sounds like my bed when me and my gf are... nvm.
check to see if there are spring isolators on the top and bottom of the spring. your best bet to get rid of the noise is take apart your suspension, make sure all your bushings are in the right place, grease/lube it up, and reinstall correctly. if the sound still persists, check your LCA bushings.
blkonblkse: for the clunking noises you are experiencing when turning, check your upper strut bearing to make sure its still in one piece. mines been torn to shreds a couple times even with RTV-ing it to the upper mount. but this time so far so good. i still get clunking but i need to regrease the GC springs again. lame. try greasing up your springs with wheel bearing grease on the top and bottom. i find that works the best.
