I have a friend who is a Toyota tech and offered to give me a free alignment. My car has been moderately lowered for years but I only recently noticed that yes, the insides of all my tires are showing significantly more wear than the outsides. I suspected the problem was toe out and I was right. Over -0.30° toe on each side of the front.
On Thursday my friend put my Max on the expensive Hunter laser alignment rig and went to work on the tie rods. Only thing was, he forgot to put the steering wheel lock before he started adjusting the driver side. He got the toe to within 0.01° of 0 on both sides, but now my steering wheel is not centered! I was afraid of this. My question is, if I adjust each tie rod precisely the same number of turns (e.g. 1/4 turn clockwise on the left and 1/4 turn counterclockwise on the right), will I theoretically be able to recenter the wheel without throwing off the toe much? I want to do this as simply as possible but if I have to I can try the
jackstand and string method. Thanks for any insight.
