Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Question about Mix Matchin Springs
Old 03-14-2009, 07:19 PM
WhoDatBuuL's Avatar
Ok People here's the deal , I gota 5th gen and i got some tokico illumina that i just brought, and i lookin to get some springs . Now i had my mind on some H-Techs FOR a very time . But here's the problem im customizing my trunk meanin ima have some weight in the trunk , so i was thinkin about mix matchin my springs . Maybe get some front H-Techs and use my fact. springs in the back, prayin that it well level perfect wit the front . Or maybe getting some maxspeed ones.IDK , I dont wanta sag in the back ...im goin insane tryin to do this, So i was lookin for some ideas and help. So PLEASE help a fellow orger out .... THANX
WhoDatBuuL is offline
Old 03-17-2009, 08:38 AM
Norm Peterson's Avatar
To keep the car's original ride behavior, you'll want slightly stiffer rear springs for both reasons (stiffer front springs and heavier trunk load). Plan on running the rear Illuminas at a higher setting than the front. For the front, '2' isn't enough to keep that end from constantly heaving up and down when the highway is not dead-flat (think I-95). My opinion with even the OE springs.
One of the things you're trying to avoid is having the front and rear suspensions always moving in opposite directions (nose up/tail down, nose down/tail up). Most people don't like having their heads constantly being tossed forward and backward like a bobblehead doll even if it's only by a little.
Norm
Norm Peterson is offline
Old 03-17-2009, 08:41 AM
Kevlo for President
Kevlo911's Avatar
Do OEM in the rear since it will be heavy in the rear
Kevlo911 is offline
imported_Nismo_max
02-17-2016 03:39 AM
Maximan190
12-16-2015 06:01 AM
Stagnet04
09-13-2015 09:32 PM
pjgreek
09-09-2015 09:30 PM
Maxboy23
09-04-2015 06:04 PM
Quick Reply: Question about Mix Matchin Springs
