that you can check when the rotor is worn out. This is the stupidest thing I have ever heard. That's what micrometers are for. I was also told that depending on where the rotors are made they may or may not be stamped with brembo on the side. I hope these are better than the cheap rotors at parts stores because it doesn't sound like it. Can't wait till next week to put it all on. Thanks everyone for your help.
__________________
SHIFT_NFS
Old 03-23-2009, 07:59 AM   #12
The dimples may be there in order to assess rotor thickness without having to pull the wheels. Not for determining how much you might still be able to cut. That would benefit periodic state inspections and could also keep individuals from being sold rotors unnecessarily.
Norm
__________________
Automatics need not apply
'01 20th AE Maxima, 5 speed, wife's DD, stockish
'08 Mustang GT, 5 speed, my DD, slightly un-FStock
'95 626 LX-V6, 5 speed (spare DD and weenie EP autocross car, Prepared just enough, sometimes)
'79 Malibu, 5 speed (retired, awaiting decisions . . .)
Norm Peterson is offline   Reply With Quote
Old 03-23-2009, 10:25 AM   #13
STFU n00b!
Yes. The dimples help the 'average Joe mechanic' keep his own car up and running vs. having to pull the rotor off and take it to a shop or parts store to check the rotor thickness.
MOST people do not have a way to properly tell rotor thickness.
It's easy enough to remove our rotors to check, but some others (Honda, early Z, Chevy, etc) are a royal PITA to remove because they're integrated with the wheel hub and can't be easily removed from the car to check.
The dimples are a really good idea actually.
And yes, the slots in most aftermarket rotors are usually about the same depth as the rotor's minimum thickness. when they wear the slots off, it's time for new rotors.
__________________
Old 03-23-2009, 01:36 PM   #14
Send a message via AIM to mist max2000
they are prob both brembo.. you got one old product and one of their newer products in tersm of shelf life..... i would still bring them back and want 2 of the same for peace of mind..
__________________
| 2002 6speed|Progress RSB|Illuminas|Progress Springs|Clear Sides|Crome DoorTrim Blackout|Grill-tech lower Valence insert|HID fogs|eyelids|Hella Supertones|HD CatchCan|Berk Intake w/ Apexi filter|
Parts I own waiting to go on:| stillen classic kit|GenI cattman headers|Test Pipe|SAFCII
mist max2000 is offline   Reply With Quote
Old 03-23-2009, 10:25 PM   #15
STFU n00b!
Every Brembo disc I've ever bought has had brembo engraved along the outer edge.
__________________
Old 03-24-2009, 07:46 AM   #16
When I called I was told not all of them have it depending on where they were made. Seems kind of cheap not to have it on there for a company like brembo. Makes it seem like a made in china product.
__________________
SHIFT_NFS
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
