Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Thread Tools Display Modes
Old 01-29-2008, 07:03 PM   #1
Yes, I Have One
maxitech's Avatar
Having Trouble Rebuilding Q45 Calipers
The dust boot's lip doesn't want to seat in the groove with the piston in place and the piston doesn't want to slide into its hole with the dust boot already seated. I will post a link to what I am talking about shortly. The process I am stuck on is at the bottom of the page.
__________________
MODS: VLSD 5-Speed Swap, Exedy Stage 1 Clutch, Turbo Manifold Studs, Koni/Eibach Suspension, Unorthodox Racing UDP, Blehmco Grounding Kit, WSP Y-Pipe, Place Racing CAI, Custom STS, Polyurethane Front & Rear Bushings, Q45 Front Brakes (Blehmco S.S. Lines, Brembo Rotors, Hawk HPS Pads), Courtesy Nissan FSTB, Blehmco RSTB, NissanWorks TB & IACV Spacers, 9007 Headlight Bulb Conversion, GXE Fog Lamps, Sound System (Infinity, JVC, Polk, MTX), 2k3 SE 17" Wheels w/ 225/50R17 Hankook HR Ventus II Tires
Next Install: Blehmco Stage 2 Lower Tie Bar & Suspension Techniques Swaybars
maxitech is offline   Reply With Quote
Old 01-29-2008, 07:18 PM   #2
STFU n00b!
I remember that a while back doing one on another car.
IIRC I wound up using a plastic screwdriver or something like that to carefully wedge it in there. it was a PITA but I eventually got it done.
__________________
93 SE 5 spd- Only thing still stock is the carpet.
Check out the toys I make on my website!
Matt93SE is offline   Reply With Quote
Old 01-29-2008, 08:31 PM   #3
Yes, I Have One
maxitech's Avatar
Last step of the link is giving me trouble. Using a mini-flathead screwdriver...not working so hot...
http://www.nicoclub.com/articles.php?id=214906
__________________
Old 01-29-2008, 09:31 PM   #4
2nd Gen Boostinator
Big_E-Dog's Avatar
take your time, in the 300zx calipers when i rebuild them i put the rubber on the bottom first, but he says he used his finngers, to push it in so try that and try to rotate the cover while putting it in helps on everything i do.
__________________
Xenon projector headlamps/carbon fiber/ NGK plugs&wires/60mm TB/FTSB&RTSB/BMW oil cooler/LED tails and turnsignals/300zx turbo motor w/intercooler/2.5 in exaust/HKS turbo timer&bov/300zx calipers slotted&drilled rotors/K&N filter/2x T3 garrett turbochargers
Big_E-Dog is offline   Reply With Quote
Old 02-05-2008, 06:12 PM   #5
Yes, I Have One
maxitech's Avatar
Finally got it done and the calipers are back on the car...what a PITA!
__________________
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
