Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Thread Tools Display Modes
Old 02-04-2008, 10:25 AM   #1
A32shop.com
BLACKonBLACK98's Avatar
Send a message via AIM to BLACKonBLACK98 Send a message via MSN to BLACKonBLACK98 Send a message via Yahoo to BLACKonBLACK98
J30 BBK questions?
I had pretty much given up on upgrading my braking any further but I started reading about the J30 upgrade and it seemed like it was perfect for my application. I'm into deep wheels so the bbks i was looking into (z32 then willwood) kind of lost there appeal. I want to run a normal, or even super low, disk in the future so the J30 caught my attention when i heard they had stock clearance. I went ahead and ordered some reman. calipers, now on to the rotors/brackets. I know some have used milled oem rotors and some have used cobra rotors with Jeff's kit, but has anybody used them with Matt's brackets and 04 rotors? My understanding is that the J30/Q45 calipers have the same mounting dimensions as the Z32, and if they work with Jeff's they should work with Matt's too right? Am i missing anything here?
BLACKonBLACK98 is offline   Reply With Quote
Old 02-04-2008, 11:14 AM   #2
STFU n00b!
I would think they should work if they work with the Cobra rotor kit and need the 3mm milling to fit the stock rotor with that caliper on the Max..
it sounds as if that's the case here, so I'd think they'll work.
__________________
93 SE 5 spd- Only thing still stock is the carpet.
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 02-04-2008, 11:28 AM   #3
A32shop.com
whats the eta on your next run of brackets, or do you have any left? this might make a good (more) affordable addition to your brake lineup. j30/q45 calipers are pretty cheap and you don't need new lines.
ot: any update on your status for the meet?
Old 02-04-2008, 05:31 PM   #4
I'm in for q45 brackets!!!
__________________
goon9 is offline   Reply With Quote
Old 02-04-2008, 05:37 PM   #5
A32shop.com
it wouldn't be a new product, just a new use of an existing one. what car is that in your sig?
Old 02-04-2008, 08:43 PM   #6
Send a message via MSN to 96blkonblkse
The J30 caliper will bolt onto Jeff's bracket. They all used the same dimensions in respect to bolting onto the spindle. If you use the J30 torque member you will need J30 pads. Im sure you probably knew that but just in case. I had originally used the A32 torque member and J30 caliper but i wasnt happy with it, i wanted my 4 piston calipers lol.
I have Jeff's brackets sitting waiting to be installed, the corresponding holes lined up so i cant see why it wouldnt work. Jeff's require 13" Cobra rotors though.
__________________
VQ30DET - Holset HE351, Tial 38MM, HKS SSQ, MEVI, 3" Turbo back, Tein Coilovers, 17" Superleggeras, Full Z32 BBK
"Because boosted is beter.."
96blkonblkse is offline   Reply With Quote
Old 02-04-2008, 09:06 PM   #7
Quote:
...A maxima.
I want brackets to make the 13" rotors work, I suppose that means I'll need rings also. Are these out of production?
__________________
Old 02-05-2008, 08:17 AM   #8
A32shop.com
pm Jeff92se, he still makes the cobra kit afaik.
any full pics of that car? looks sick.
Old 02-06-2008, 05:09 PM   #9
Looks like sin atm
There is afew in here
If you love your VG POST A PIC HERE!
__________________
Old 02-06-2008, 07:04 PM   #10
PM me for LCA's!
SNOMAX's Avatar
You don't necessarily need rings if you get the holes redrilled on the rotors. There is a vendor who can sell them that way, if you haven't bought them yet.
I dont run the rings, but I have it redrilled.
SNOMAX is offline   Reply With Quote
Old 02-07-2008, 10:46 AM   #11
Koni Kroo
95maxrider's Avatar
Send a message via AIM to 95maxrider
Did this eliminate the problem of the rotor 'unseating' itself when you take off a wheel?
