Advanced Suspension, Chassis, and BrakingTalk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access
to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Wanted to see if anyone had ideas on the 300zx calipers. The braking is superb, but on the passenger side on slow braking, there are very loud pops on engaging the brake pedal and gets louder as I press it. No noise on a stop like I would here with piston locking or the pins rubbing creating a noise. Could it be the rotors or the pads? It only happens when the system is warmed up as well. these are rebuilt calipers too by the way. Do I need to bleed the system again?
Any thoughts?
__________________
Dan formally coitaltie
Nismo CAI- Nismo Ray's Engineering 19's- Nismo full catback exhaust-Nissan 300zx TT aluminum calipers- Progress RSB- Racingline V2 endlinks rear- Progress lowering springs- KYB GR2 struts and shocks- Racingline FTSB OEM look- Active Tuning custom grounding kit- Active Tuning S4.1 grill- Custom Enterprise Y pipe- Unorthodox Racing Underdrive Pulley- Optima Red Top- JL W3V3- JL 500/1 v2 amp
Check your pads/rotors...I own a 300zx Twin turbo and the braking on these cars are awesome. Perhaps something is either loose or needs to be lubricated
try lubing the slider pins and see what happens. can't hurt.
Will do, thanks
Quote:
The braking is awesome, the noise is not.
Will keep posted
__________________
mine does the same thing. I was wonering about it the other day in the drive thru at Carls JR. I was inching up and put on light pedal pressure to stop and heard pop....pop....pop....
It kinda feels like theres resistance then a slight release of that resistance, then resistance....
A lot of times the pads will tick or creak as they rub against the slider pins if there's no lube or anything on them and it's metal on metal.
I hear a little of everything, snap, crackle, pop,lol. Subscribing to this thread. Matty can you confirm these gold pins are the slider pins mentioned in your quote?
Thanks in advance.
--Roger
__________________
|| B&M Short Shifter || Ksport Kontrol Pro || Stillen Front & Rear Strut bar || Stillen Sway Bar
||Smoked Side Markers || Berk Intake w/ AEM Dry Air Flow Filter || 35% Tint || Cattman Headers
|| MR B-Pipe w/ 5.5 Muffler || Place Racing Motor Mounts || ES Lower Front Subframe Bushing
|| CE Test Pipe || Boss Chen Shifter Bushing|| 17" G35 Coupe Rims || 300zx BBK
|| 5.5 Front End Conversion Cardomain MyspaceExhaust Clip DOWNLOAD MY NEW MIX HERE
I have a hard time believing that a little lube on the slider pin will fix it, BUT from reading your posts in other threads I can see that you know your sh*, so my stubborn *** will def. try it soon. Ill update you with results and possibly a soundclip if I can figure out a way to mic it accurately.
What do you recommend to lube it?
**edit** I also believe the sound originates from the pass side
well dismantled the brakes and cleaned the hell out of the pistons and around the seals (didnt take the pistons out). I re greased the back of the pads and reversed them as well and re greased the pins. No noise as of yet but Im still waiting. So far I believe it was the pads but time will tell.
__________________
