Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Thread Tools Display Modes
Old 03-27-2008, 02:00 PM   #1
Yes, I Have One
maxitech's Avatar
Camber Question
Can the camber be changed w/o installing camber bolts? From what I've read on here toe-in is the only adjustable dimension.
My car is lowered on eibach springs and after I put them on I took my car in for an alignment. After a few thousand miles I noticed that the inner edge of my front tires was wearing rather quickly. I took it back to the shop and they fixed it.
Fast-forward another year and after having the front suspension apart again I took it back to the same shop for another alignment. Same scenario played out except this time I took it back in at the first signs of premature tire wear on the inner edge. They fixed the problem once again. This time I asked what they specifically did to fix my problem. The guy who did it told me he gave the front wheels an additional 1/4 degree of positive camber.
So my question is: can an alignment shop actually adjust your camber (and castor, for that matter)?
__________________
MODS: VLSD 5-Speed Swap, Exedy Stage 1 Clutch, Turbo Manifold Studs, Koni/Eibach Suspension, Unorthodox Racing UDP, Blehmco Grounding Kit, WSP Y-Pipe, Place Racing CAI, Custom STS, Polyurethane Front & Rear Bushings, Q45 Front Brakes (Blehmco S.S. Lines, Brembo Rotors, Hawk HPS Pads), Courtesy Nissan FSTB, Blehmco RSTB, NissanWorks TB & IACV Spacers, 9007 Headlight Bulb Conversion, GXE Fog Lamps, Sound System (Infinity, JVC, Polk, MTX), 2k3 SE 17" Wheels w/ 225/50R17 Hankook HR Ventus II Tires
Next Install: Blehmco Stage 2 Lower Tie Bar & Suspension Techniques Swaybars
maxitech is offline   Reply With Quote
Old 03-27-2008, 02:29 PM   #2
choray911's Avatar
There really isn't any factory adjustment. When you put the lowering springs on, it made the lower control arm more horizontal, making the angle to the strut tower sharper. Hence the additional camber. The only way I can think of to take that camber out is to use camber plates, or a smaller bolt in the top spindle hole. On my Ksports, the top hole were the spindle attaches to the strut is oblong, and additional camber can be added or taken away.
__________________
'96 black Se, 5spd with grey cloth interior because leather sucks! Turbonetics T04E turbo, Spearco FMIC, Tial 38mm waste gate, HKS SSBOV, Deachwerks 570 injectors, GReddy E-manage Blue, Sard FPR, Stillen Flywheel, XTD 6 puck kevlar clutch, Zeitronix WBO2 with all the trimmings, and some other crap. TSW REVO 17" bronze wheels, Z32 brake conversion, K-Sport Coilovers with pillow ball mounts and camber plates, 84' 300ZX hood scoop, blacked turn signals, and tails.
choray911 is offline   Reply With Quote
Old 03-27-2008, 02:34 PM   #3
STFU n00b!
There's enough slop in the bolt holes on the factory equipment to get about 1/4 degree of movement in it.
If you have Eibachs and are having alignment issues, you have something else wrong somewhere. wheel bearing, ball joint, control arm bushing, something.
__________________
93 SE 5 spd- Only thing still stock is the carpet.
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 03-27-2008, 03:28 PM   #4
Yes, I Have One
maxitech's Avatar
I'm not having issues, all front end parts are new, both driver-side and passenger-side tires were wearing exactly the same...So you think he adjusted the camber via sloppy bolt holes?
__________________
Old 03-27-2008, 07:13 PM   #5
Obama hates Maximas
irish44j's Avatar
Eibachs are not low enough to throw your camber off that much that it affects tire wear appreciably. Either your toe is wrong, or something else is bent/worn/loose, as Matt said.
irish44j is offline   Reply With Quote
Old 03-27-2008, 08:05 PM   #6
My foot in your ***
Greeny's Avatar
+3
Take your car to a different alignment shop. You should not be having camber issues with eibachs
Greeny is offline   Reply With Quote
Old 03-27-2008, 09:08 PM   #7
I found that if you go into a shop and Tell them exactly what you want for a camber setting and tell them you want a spec print out. They will ACTUALLY align our car...
__________________
goon9 is offline   Reply With Quote
Old 04-04-2008, 07:20 PM   #8
MMMWWWWAAAAA!!!!!
BenStoked's Avatar
couple of noobish questions(regarding suspension)
what exactly is a good camber setting for our cars(3gen)?
fsm says -1*00' to 30' for front, and -1*20' to 10'
first what do these numbers signify, degrees, and partial degrees?
when i get my car re-aligned, i want to know so that if they try to give me some bs, or whatever i can just tell them.
should both wheels be exactly the same? or just as long as they are in spec?
__________________
New to the forum? CLICK HERE!!!!
235,000 miles and still strong!
1991 black SE vg30e 5-sp.
Quote:
Originally Posted by 505max94se View Post
I don't really believe in the "know what you're doing" saying. You just need to believe in yourself, not be afraid, and have some common sense and knowlege.
My moto is, "if it can be done then do it!"
Another enjoyable quote.
BenStoked is offline   Reply With Quote
Old 04-06-2008, 10:04 AM   #9
Yes, I Have One
maxitech's Avatar
Here is a pic of the strut assembly w/o the hub assembly attached. I believe this is how alignment shops adjust the camber.
__________________
Old 04-06-2008, 12:06 PM   #10
Most will claim that it's impossible to adjust the camber and act like you have no idea what you're talking about if you tell them otherwise.
__________________
All stock.
MorpheusZero is offline   Reply With Quote
Old 04-07-2008, 02:43 PM   #11
Location: Carson CA is where i live. Queens NYC is always home.
Send a message via AIM to GAMERA30
wearing of the inside edge can also be caused from high speed cornering. After i put my springs ( eibach prokit) in, I was getting "brave"..lol My friend has the same springs in his car and they dont wear as fast. If u have Eibach prokit, it wont change the camber to the point where u need camber bolts. but if u have sportlines .. then u need them. I`ve tried slotting the holes on my struts like in that pic and it wasn`t that good. A nice bump will cause th strut to shift. For reference on getting camber bolts,1st-4th gen Max use 12 mm bolts. 5th-current gen use larger 14mm bolt.Hope this helps
GAMERA30 is offline   Reply With Quote
Old 04-07-2008, 06:34 PM   #12
Send a message via AIM to MrDicks95SE
Quote:
you're crazy.
__________________
MrDicks95SE is offline   Reply With Quote
Old 06-26-2008, 01:44 AM   #13
Send a message via AIM to maximafan91
GUYS HELP ME OUT HERE
I have a 1991 Maxima. I just put wheels from a 02 Maxima on it with 215/50r17 Falkens. I want my suspension done now. What do you recommend from experience? Would it be a good idea to go to les schwaab and have them do my suspension? thanks
__________________
91 Nissan Maxima SE 5 Speed
maximafan91 is offline   Reply With Quote
Old 06-26-2008, 07:23 AM   #14
choray911's Avatar
Quote:
Who is diz Les Schwaab you speak of?
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
