Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 12-05-2008, 01:46 AM   #1
Eibach/ Illuminas now my car is a drift car
Well its not really a drift car but the rear end comes out on me all day long. I have GoodYear GSD3 an adjustable RSB and eibach/ Illuminas with the front set to 3's and back set to 4's. I live in a place where the roads are complete Sh%* so I cant set to a firmer setting. Everytime I go through some turns I notice my rear ends slides out on me, any tuning tips you guys maybe I should set the rears to a softer setting or is the rear sway bar adjusted to aggressive, the brackets are currently set right past the brake line. Any tips greatly appreciated and thanks for your time.
__________________
5.5 Gen
6 Speed
Modded
Reket is offline   Reply With Quote
Old 12-05-2008, 09:37 AM   #2
sciff5's Avatar
Send a message via AIM to sciff5
Quote:
I almost find this hard to believe.. If theres anything a Maxima is not.. its tail happy, although I did find after installing the same setup I was able to rotate the rear end very slightly under very hard cornering, but deff nothing I would consider tail happy.
To address your issue. I dont know what RSB you have but very generally a very tight RSB will reduce your traction out back. Try loosening or taking off the RSB and see if that makes any difference.
__________________
2002 Infiniti I35 Sport Package
Progress RSB, Otto FSTB, Michellin Pilot Sports A/S, Eibach Springs, Illumina Shocks, Fx35 Brakes Rotors/Calipers, Custom SFCs
1989 Mazda Rx7 GTU
Ls1/T56 W/ Ported TB and Full Exhaust
11.67 at 120mph 3rd time out
My Car Domain Page
http://www.cardomain.com/ride/2340299
sciff5 is offline   Reply With Quote
Old 12-05-2008, 09:38 AM   #3
'Trynna' is not a word
mtrai760's Avatar
New tires?
__________________
98 SE - VQ35
2k SE - Stock... pretty much
Boost, juice, conversions, been there, done that.
mtrai760 is offline   Reply With Quote
Old 12-05-2008, 01:57 PM   #4
Nope tires have been on the car for less then a year.
__________________
5.5 Gen
6 Speed
Modded
Old 12-05-2008, 08:06 PM   #5
Crusher103's Avatar
Send a message via AIM to Crusher103
Id try disconnecting one side of the RSB and see if it still very tail happy, does it feel unstable at all while cornering?
__________________
96 Black I30t VLSD 5spd A.K.A Big Black(has a bad attitude)
Eibach springs//Koni yellows//Koyo OE Radiator//F&RSTB//Black retro'd Cefiros w/E46 Bi-Xenon projectors/ZKW clear lense'd//Budget y-pipe//test pipe//Apexi WS2//WAI//Grounding kit
3.5 in progress
CLICK ME FOR WHEELS FOR SALE AND TIRES FOR CHEAP
Crusher103 is offline   Reply With Quote
Old 12-05-2008, 11:52 PM   #6
I R The Law
The Law's Avatar
Send a message via AIM to The Law Send a message via MSN to The Law Send a message via Yahoo to The Law
I don't know what you're experiencing cause I've had that setup on my car for 3 years and I have never had such a problem.
__________________
Progress Coilovers, Otto racing FTSB, Stillen RSTB, Progress RSB, Window tint 20%/5% All Around, Clear Side Markers, Berk w/ JWT Filter, SS brake lines, 350z Ray Rims, Maxxtuning front lip, Stillen sides and rear lip, 300z BBK, SSIM, Xtreme Eyelids, NWP Thermal Intake Manifold Spacer, Truax SFCs, E46 DDE's, Clear Corner, Rainbow speakers, Eclipse AVN 6610, Hifonics amp, Epic 160, HS Headers, Cattman 3" catback
The Law is offline   Reply With Quote
Old 12-06-2008, 08:07 AM   #7
sciff5's Avatar
Plus I have proxes4 with about 55k on them so they are pretty well done and I still dont have that issue, nor should normal wear create an oversteer condition because if anything, these cars wear the front tires more than the rears which should make understeer more prominent.
Like I said before the only thing I can think of is the rear sway bar.. other than that I would try loosening the rear struts a click.. but if the rear sway bar doesnt fix it.. I dont know what to tell you.. Theres not a lot on these cars thats adjustable so we're not working with tons of variables like a race car.
