Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Thread Tools Display Modes
Old 03-03-2008, 10:24 AM   #1
?? About Bleeding New Calp's + Old lines
Okay - i read a billion threads, ad nauseum....only found one instance of this question recurring:
I just swapped my front Calp's for the 04's.
I properly bled both front lines after - but I didn't bleed the rears.
..and YES - I KNOW how to bleed hydraulic lines properly - please don't ask.
I still have mushy pedal.
I AM going to bleed the rears now - but just wondering if it is typically necessary to bleed ALL FOUR lines/calp's after a caliper/line swap??
RR/LR/FR/FL seems to be the most accepted pattern for bleeding....so I got that.
**Also, do most of you guys with 6spds, get the KEY-OFF dead-pedal issue??
I had to literally RUN my engine to build proper pressure in the system...I find this weird! --must be to do with the power-assist system--?
Curious to hear what the rest of you have done.
Thanks,
gr
__________________
"I never saw a wild thing feel sorry for itself. A small bird will drop frozen dead from a bough without ever having felt sorry for itself." ~D H Lawrence
ghostrider17 is offline   Reply With Quote
Old 03-03-2008, 11:03 AM   #2
MAXIN' ON
Send a message via AIM to redls1
I always thought you had to do all 4 wheels when bleeding. But recently when I just tried to do the front calipers I didnt even touch the back and didnt have a problem. I just did the one side I was working on and everything has been fine. Maybe I got lucky.
__________________
2007 Maxima 3.5 SE
! 20" CHROME Katana Desire ! MTX MONO AMP !
! MTX 10" SUB ! BILLET GRILL !
redls1 is offline   Reply With Quote
Old 03-03-2008, 11:34 AM   #3
Send a message via AIM to !PrjctMax!
Think about it...if you do only the fronts, then you only need to bleed the fronts. If you were to have to do each caliper after bleeding one, then it'd be an ongoing circle.
That's just the way that I see it at least.
__________________
Lots of performance parts for sale
http://forums.maxima.org/6th-generat...-out-sale.html
OEM shocks, coil-packs, mud-flap, LIM
!PrjctMax! is offline   Reply With Quote
Old 03-03-2008, 11:58 AM   #4
...well - this is the same logic I used as well...but the pedal is still mushy, and I'm certain I bled them thoroughly....
i was careful to not push any air back in the lines when changing the calp's too....so I figured not bleeding the rears was the cause for the mushy pedal.
I'm curious to hear what others have done.?
keep 'em coming please boys!
gr
__________________
Old 03-03-2008, 07:10 PM   #5
Obama hates Maximas
irish44j's Avatar
With the car off, pump the pedal a few times and then re-bleed. You need to bleed the ABS systems as well, typically.
Also with new calipers sometimes air gets caught up inside and doesn't come out after the first bleeding. I almost always have to bleed again after driving the car around a bit, and you know how many different caliper swaps I've done (probably switched out the fronts 10+ times)
irish44j is offline   Reply With Quote
Old 03-03-2008, 07:11 PM   #6
Thanks Irish.
So, no need to bleed the rears then?
__________________
Old 03-03-2008, 07:41 PM   #7
RIP Cashj2002
Delvin's Avatar
Send a message via AIM to Delvin
Quote:
Originally Posted by ghostrider17 View Post
Thanks Irish.
You shouldn't need to unless you let the master cylinder go dry and continued to bleed by mistake.
__________________
Family Photo
Delvin is offline   Reply With Quote
Old 03-04-2008, 09:28 AM   #8
Quote:
Nope - always very careful to not do that! --although with the engine running, the power-assist sucked fluid out of the res VERY quickly!! I don't recommend this procedure!!
Thanks for the replies, guys.
gr
__________________
Old 03-05-2008, 12:39 PM   #9
Mizike's Avatar
....just another thought, make sure you didnt install the calipers on the wrong side, i.e. left on right and right on left.
Mizike is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
