Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Thread Tools Display Modes
Old 04-15-2008, 02:56 PM   #1
BBK fitment
Does this look right?
__________________
goon9 is offline   Reply With Quote
Old 04-15-2008, 03:03 PM   #2
I'm needing a caw
Jeff92se's Avatar
Yup. it's only 1-2mm and I ran it this way for years. Eventually I broke off the pad lip that developed but no biggie. Never had any noise/squeal problems associated with it, not does it affect anything. Wait until you drive on it. ESPECIALLY if you have the Z31 rear upgrade. It's freakin' nice.
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 04-15-2008, 04:25 PM   #3
Quote:
Oh good, I can't wait to drive it! It maky be a few months till it's road worthy...
Oh, I put on my wheel for clearance, the wheel fit fine. But i Spun the wheel and snapped off the chrome valve stem! Crappy... I need a flush kind of valve stem now.
Edit: z31 upgrade on too.
__________________
Old 04-16-2008, 03:49 PM   #4
Location: Carson CA is where i live. Queens NYC is always home.
Send a message via AIM to GAMERA30
YEAH... thats right. Mine does that too. I did a BBK w/ brembo z33 rotors and z32 calipers on my friends s13.it did that also. It`s because the arc of the rotor is wider then what the calipers were really made for.I had to use J30 calipers because the Z32 calipers dont clear my spokes on my rims Jeff is right.. wait till u do z31 rears ... i`m having fun w/ mine...lol
GAMERA30 is offline   Reply With Quote
Old 04-17-2008, 07:56 AM   #5
t_ahan's Avatar
300zx bbk
does anyone know if BlehmCo's 300zx kit with the 04 rotors will clear the 03-04 Infiniti G35 17x7 (alloy), 6-spoke wheels on a 96 max?
__________________
MR.T
t_ahan is offline   Reply With Quote
Old 04-17-2008, 09:36 AM   #6
your best bet is to test fit Mr.T. I think it should. The 04 rotors are positioned more inward the the Cobra rotor.I thought my Z32 calipers would clear w/my rims but no dice. Thats Y i run J30.The RWD Nissan/Infiniti rims "should" clear Matts kit. The Z/G rims have more nigative offset.
Old 04-17-2008, 09:41 AM   #7
I think it should. RWD Nissan/Infiniti rims have more negative offset.
Old 04-17-2008, 12:27 PM   #8
I'm needing a caw
Jeff92se's Avatar
Quote:
COUPE 17s = probably
SEDAN 17s = probably not
Yes, the they are different wheels. They LOOK very similar though.
__________________
Sold Jan 14, 2006'
Mod list:
Old 04-17-2008, 01:07 PM   #9
The offset made the spokes for the coupe to be more concaved... therefore they can house the BBK. I dont think you can fit the 300zx BBK with G sedans unless you get like 10-15mm spacers.
__________________
IHAVEA2KMAXIMA is offline   Reply With Quote
Old 04-22-2008, 08:39 PM   #10
Obama hates Maximas
irish44j's Avatar
agreed. The coupe 17s don't have much clearance (10mm maybe), and they are 30/33 offset and 8" wide while the sedan 17s are (IIRC) 40 offset and 7" wide....you would probably need a spacer.
__________________
2000 Maxima SE (sold but still on the org) - 2009 Subaru WRX - 2008 4Runner SportEdition - 1990 Cherokee Laredo - 1970 Triumph GT6 Mk2
Eibachs*Illuminas*BlehmCo Stage 2 LTB*Truax Stage 2 SFCs*Stillen RSB+RSTB*Otto FSTB*Cattman Ypipe*Place Racing CAI*
Wilwood Calipers*BlehmCo 2pc Rotors*Frankencar Catback*ES Bushings*Samco Hoses*Goodridge Lines*Raxles*Everything JDM yo!
irish44j is offline   Reply With Quote
Old 04-23-2008, 12:10 PM   #11
If using the sedan rin w/ 40mm orrset.. then probably NO. My rims have 40mm offset and I had to use Infiniti J30 calipers .. see pic
Old 04-25-2008, 09:14 AM   #12
STFU n00b!
Offset from a different rim doesn't matter at all though. It's all about the spok design of that particular rim.
__________________
93 SE 5 spd- Only thing still stock is the carpet.
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