95maxrider is offline   Reply With Quote
Old 02-07-2008, 11:05 AM   #12
I'm needing a caw
Jeff92se's Avatar
For your information, I'm considering offering the brackets w/o the rings. My ring maker has backed out because they can't make them for the price they have before. If people are running these successfully w/o the rings (BUT USING THE REDRILLED COBRA ROTORS), then I'll just offer then this way. But I'd require the use of the redrilled rotors though.
Chime in.
__________________
2003 G35 Sedan. Mods comin'
3-gen parts for sale
Sold Jan 14, 2006'
Mod list:
Eibach/Konis - ST front sway bar/Addco rear bar - Blemco rstb - Otto fstb
350Z 18" touring wheels.
Modified Cattman Y, Custom flex, 4-gen Carsound cat, Custom cat-back, Y2K muffler
Custom CAI, custom ground kit, JWT ecu, Fidanza flywheel, ACT clutch, Jeff92se Cobra 13" bbk with 300zx 30mm polished alum calipers.
Jeff92se is offline   Reply With Quote
Old 02-07-2008, 12:04 PM   #13
Send a message via AIM to kzoosho Send a message via MSN to kzoosho Send a message via Yahoo to kzoosho
Im in for brackets too. Seeing i need to upgrade the stoping since it goes better.
__________________
99 GXE Auto V1 370cc injectors and Modded vb.
97 5sp SE 343whp/356wtq Turbonetics 60-1 @18psi,SAFCII,r33 full kit,Acura TL retroed headlights.Innovate LC1 wideband O2
Spec Stage 3 clutch, 550cc DW injectors,MEVI.
91 GXE Auto bone stock beater
Led retro's Pm me
kzoosho is offline   Reply With Quote
Old 02-08-2008, 03:20 PM   #14
I'm needing a caw
Jeff92se's Avatar
How's that been working out? Well I assume.
It's Automax in the Group deal forum that sells them this way. Recommened and will probably be a requirement to buy the Cobra rotors this way as I probably won't be offering the rings anymore
__________________
Sold Jan 14, 2006'
Mod list:
Old 02-26-2008, 03:03 PM   #15
Wait, I kinda got lost when reading the posts on the page........
So can I use J30 calipers and Bridges on my 98 SE as a direct bolt-on to my spindle?? Or do I need to get different mounting brackets??
And what rotors should I use????
__________________
-- Progress Springs w/ Tokico Illuminas - Progress Rear Sway Bar - Otto FSTB - Courtesy Nissan RSTB - J30 Front brake calipers w/ RTP Blanks and Hawk HPS Pads - JWT Pop Filter Intake - Ground Wire Kit - Unorthodox Racing Lightened Crank Pulley - Warpspeed Y, High Flow Cat, Custom B and Dynomax Muffler - Red/White Tails - Clear Corners --
Drivin Maxima is offline   Reply With Quote
Old 02-26-2008, 03:08 PM   #16
I'm needing a caw
Jeff92se's Avatar
J30 calipers + J30 rotors = need to shave 3mm off the radius. Then bolt on
J30 calipers + 13" Ford Cobra rotors = my brackets and need to purchase the rotors/pads/ss lines from Automax
__________________
Sold Jan 14, 2006'
Mod list:
Old 08-27-2008, 12:02 AM   #17
Kinda noob-ish of me-Believe me. I have spent the last 3 hours searching...But will J30 calipers and rotors hit a 5th Gen? 2001. From all I've found-the only option 2000-01 has is BlehmCo's...I can't imagine that the spindle's would've changed enough that I have no options here. Thanx.
flatcat19 is offline   Reply With Quote
Old 08-27-2008, 12:13 AM   #18
Old 08-27-2008, 06:42 PM   #19
Quote:
As far as I remember, the 5th Gen front brakes are veeerrryy similar to the front 4th Gen brakes......if not the same.
I dont think youll have a problem....
PS I might be selling my J30 setup (check sig for details) with less than 6K on it pretty soon....
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
