Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-05-2009, 09:45 PM   #1
Send a message via AIM to mastere954
does the 26mm caliper same fitting as 30mm??
do both the 26mm and the 30mm 300zx calipers have the same brake line fittings?
__________________
Mods- injen CAI/ Stillen Y/ Stillen B/ Megan Racing Hi-flow Cat/ Greddy SP muffler/ MEVI/ Fidanza Flywheel/ Unorthodox Racing UDP/ JWT ECU/ NWP Thermal Intake Spacer Kit/ 300zx bbk (jeffs brackets, 13" cobra slotted rotors)/ B&M STS
mastere954 is offline   Reply With Quote
Old 01-06-2009, 10:01 AM   #2
STFU n00b!
Yes. Everything is identical except the opening width and the length of the slider pins and spring (because the opening is bigger).
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 01-06-2009, 10:18 AM   #3
I'm needing a caw
Jeff92se's Avatar
26mm calipers will only work for the 300z rotors. If you want to use the big rotors, it won't work.
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 01-06-2009, 12:06 PM   #4
^^^ yea i know thats the setup i have now but i just bought some 30mm and the rtp cobra rotors, already have the lines, and ill be buying the brackets off of you in about a week
__________________
Old 01-06-2009, 12:12 PM   #5
btw the ss lines i have now with the z32 conversion also work with my my stock maxima calipers!! i thought they were different fittings? i remember i installed the lines, connected the z32 calipers then my wheel wouldnt clear so i left the sslines hooked up and connected the stock maxima caliper back while i got spacers. and the calipers worked just fine!! so what exactly is the difference in the 300zx fitting?
__________________
Old 01-06-2009, 04:30 PM   #6
STFU n00b!
The Maxima caliper is designed for a banjo fitting. The Z caliper is designed for an inverted flare fitting.
Just because one *might* fit in the hole and work for a short while in place of the other, eventually it's going to have problems by coming loose or leaking.
Look inside that Maxima caliper. do you see the inverted flare mating surface for the Z line? I didn't think so. That mating surface is what technically seals the fitting, NOT the threaded portion.
Look on the Z caliper. do you see a flat, machined surface and ears on the outside of the caliper to attach the banjo bolt and copper crush washer? I didn't think so.
Given enough vibration, the banjo bolt will eventually twist against the Z caliper and leak. You're also damn lucky if you ever get it to seal since the copper crush washer sits against cast aluminum/iron on the Z caliper vs. a machined steel mating surface on the Maxima caliper.
the ONLY similarities in the fittings is that they use an M10x1.0mm thread on them.
__________________
Old 01-06-2009, 09:09 PM   #7
ok now i understand. very helpfull info matt93se. thank you
__________________
Old 01-30-2009, 07:39 PM   #8
Send a message via MSN to 96blkonblkse
My friend with his S13, has the Z front calipers, and he has used his stock lines which are the same as the maxima. Hes been on the same calipers for over 4 years, tracked the car so hard hes boiled the fluid, warped, rotors, destroyed pads, and hes never had his line leak.
Im not saying thats the proper way, because it is dangerous, go out and buy some S13 to Z32 conversion lines. I got mine from PDM racing, they are the same for the maxima, smae lenght and everything.
__________________
98 Maxima SE 5MT - For sale, My first true love
00 E39 M5 Alpine White/Silverstone 6MT
19x10.5 Volk CE28N T/A, 275/30/19 Pilot Sport PS2's, AFE Intakes, ESS Tuning Reflash, Tubi exhaust #36
96blkonblkse is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