Did you change anything else on the car before you started noticing this?
Or was it a pretty sudden and immediate change after the springs/struts install?
__________________
1989 Mazda Rx7 GTU
My Car Domain Page
Old 12-06-2008, 08:51 AM   #8
Send a message via AIM to mist max2000
did you buy the springs new or used?.. who installed them? maybe you got screwed maybe you have stock/not eibach springs on the front and the back is wicked stiff with eibach springs? know what im sayin?.... only thing i can think of.. cuz like others have said not much is adjustable.....do u have an RSTB of FSTB on?
__________________
| 2002 6speed|Progress RSB|Illuminas|Progress Springs|Clear Sides|Crome DoorTrim Blackout|Grill-tech lower Valence insert|HID fogs|eyelids|Hella Supertones|HD CatchCan|Berk Intake w/ Apexi filter|
Parts I own waiting to go on:| stillen classic kit|GenI cattman headers|Test Pipe|SAFCII
mist max2000 is offline   Reply With Quote
Old 12-06-2008, 08:19 PM   #9
Offset Is Everything.
Send a message via AIM to MrDicks95SE
Quote:
sturt bars only aid in chassis bracing/stiffening.
MrDicks95SE is offline   Reply With Quote
Old 12-06-2008, 08:40 PM   #10
Try firming up your front struts (or loosening up your rears) by two clicks, or try removing the RSB (or just unhooking one side).
With my rear struts on full firm and the fronts on 1/2 way (and a RSB) I can definitely feel the car's tossability... feels like it corners pretty neutrally, under neutral throttle there is very little understeer to the point where it feels I'm almost oversteering, but I've never had to countersteer yet unless I was trail braking.
MorpheusZero is offline   Reply With Quote
Old 12-24-2008, 07:01 PM   #11
You must have a pretty meaty RSB to create overstear on a front wheel drive car.
Dive n Drive is offline   Reply With Quote
Old 12-26-2008, 02:15 PM   #12
hmm u ever fix this?,... maybe while installing u f'd up the brakes,.. and now u have a semi sticking capiler?,.. or maybe your e brake is causing it to stick.. that would help oversteer but still not like u say.. idk..if ur near snow i sure hope u dont drive in it like that lol
__________________
Old 12-28-2008, 09:53 PM   #13
Could be your battery
__________________
gene_vq03 is offline   Reply With Quote
Old 12-31-2008, 06:55 PM   #14
retired moderator
irish44j's Avatar
your tires must be garbage. I ran Eibachs/Illuminas with a RSB for well over a year (before adding other things) and never lost the tail, even in heavy autocross maneuvers.
You sure you're actually losing the tail, because with the beam axle/"panhard bar" setup you might just be feeling the axle shift, which gives the feeling of the tail sliding but the tires aer actually gripping fine.
Stiffen up your front struts. I always ran fronts at 5 and rears at 3 or 4....stiffer in back creates more oversteer.
__________________
Sold: 2000 Maxima SE - PR Intake - Frankencar CB - Truax SFCs - Wilwoods - Eibachs - Blehm LTB - Cattman Ypipe
Stillen RSB - RSTB - FSTB - ES Bushes - G wheels - Raxles - Mach1 lip - Illuminas - and plenty more
New: 2009 WRX - Cobb 25mm FSB - Perrin 19mm RSB - SPT Catback - STi springs - Rota SDRs - RalliTek Endlinks
irish44j is offline   Reply With Quote
Old 01-01-2009, 08:07 AM   #15
Send a message via AIM to ColdSHO
even with my jic rears set on theyre firmest with 8k springs i dont get crazy oversteer. i think my cars rather neutral. the rear can be swung out but its not easy nor usually benefical to me. perhaps its just that ur not used to the new way the car feels. everytime i do suspension work i have to relearna bit how the car reacts to the road.
__________________
Shift_Afganistan deployment 08-09 Of the troops, for the troops!
05 sti, snorkel stock, small mods on the pipeline
89 SHO 5spd k&n maf clutch/flywheel. 400lbs weightlose and counting
00 Maxima se 5spd - SOLDEU,JIC,SFC,Hotshots,frankencar,BBK,Rota/nittos,cf hood/trunk, stillen lip
95 Maxima se 5spd-d2s,greddy sp2,enkie,cf lip, y pipe ready to install
93 SHOatx - gutted being parted out
ColdSHO is offline   Reply With Quote
Old 01-01-2009, 10:09 AM   #16
Send a message via AIM to Drockb418
i only have that prob trashing the living blank out of it on the auto x... to the point were im tiring to do it for fun. or on a highway on ramp were it gets tight at the last min.
