A few questions about warped rotors
Just installed brand new Brembo blanks with Hawk HPS. And while bedding the pads, I noticed a dull pulsating sound that seems to be coming from my front right wheel.
The noise is heard only when pedal is pressed relatively hard. (not slammed, but still above average braking force. (on a scale from 1 to 10, where 10 = pedal slammed to the floor with activating ABS. I'd say it happens at 5 and above.)
*All bolts seem to be tight (double checked)
*The problem showed up only after new brakes were installed.
*The pedal does NOT pulsate, it's only the sound.
Do you guys think it's a warped rotor, even though the pedal does not pulsate, and I did all bedding procedures perfectly? If not, what else could be the cause?
If the rotor is indeed warped, would in make sense to resurface it, or I should just get another new rotor? (I was dumb enough not to keep the receipt when I got them - a wile ago. So it would be another $60+.)
I read resurfacing a warped rotor, is only a short term solution since the surface will get uneven after a couple of thousand miles again. Is that even true??
Thanks in advance!
__________________
2000 SE 5-speed
BC coilovers | BlehmCo LTB | Progress RSB | ES bushings | OTTO FSTB | Toyo Proxes 4 | GAB2
Hawk HPS | Brembo blanks | Cattman muffler | BlehmCo grounding | AutoVation pedals
