Go Back   Maxima Forums > Advanced Performance > Advanced Suspension, Chassis, and Braking
Advanced Suspension, Chassis, and Braking Talk about suspension geometry, advanced handling/chassis setup, custom brakes, etc. NOT your basic brake pads and "best drop" Information.
Welcome to Maxima.org!
Welcome to Maxima.org,
You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to start new topics, reply to conversations, privately message other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join Maxima.org today!
Thread Tools Display Modes
Old 05-12-2007, 06:39 AM   #1
Slotted/drilled rotors - gimmick or worth it?
I'm looking to upgrade my stock brakes on my 6th gen because the rotors warp < 20,000 miles. Mileage is about 80% highway and I'm not a last second braker or even a speed freak.
Are slotted rotors worth the money where they'll last longer without warpage? I've seen deals on slotted/crossdrilled rotors c/w semi-metallic pads for < $300 through R1.
__________________
People who drive domestic are not domesticated.
xavalancheowner is offline   Reply With Quote
Old 05-12-2007, 07:44 AM   #2
You can't friend yourself
Kevlo911's Avatar
Get blanks.
Kevlo911 is offline   Reply With Quote
Old 05-13-2007, 09:36 PM   #3
Send a message via AIM to !PrjctMax!
I was in the same predicament a while ago and ended up going for the blanks. Slotted would help a LITTLE if you were to be autoxing your car often, but other than that, it's not really worth it.
Also, down the road not too many shops would be willing to "cut" the rotors because the slots could possibly screw up their machines.
The slots also reduce the amount of surface area that the pads can grab onto, so that also reduces braking distance. As for the "cooling," like I said unless you do 100+mph braking down to 40mph stops within a short amount of distance very often, then you sure as hell don't need these.
hope this helps
dan
__________________
Stopped in on 10/29/09.
!PrjctMax! is offline   Reply With Quote
Old 05-13-2007, 09:48 PM   #4
retired moderator
irish44j's Avatar
blanks.
btw, slotted would not help autocrossing in any way, shape, or form. They are a waste of money, as are drilled rotors - unless looks is all you're looking for.
irish44j is offline   Reply With Quote
Old 05-13-2007, 10:03 PM   #5
Quote:
Originally Posted by irish44j
blanks.
^^^ that too ^^^ I just woke up from a long nap and couldn't cover every aspect!
__________________
Old 05-14-2007, 07:54 AM   #6
maximabebe's Avatar
Out of curiosity, why would a huge corporation like Mercedes Benz throw drilled rotors on some of their higher end AMG models?
__________________
maximabebe is offline   Reply With Quote
Old 05-14-2007, 12:56 PM   #7
Quote:
Mainly for the "wow" effect and it's easier to price-up the rotors since they are "performance rotors from Mercedes" lol Another thing is that they will be eating through the pads like crazy, and I doubt that they would be willing to "cut" the rotors and instead would make excuses that the drills/slots would **** up their machines. So imo it's mainly a money market for benz...for my moms ML320 they wanted close to $1,500 if not more for f/r rotors and pads. I told my dad to get autozone stuff and he ended up paying $<500, if that and both of us installed them in a couple of hours.
But then again, these are cars that can easily do spirited runs up to 155mph regularly and maybe that's why the engineers thought of the "venting" advantages, even though for a daily driver it is totally unnecessary.
__________________
Old 05-31-2007, 09:38 PM   #8
Send a message via AIM to jack63ss
Maybe, or Maybe Not
My experience is that using Cross-Drilled or Slotted rotors will have little effect unless you are really leaning on them. A time when it will make a difference is if it is raining, but even then it will not be too noticeable under normal conditions. Emergency braking in wet or snowy weather, maybe.
Two key comments. First, match the pads and rotors to your driving style. If you drive normally 95% of the time (fast is okay, I mean how much do you use your brakes), I'de use regular pads and rotors. If you drive hard, brake a lot and late brake, you might try semi-metallic. Unless you autocross I would skip even thinking ceramic as you'll never get enough heat in them to make them work properly on the street. Second, do not cheap out. My last set of rotors were inexpensive cross-drilled (about $70 each) and they warped within 10k miles. At under 15k I had to replace front pads and rotors, and I am a 95% normal type driver. When they were new you could sense a slight difference in the rain, but after a couple of 1000 miles they lost it. I just replaced them with good quality, but not expensive, pads and blank rotors.
__________________
Thanks !
jack63ss is offline   Reply With Quote
Old 05-31-2007, 09:56 PM   #9
Blanks.
If you're doing regular track days then you could possibly justify slotted as they effectively "clean" the pads, but they're more prone to cracking and eat up your pads quicker.
The main you'll see race cars using cross-drilled rotors is for unsprung weight savings, not cooling.
Cross-drilled smallish rotors with low-gas pads: rice.
/thread.
MorpheusZero is offline   Reply With Quote
Old 09-30-2009, 01:05 PM   #10
Send a message via AIM to Shift_Knob
i differ here on this subject. i put a set of stock sized EBC dimpled and slotted rotors along with EBC green stuff pads on my Lincoln Mark VIII. i did notice a big difference in braking power and brake fade is quick stops from 120+ mph down to 20-30 mph.
i also have to disagree in the slotted rotors wearing down pads faster they have been on my car for about a year and a half now and i still have just under 1/2 pad left. one thing that you have to be wery of is cracking with drilled and slotted rotors. if you do get rotors with holes drilled all the way through dont get cheep ones they will crack.
__________________
95 maxima 5 speed : slammed, hai, flowmaster (aka pos)
2000 bonneville SSEi 3.8L supercharged : 3.3 pulley on blower, headers with 3" exhaust back to flowmasters, DHP tune by me, 285/40ZR17's on front and still spinning
88 chevy k2500: sm465 4 speed with granny low, 3" body lift, 35x12.50 BGF MT's, converted from TBI to carb, motor rebuilt by me with small cam, alum intake, and headders
Shift_Knob is offline   Reply With Quote
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are Off
Powered by vBulletin® Version 3.7.3
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Search Engine Optimization by vBSEO 3.2.0 RC7
Maxima.org Forums Home Here you can view your subscribed threads, work with private messages and edit your profile and preferences Frequently Asked Questions on the Forums Search Find other members Registration is free! Support Maxima.org! Receive perks and benefits by donating to Maxima.org Questions? Comments?  Suggestions? Contact Us! Visit our Sponsors View and submit Maxima events Log Out of Maxima.org
