Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-13-2008, 03:37 PM   #1
Replacing Front Suspension?
So, for the Holidays, I plan on getting some suspension pieces for my car.
Specifically, I want shocks (Illuminas) and springs (Eibachs). However, I have a rather limited budget, so the plan is to order only front shocks and springs.
How would this affect my handling?
Note: I may consider getting rear shocks as well, but no rear springs for sure because I think the rear ride height is fine, and the drop makes it look saggy...
__________________
muravei2 is offline   Reply With Quote
Old 12-13-2008, 09:25 PM   #2
Thinks he owns a sports car
That'll be a pretty dramatic change in rake. What about the headlight alignment?
BEJAY1 is offline   Reply With Quote
Old 12-14-2008, 08:19 AM   #3
STFU n00b!
You have to buy the springs as a set, unless you can find someone here on the .org that's split a set already.
I know a few guys are mixing H&R on one end and Eibach on the other to keep the rake looking decent. Either way you're going to want to put good shocks on both ends. put your money there if you have to spend it somewhere. It'll at least make the car fun to drive.
__________________
04 G35 Sedan 6MT- The DD
96 240SX 5 speed- The track toy
93 Maxima SE 5 speed- retired 1-5-09
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 01-07-2009, 02:04 PM   #4
ThurzNite's Avatar
Send a message via ICQ to ThurzNite Send a message via AIM to ThurzNite Send a message via MSN to ThurzNite Send a message via Yahoo to ThurzNite
buy shocks all around, get the springs later. Like Matt implied, this's a safety issue, you're safer changing all the struts at 1 time, and doing springs later, rather than springs first, or fronts first.
Dr J
__________________
Dr J
ICQ/AIM/MSN/YIM/Google/Skype: ThurzNite
Email: ThurzNite@Yahoo.Com
MCC member #27
Show your support! Custom MAXIMA.ORG lanyards! Link
ThurzNite is offline   Reply With Quote
Old 03-12-2009, 01:15 PM   #5
Send a message via Yahoo to chuckd2k
New questions
Quote:
Dr J
Sorry about bring up an old thread, but my question is along the same line.
I'm replacing springs and struts, and have them already; H-Tech/Illuminas. How necessary is it to replace the front and rear strut mounts and front strut bearings? My max has about
88k miles, I bought it used with about 35K on it about 5 years ago.
__________________
Corner Markers / Falken Ziex ZE-912 / Tein H-Tech Springs / Tokico Illumina
chuckd2k is offline   Reply With Quote
Old 03-12-2009, 02:44 PM   #6
ThurzNite's Avatar
Tough question... For the fronts, does suspension squeek or bind when you turn? If not, inspect the bearing and mount when you take it apart. The bearing's not incredibly expensive @ the dealership, and they should be in stock. The mounts are pricier, and I don't know if they're always in stock. However I'd just get the mounts somewhere with lifetime warranty for cheaper than dealership anyways.
I changed my bearings when I lowered my car at about 120,000 miles. The originals weren't worn, and I coulda cleaned and lubed them and put them back in if I wanted.
I replaced my mounts at about 190,000 miles, mostly because I was driving my car sideways (which probably wore out my hubs that I replaced shortly before the mounts). Otherwise, they wouldn't have worn out so prematurely.
Dr J
__________________
Dr J
MCC member #27
Old 03-12-2009, 03:46 PM   #7
Dr J
There is some squeeking when I turn or when I'm driving slow, but that could be because the cv boot is busted; not sure for how long. But let's just say that the squeeks were not because of the axel/busted cv boot, would you say that it would be because of a worn out bearing more so that the mount? (in your opinion of course.)
__________________
Old 03-12-2009, 04:49 PM   #8
ThurzNite's Avatar
Yes. When my mount wore out, it would clunk over bumps/dips and while in constant radius turns. The bearing would squeek or bind only as you're turning the steering wheel.
Dr J
__________________
Dr J
MCC member #27
Old 03-12-2009, 06:38 PM   #9
Dr J
Thanks Dr J, this info helps a lot.
__________________
Old 03-12-2009, 10:03 PM   #10
ThurzNite's Avatar
As for the rears... Just swap the struts and springs, make sure your spring isolator is in good condition or else it'll squeek (same for the fronts), and you're good to go.
Dr J
__________________
Dr J
MCC member #27
Old 05-17-2009, 08:18 PM   #11
SOME HELP & ADVICE NEEDED!!!
I wasnt sure where to post this so sorry if in the wrong subforum
I currently have a 96 SE...I have the stock honeycomb 16in wheels and all stock suspension and whatever shocks/struts/coils it came with etc...
I want to purchase the MOMO GT-Rs 19in wheels and the vredestein sessanta tires in 225/35/19 and 235/35/19...
I just want to know if I should OR need to get new shocks/coils etc…What adjustments will I have to make to the suspension and stuff?
Thanks Guys
C1imax is offline   Reply With Quote
Old 05-19-2009, 08:54 AM   #12
Send a message via AIM to djfrestyl
Wheels don't dicate suspension. You can change your wheels without any suspension consideration, provided you're not going overly large like getting 22's or whatever.
It will probably just look like it needs a drop moreso than it already does. If you have specific questions, PM me. I'm local and can perform your suspension upgrade, should you choose to go that route.
__________________
Eclipse CD3000
Audison LRx 6.9-> Rainbow SLC 265.03, (2) 10" DLS Reference W710's
Knukonceptz 1/0awg / Cascade VB2Max / Stinger / Clifford / Optima
Exterior: stock-tastic.
I can install your suspension and stereo. Click here for info!
Is your spare tire cover sagging? Trunk have a big DIP in the middle? Click here to see a solution!
djfrestyl is offline   Reply With Quote
Old 05-19-2009, 11:03 AM   #13
ThurzNite's Avatar
Agreed, unless you start doing something wild like a 3" drop, tuck, flared fenders, rolled fenders, flush mount, etc etc. At that time, you may consider a wheel/tire setup out of the standard plus size range.
Dr J
__________________
Dr J
MCC member #27
Old 05-20-2009, 09:06 AM   #14
Question here.. For some reason I cannot post a new thread.
My roommate has an Altima Se-r... he bought it with a drop.. They are Tein S-techs springs. Would the s-techs on his altima fit on my 01 Maxima GLE??
DivineMight is offline   Reply With Quote
Old 05-20-2009, 09:27 AM   #15
Probably not. Spring rate, size, shape are likely different.
__________________
Eclipse CD3000
Old 06-10-2009, 12:45 AM   #16
It would be a lot better if you buy your springs as a set, instead of just upgrading your front suspension. That way you are much assured of the performance.
__________________
Hypertech Performance Module
thomatt12 is offline   Reply With Quote
Old 06-10-2009, 05:27 AM   #17
Send a message via AIM to Tippy Toes Send a message via Yahoo to Tippy Toes Send a message via Skype™ to Tippy Toes
If you want to do it right, I would personally wait to do it all together. Unless you're doing it yourself, it'll cost AAAAL to install shocks then go back and install springs later on. If nothing is broke wait it out. .02
Tippy Toes is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
