Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 01-05-2009, 05:08 PM   #1
doesn't twitter
rxm6's Avatar
FSTB question
Summary: Why do all the FSTB's available for the max have a bolt to attach the bar to the strut mount while other FSTB's for other cars have a single solid piece?
OK the reason for this question is two-fold. Firstly, in my head, it seems to me that a bolt system leaves room for vertical mount movement, but would prevent horizontal movement. Whereas a single solid welded piece would hold the struts firmly in place. Secondly, I ask because my BMW has a single solid welded piece and I looked online and could find no solid strut braces for the max including the expensive ones from stillen and cattman. I immediately thought of putting one together, but then thought I should ask here to see if there was a technical reason.
rxm6 is offline   Reply With Quote
Old 01-05-2009, 08:33 PM   #2
IMO the FSTB's with an adjustable bolt allows proper alignment with caster, toe in or toe out so your tires can wear evenly. If you have a solid one piece FSTB, then your tires could wear uneven and cause damage at a later date. I am by far no expert, but again just my opinion.
__________________
""If a man does his best, what else is there?" - General George S. Patton (1885-1945)"
cfr94 is offline   Reply With Quote
Old 01-05-2009, 09:10 PM   #3
My axles cry for mercy...
essential1's Avatar
Quote:
I could be wrong, but that doesnt make much sense to me at all. The only thing the FSTB bolts to are the 3 strut mount bolts above each strut tower. These are stationary bolts. They have no play no matter how you look at it. The purpose of a Front strut tower brace is just to help eliminate chassis flex to aid in handling.
Back to the topic at hand though. Looking at my FSTB, which does have a bolt that allows for vertical (more so a pivot) movement. Even though this is there, the fact that it is bolted to the strut tower bolts mean that it is physically impossible for this vertical (or pivot) action to take place. The strut tower bolts would litlerally have to be loose for this to happen. Either way, tighten the hell out of that bolt. Now as far as the strength of the materials used? Cant speak for that, but that is a completely different topic. That could definately contribute to flex.
For reference, i'm using a cheapo otto FSTB that cost me $30 on ebay a few years ago.
Again, i could be wrong. And please correct me if I am. I'm no expert.
__________________
01 I30, [5 speed swap][4th gen pedals and master cylinder][OEM clutch][OEM flywheel][ksport coilovers front, D2 coilovers rear][10k hid headlights and fogs][custom WAI][cattman exhaust][tenzo type-M, 19x8.5 +17F, 19x10 +22R][300zx calipers][Cobra 13" drilled and slotted rotors]
5 speed swap myths BUSTED:
1. Both driver and passenger side AUTO axles work fine.
2. AUTO flywheel bolts work fine.
essential1 is offline   Reply With Quote
Old 01-06-2009, 12:23 AM   #4
doesn't twitter
rxm6's Avatar
Quote:
That's my thought though is that they can pivot. In my mind, when a picture a car going into a hard turn, I know that the outside wheel is carrying the load and as such, exerting much more force on the top of the strut assembly. Vice versa on the other side, the inside wheel is exerting much less force than normal. So I would think that the inside strut mount would drop lower and the outside strut mount would rise higher, thereby, creating the pivot I'm imagining.
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
