Advanced Suspension, Chassis, and BrakingTalk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
The new intake is much taller than a stock manifold. So I need to make one. I'm trying to keep the weight down but more importantly restore the structural integrity. Here's the main bar and I'm thinking I need to add 2 more bars. Any thoughts?
The itty bitty bolts are temporary till i order some beefier ones. Also the bar looks close the manifold I know But... My mounts basically SOLID and will not move. I'm also going to add a lower tie bar to help.
not alot of leeway for that bar and engine. id push it out just a tad bit more.
for the final design, try placing more support from the bar to center of firewall in a triangular shape. or from the towers themselves to the firewall. that should stiffen it up a bit.
something like this:
This is what I was going to suggest as well. Remember the mid-60's shelby Mustangs? They used a triangulated strut bar system.
Oh nice, I like the tri-bar. I REALLY doubt my motor will move more than 3/4 of an inch, because the mounts are solid. But I'll see about moving it out more.
It looks like alot is missing, Thats only because I removed some sheet metal.
In the event it would move under hard acceleration the top of the manifold would move away from the bar. And I would never drop the clutch in reverse so I'm good on the clearance.
i do realize the engine moves in back motion under acceleration but i just dont rigid parts that are too close to the engine. even if you have solid mounts, it'd make me nervous lol.