__________________
1998 318 ti,s50 swap, m3 brakes, green house control arm bushings,H&R race springs with bilstein struts,ASA wheels,Magnaflow catback ,sparco seats,two 10” JL audio subs,3.73 rear end,euro headlights and more to come![/center]
Drockb418 is offline   Reply With Quote
Old 01-05-2009, 03:27 PM   #17
doesn't twitter
rxm6's Avatar
Quote:
Agreed. I can purposely lose the tail with DD tires on wet pavement, but I have never lost the tail before hitting understeer in performance situations (even with stickies on the front and DD's on the rear, ahh the poor college days )
rxm6 is offline   Reply With Quote
Old 01-07-2009, 02:01 PM   #18
ThurzNite's Avatar
Send a message via ICQ to ThurzNite Send a message via AIM to ThurzNite Send a message via MSN to ThurzNite Send a message via Yahoo to ThurzNite
The guy answered his own question/concern. The roads suck...he's getting bump oversteer, not the oversteer most of us encounter on the track or auto-x. His rear is too stiff, as many have pointed out. So loosen up the rear... softer setting on the illuminas, remove the RSB, drop rear PSI a bit.
Dr J
__________________
Dr J
ICQ/AIM/MSN/YIM/Google/Skype: ThurzNite
Email: ThurzNite@Yahoo.Com
MCC member #27
Show your support! Custom MAXIMA.ORG lanyards! Link
ThurzNite is offline   Reply With Quote
Old 01-11-2009, 05:00 PM   #19
Send a message via AIM to a33i30
this happened to me yesterday and i have stock shocks/springs. i was REALLY giving it everything and it was on a mountain road over a crest. But I was supprised it actoully oversteered, wasn't expecting that.
a33i30 is offline   Reply With Quote
Old 01-11-2009, 06:48 PM   #20
ThurzNite's Avatar
a33i30: describe the road conditions. Do you remember the 3rd gen chase through #2 hwy that ended in oversteer?
__________________
Dr J
MCC member #27
Old 01-11-2009, 08:50 PM   #21
damn @maxima rear end sliding out.
__________________
FOR SALE
97-99 Headlights $100 shipped obo
Snypa is offline   Reply With Quote
Old 01-12-2009, 10:53 AM   #22
doesn't twitter
rxm6's Avatar
Quote:
Originally Posted by a33i30 View Post
...it was on a mountain road over a crest.
There is your answer. Weight transfer over crest means less weight on the back wheels, which in turn means less friction on the road from your tires, which means oversteer possibilities.
Old 01-13-2009, 02:14 PM   #23
Send a message via ICQ to Torgus Send a message via AIM to Torgus Send a message via MSN to Torgus Send a message via Yahoo to Torgus Send a message via Skype™ to Torgus
if the maxima was fwd and not rwd we wouldn't have this problem.
Torgus is offline   Reply With Quote
Old 01-14-2009, 09:22 PM   #24
doesn't twitter
rxm6's Avatar
Old 01-15-2009, 12:21 PM   #25
heh
Old 02-01-2009, 01:48 PM   #26
Quote:
clear roads, it was hot that day, the car basically started understeering then i tapped the brakes a little and the a$$ went out, i tried the same corner the other day and it didnt oversteer O_o. It was probably becouse i tapped the brake.
Old 02-01-2009, 08:38 PM   #27
My axles cry for mercy...
essential1's Avatar
It shouldnt be surprising that you oversteered then...
__________________
01 I30, [5 speed swap][4th gen pedals and master cylinder][OEM clutch][OEM flywheel][ksport coilovers front, D2 coilovers rear][10k hid headlights and fogs][custom WAI][cattman exhaust][tenzo type-M, 19x8.5 +17F, 19x10 +22R][300zx calipers][Cobra 13" drilled and slotted rotors]
5 speed swap myths BUSTED:
1. Both driver and passenger side AUTO axles work fine.
2. AUTO flywheel bolts work fine.
essential1 is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
