Quote:
Originally Posted by MorpheusZero
Caliper profile is important but so is rotor size. You will not get a decent size rotor under a 15" wheel no matter what caliper you use. Also if you are using stock sawblades etc for wheels you are obviously going to have a problem with lateral caliper clearance.
You will be lucky if you're able to find a 12.2" rotor and caliper that clear 15" wheels. I suppose you could up the rotor thickness it might be worth it, but you'd have to mill down the rotor, probably fab up custom caliper relocation brackets etc. =\
Then again it might be doable, that's just my $.02.
I know... I need to start with first things first, finding out the lowest profile caliper available and from there I can start taking measurements as to what fits and what doesn't. This will be my 3rd maxima BBK so I know what goes into it.
2005 mustang owners are able to fit a few select 15" wheels over their stock front calipers and rotors which are 12.2". My 15" drag wheels may not fit over those brakes, but dropping the rotor size down a bit isn't a problem if necessary. Starting with the lowest profile caliper though will give me the most head-room to work with and I can size the rotor as necessary once I've decided on a caliper. Nothing is set in stone yet as I'm exploring options at this point. I really want to stay out of the "swap rotors before and after the drag strip" game that I used to play back in 2003-2004 if I can.
