Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Thread Tools Display Modes
Old 02-08-2008, 01:18 PM   #1
Send a message via AIM to chillin014
what is in my rotor? (pic)
Im going to take a picture of it right now.
I am replacing my brembo blanks with brembo slotted on the front and I noticed while looking at the profile of the rotor there is this metal wire going through about 3 or 4 of the cooling fins. is this some sort of weight for balancing? or should I remove it?
also ive got the rotors on correct right? this picture is of the passenger side of the car. outter part of the slot should be hitting the brake pad first right?
chillin014 is offline   Reply With Quote
Old 02-08-2008, 04:00 PM   #2
Send a message via AIM to MOHFpro90
Looks like weight balancing to me. But I just got some powerslots in for a friends car and they dont have that.
They are on correct.
__________________
FOR SALE: Ksport Coilovers, VQ30DE Engine, MAF, Auto ECU, Stock Parts
00VI | 5.5Gen BBK | Axxis Ceramic | Raxles | Ksports | 00 5 spokes | AE'd | Cleared Tails | Shortram | 9007 conversion | LED interior | SNOMAX's LCAs
MOHFpro90 is offline   Reply With Quote
Old 02-08-2008, 04:02 PM   #3
thanks for the response. sucks i got some out of whack rotors i guess.
Old 02-09-2008, 07:28 PM   #4
STFU n00b!
that's pretty normal. they'll use that to balance the rotors instead of grinding metal off the other side to put it in balance.
personally I'd rather see it ground off on the other side instead of adding weight and something that might fall out later.
__________________
93 SE 5 spd- Only thing still stock is the carpet.
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 02-09-2008, 07:33 PM   #5
thats what i was thinking....oh well...nothing i can do about it now. My brake pedal still feels frickin spongey. like the car just doesnt seem to ever BITE when I brake. I even embedded the pads...
Old 02-09-2008, 09:34 PM   #6
STFU n00b!
did you use 2 people to bleed the brakes?
what pads?
what fluid?
did you suck out all the old nasty fluid out of the reservoir before refilling with fresh fluid?
__________________
Old 02-10-2008, 02:04 PM   #7
what pads?
what fluid?
yeah 2 ppl. regular dot 3 fluid i forget the brand, one of the popular ones yellow bottle. no i didnt suck any old fluid out, i didnt want to create anymore air in there than there was before.
pads are metal master's.
Old 02-10-2008, 02:59 PM   #8
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
i've been doing some research on brake fluid today and apparently old fluid is a cause of pedal sponginess. might want to flush it.
BLACKonBLACK98 is offline   Reply With Quote
Old 02-10-2008, 03:10 PM   #9
Quote:
damn. so are you going with that blue high performance stuff? or just fresh fluid
Old 02-10-2008, 04:36 PM   #10
STFU n00b!
pick up a bottle of valvoline synpower brake fluid from autozone. it's the best stuff you'll find for the price.
suck the old fluid out of the reservoir and pour fresh stuff in. then bleed one wheel at a time according to the FSM (or see stickies in 3/4/5/6 gen forums.). use 2 people. one to pump up the pedal about 3-4-5 times and hold it, then the second person to crack the bleeder screw open and let fluid drain out. when the pedal is on the floor, close the bleeder and have the guy ont he pedal pump up pressure again.
that's the best way to bleed these systems, regardless of what all the other forums and people tell you (and if anyone's bled more nissan brakes than me around here, I'd like to meet them. )
__________________
Old 02-10-2008, 04:52 PM   #11
thanks. yeah that sounds like how i was doing it. I do have one question though..when you open the valve the fluid squirts out right (i have a little clear hose on the end of the bleeder). So my question is, do you open it until the pressure stops pushing fluid out and then close the bleeder? Or do you open it and close it fairly quickly. Because I always felt like when i leave it open more than a few seconds the fluid is able to go backwards into the bleeder since the pressure is no longer there. you know what im sayin?
Old 02-10-2008, 05:03 PM   #12
A32shop.com
i'll let matt (or someone else) answer that since i don't know much about bleeding, but iirc you are supposed to close the bleeder screw once the brake pedal has bottomed out.
anybody got opinions on speed bleeders?
