Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Thread Tools Display Modes
Old 04-12-2008, 08:11 PM   #1
Rear link swap out.
Here's what I'm trying out for my rear suspension.
The 4 parallel links are are steel with grease fittings for the chromoly hiem joints.
The 2 lateral are steel, no grease fittings, teflon hiem joints.
To compensate for being lowered I raised the inner mounting points. This gave the link angle a more positive angle till full compression. I also replaced the tiny bolts with 5/8's bolts and 3/4 bolts all grade 8(Standard bolts because I didn't want to use bushings with the hiem joints). I know it's over kill but it's a little more piece of mind for me. Also before being lowered on stock links, they sat at a negative angle. So when under compression the wheel would tuck inside the well, leaving me with 5mm a room between the already stretched tire and rolled fender. So after I swapped over, the links the wheel actaully pushes out and no longer inside of the wheel well. To remedy I flared the fenders a tad.
__________________
goon9 is offline   Reply With Quote
Old 04-12-2008, 08:31 PM   #2
Nice man, let's see a picture of the whole car.
__________________
All stock.
MorpheusZero is offline   Reply With Quote
Old 04-13-2008, 03:21 AM   #3
Send a message via Yahoo to jonmandude
Isn't that the same as Matt's (Blehmco) stuff?
jonmandude is offline   Reply With Quote
Old 04-13-2008, 07:24 AM   #4
Quote:
Not part for part. The lateral rod is similar but i think a little bit thicker.
__________________
Old 04-15-2008, 12:51 PM   #5
nice job man
how wide are those wheels?
__________________
http://www.cardomain.com/ride/451812
93 se
5spd with a couple of mods..........oh yeah, and a turbo
4signs is offline   Reply With Quote
Old 04-15-2008, 02:54 PM   #6
Quote:
Originally Posted by 4signs View Post
nice job man
9 wide, the tires are around 245 stretched on.
__________________
Old 04-15-2008, 04:43 PM   #7
does this mean no RSB?
Armon is offline   Reply With Quote
Old 04-15-2008, 06:27 PM   #8
Quote:
No I'm putting the stock one back in till I can afford a better one.
__________________
Old 04-15-2008, 10:49 PM   #9
Send a message via AIM to MrDicks95SE
thats some nasty negative camber wear on those tires. rear assembly is really clean! but your under carriage could use some coating. massive rusting ftl.
__________________
MrDicks95SE is offline   Reply With Quote
Old 04-16-2008, 08:46 AM   #10
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
i want irs.
BLACKonBLACK98 is offline   Reply With Quote
Old 04-16-2008, 09:07 AM   #11
Quote:
how/where will you attach it?
Old 04-16-2008, 10:56 AM   #12
I just noticed that you cut your trunk well out.
Old 04-16-2008, 02:59 PM   #13
yup, i Just redid it and will seem seal and prime this weekend.
__________________
Old 04-16-2008, 03:15 PM   #14
Well I don't have any pics... but it mounts in the stock location.
__________________
Old 04-16-2008, 06:05 PM   #15
Quote:
Originally Posted by BLACKonBLACK98 View Post
i want irs.
me too.
__________________
Old 04-16-2008, 09:56 PM   #16
Quote:
Originally Posted by MrDicks95SE View Post
me too.
Yah, but you only want it so you can camber in the rears and run stupid offset.
__________________
All stock.
Old 04-17-2008, 08:43 PM   #17
Quote:
Sounds like a good reason
I mainly did it for the strength vs. stock as well as bring back some of the handling.
__________________
Old 04-21-2008, 12:24 AM   #18
Let's see a few shots of the whole car?
__________________
All stock.
Old 04-21-2008, 04:52 PM   #19
I don't have any Real current pics seeing as how everything in the engine bay is being redone as well as and over haul on the rear trunk and fenders. But here's what it lookeded before i tore back into it.
Here's the bay right now. I had to stop on it to finish up the rear.
Front bumper is staying the same, the side skirts will be modified to match the bottom body line better.
I can snap some pics of it on jack stands.... But i think you get the idea.
__________________
Old 04-25-2008, 09:17 AM   #20
STFU n00b!
looks good to me. how's the camber curves look for the rear links in that location? Moving the mounting points that much makes me worried about camber gain/loss during cornering.. so what suspension are you running on it now? springs/shocks/mounts?
__________________
93 SE 5 spd- Only thing still stock is the carpet.
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 04-25-2008, 02:12 PM   #21
Quote:
I've looked at other ppl's set-ups and noticed they had much longer links and thought it was worth trying. I'm going to probubly have it set around -.1 for the rear and i think it should be ok, I'll probubly be adjusting it for a little while to what feels right. It's only going to be used on the street but I wanna milk as much as i can out it.
To get and idea of the travel and curve I'll probubly make a video when I get it all tightened up.
For now kyb's and intrax. I'm shooting for konis with modified boots in the next upgrade as well as better sway bars.
__________________
Old 04-25-2008, 11:10 PM   #22
dont hate cuz only the cool people are doing it
__________________
Old 04-26-2008, 10:39 PM   #23
so, who wants to make this setup for 5th gens?
Old 04-27-2008, 08:09 AM   #24
STFU n00b!
It'll cost about $10,000....
__________________
Old 05-02-2008, 04:26 PM   #25
Send a message via AIM to Prophecy99
thats a lot of work goon.... props....
__________________
Imagination reveals truths that reality obscures.
02 VQ35DE GLE__-_\:._.:/_-___sold_91 VG30E GXE
[FSTB /H&R /Illuminas /LTB Stage II /20mm Spacers /Hayden 404 ATC /Blehmco Grounding Kit /Stillen F/R Lips /18" Exel RH-5 Gunmetal /Smoked Sides /30% /Taillight Vinyls /Eyelids /PIAA ]
(MY CARDOMAIN) Bleed GREEN
Prophecy99 is offline   Reply With Quote
Old 05-03-2008, 09:51 PM   #26
Quote:
__________________
Old 05-04-2008, 02:59 AM   #27
