Advanced Suspension, Chassis, and BrakingTalk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
firestone lifetime alignments are good.......but.....
when I went this last time, here's what I got
So, the question is....do I go out and get some camber bolts or something to at least force them to match?
My left front is starting to cord on the inside since the wife curbed it and I ignored it for a while....but I know they do the camber when it's still in the air.
Should I care?
if you can't make out the pics, the camber is -1.4 L and -0.7 R
Camber is important, your car can develop a pull if it's too uneven.
The alignment dude should at least be able to get them within a few tenths of each other.
Plus you can run a little moar for mad tyte handlings, I try to keep it around -2 degrees. I get camber wear but it is not too bad if you drive like a madman.
Also, they don't measure the camber when it's in the air... that would be retarded. I'm not completely sure what you mean by that.
mad tyte handlings eh? perhaps i should invest in camber plates to get this -2* mad tyte-ness. perhaps with the low offset 19s i may need them and bend the rear beam
97SEdriver: take it back and have them re-adjust it to the specs you need. btw alignments are done with the car sitting on all four wheels on the ground with suspension under normal load. gotta be on crack for the suspension to be hanging and do an alignment like that...
Should I care?
wow, i would take your car back and have them realign that. your camber is pretty off. should be within those nominal brackets close to each other as possible.
heres the factory specs:
FRONT WHEEL ALIGNMENT
Camber, in degrees.
-1.00 Minimum
-0.25 Nominal
+0.50 Maximum
+0.75 Maximum left and right difference
Caster, in degrees
+2.00 Minimum
+2.75 Nominal
+3.50 Maximum
Kingpin inclination, in degrees
+13.50 Minimum
+14.25 Nominal
+15.00 Maximum
Total toe-in distance, in millimeters
+1 Minimum
+2 Nominal
+3 Maximum
Total toe-in angle (left plus right), in degrees
+0.09 Minimum
+0.18 Nominal
+0.27 Maximum
REAR WHEEL ALIGNMENT
Camber, in degrees
-1.75 Minimum
-1.00 Nominal
-0.25 Maximum
-3 Minimum
+1 Nominal
+5 Maximum
-0.27 Minimum
+0.09 Nominal
+0.43 Maximum
camber is the most important. also if your pulling slightly in either direction, its b/c of the camber. is your suspension stock or aftermarket? if aftermarket and have elongated struts holes, just tell the mechanic to mess around w/ that for more camber adjustment.
__________________
00VI, Full Exhaust, Suprastick, Ksport coilovers, FTSB, Hayden 404, Full LED interior,
CAI, 2K3 SE rims, RTP rotors, etc...
i actually need to get another alignment really really bad. outer front tires are worn like hell and the car pulls to the left. i am running a lot of neg camber, for auto-x and that "mad tyte handlings"
how much is it for the lifetime aligntment?
__________________
I think when I did it...it was around $150, but since then I've done it 4-5 times at least.....
$150 is not bad at all considering 1 time alignments usually cost around $50 -60 ish. if you adjust and messing w/ your suspension a lot, mine as well get the lifetime.
__________________