Old 02-10-2008, 05:11 PM   #13
My foot in your ***
Greeny's Avatar
Quote:
Here's how me-n-my son bleed brake systems..
Son is the pedal pusher,I am the bleeder screw guy,(clear bleed hose into cup of fluid and wrench ready)
My son already knows the drill by heart now, but instruct your pedal guy to pump the brakes 2/3 times,then hold firmly on the pedal,when he signals ready, I open the bleeder, KEY PART HERE..Make sure your pedal helper is continuing to push the pedal until it hits the floor, then make sure he/she holds it there until you close the bleeder screw. Then repeat a few more times.
Communication between you and your helper is key if they haven't done this sort of thing before..
__________________
Greeny is offline   Reply With Quote
Old 02-10-2008, 05:11 PM   #14
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Speed bleeders are fine . We use them at school all the time.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE 343whp/356wtq Turbonetics 60-1 @18psi,SAFCII,r33 full kit,Acura TL retroed headlights.Innovate LC1 wideband O2
Spec Stage 3 clutch, 550cc DW injectors,MEVI.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 02-10-2008, 08:21 PM   #15
STFU n00b!
I've used speed bleeders, but don't like them that well. with how picky nissans are about spongy pedals, I tend to recommend against them on nissans.
I even have a set on my 240 with the wilwood front/Z32 rear brake setup, and I do it just like they weren't there.
__________________
Old 02-10-2008, 08:35 PM   #16
Send a message via AIM to !PrjctMax!
Alright, here's a question for ya...when does the bleeder screw guy close the valve? Do you let the fluid drain until it stops, or shut it before it stops? I would figure that when it stops, it would suck in more air, correct?
__________________
Lots of performance parts for sale
http://forums.maxima.org/6th-generat...-out-sale.html
OEM shocks, coil-packs, mud-flap, LIM
!PrjctMax! is offline   Reply With Quote
Old 02-10-2008, 09:04 PM   #17
STFU n00b!
when it stops. that's why you put a rubber hose on it.
__________________
Old 02-10-2008, 09:21 PM   #18
So that's why when my dad and I bled my brakes for the first time they were spongy. No hose on it or anything, just a little bottle to have the fluid sip into.
What does the rubber hose do exactly? Prevent air from coming in?
__________________
Old 02-10-2008, 11:16 PM   #19
I connect a hose to the bleeder and bleed. I can see the bubble in the air line tube. But after a few pumps of fresh fluid, the bubbles are gone, and the fluid changes from brownish to clear. hehe..
The LAST one, I do what was mentioned. PUMP HOLD and LOCK.
FishyMan is offline   Reply With Quote
Old 02-11-2008, 06:31 AM   #20
STFU n00b!
Yup.
for the most part you're squeezing fluid out the house, but then the small air bubbles too.
but for the small volume that gets sucked back in before you close the bleeder, the hose prevents it from being air because its holding a decent amount of fluid right there at the bleeder.
__________________
Old 02-11-2008, 07:09 AM   #21
My foot in your ***
Greeny's Avatar
+1
I bought a speed bleeder some years back, didn't like the results at all, the pedal was still spongy. It's in the bottom of one of my tool boxes collecting dust..
__________________
Old 02-11-2008, 12:06 PM   #22
STFU n00b!
He's referring to the bleeder screw replacements that screw into the caliper.
__________________
Old 02-11-2008, 12:13 PM   #23
My foot in your ***
Greeny's Avatar
Nice animation..
I had another blond moment..
Old 02-11-2008, 01:22 PM   #24
A32shop.com
heh... geuss this thread was just a little late then. not only did i just buy a set of speed bleeders but i shelled out for the stainless version. oh well, won't be the first time i waisted some money. hopefully they'll work out for me though. i'm not as performance oriented as a lot of you guys.
Old 02-11-2008, 01:35 PM   #25
bling bling!!!
Old 02-11-2008, 01:50 PM   #26
STFU n00b!
