Advanced Suspension, Chassis, and BrakingTalk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
For quite awhile I have had some squeaking coming from my front brakes. They don't do it at first when they are cold, just after they are warmed up with a few stops. I have the Q45 front setup. If I press on the brake pedal ever so slightly (not even enough to make the car slow at all) the squealing goes away. As soon as I release it comes back. It is VERY annoying driving in town. I pulled everything apart and regreased it with that clear brake lubricant in a tube, but it hasn't made a difference. Thoughts?
__________________
MODS: VLSD 5-Speed Swap, Exedy Stage 1 Clutch, Turbo Manifold Studs, Koni/Eibach Suspension, Unorthodox Racing UDP, Blehmco Grounding Kit, WSP Y-Pipe, Place Racing CAI, Custom STS, Polyurethane Front & Rear Bushings, Q45 Front Brakes (Blehmco S.S. Lines, Brembo Rotors, Hawk HPS Pads), Courtesy Nissan FSTB, Blehmco RSTB, NissanWorks TB & IACV Spacers, 9007 Headlight Bulb Conversion, GXE Fog Lamps, Sound System (Infinity, JVC, Polk, MTX), 2k3 SE 17" Wheels w/ 225/50R17 Hankook HR Ventus II Tires
Next Install: Blehmco Stage 2 Lower Tie Bar & Suspension Techniques Swaybars
Do you have Q45 rotors or Cobra? I have the Cobras, and even with Jeff's rings they aren't completely hubcentric. I have the same problem you have, and when I had my car on the dyno I noticed I could see the rotor spinning unevenly, so I'm thinking the noise could come from the rotor rubbing against the caliper since it's not completely hubcentric. I've had my setup for 2 years now with some auto-x, so maybe I should be checking my pads....hmm...
__________________
5-speed DE-K with 205 whp and 199 wtq SAE corrected
Shortened Koni yellows/Eibachs, Cobra/Q45 brakes, SFC's, LTB, TB's, all ES bushings, etc...
It definitely isn't the wear indicators, the setup has only been on the car for a year or so. The pads are Hawk HPS and the rotors are Q45's made by Brembo.
__________________
yup, mine are the same way. stock brakes, but same symptoms. I checked out the pads and it's the wear indicators! I'm still waiting a while for pads though...
Didn't you just rip the indicators off and keep going?
im looking into this mod for the I.. Is there a thread that covers all the parts needed to swap? Any installation tips now that you've both had some noise issues?
Thanks,
__________________
03 I35: Transgo Shift kit, H&R front drop with Illuminas 2F-2R, Stage 2 LTB, Progress RSB, FSTB, Front Sway ES Poly Bushings, Spark advance, Hyperground kit, Clear front corners, G35 wheelies, Black n Tan Interior, LED rear conversion.
